San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Aug 3, 2016 at 9:16 PM
    Shennanigans
    Shennanigans Well-Known Member
    Eric
    2001 TRD prerunner sr5 rwd
    none.... yet
    ill try a regular hammer. When i tried to thread it through it ended up threading the sleeve and getting more fucked. tried putting it through the wrong way and it cant get past the fucked part
  2. Aug 3, 2016 at 9:17 PM
    Shennanigans
    Eric
    none.... yet
    worst come to worst, do you guys know any fab shops that do house calls?
  3. Aug 3, 2016 at 9:19 PM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Connor has all the ideas. Put a rachet on there and see if the threads will bite and pull it through.
  4. Aug 3, 2016 at 9:21 PM
    SKULLY
    Dave
    San Diego
    06 DCSB
    @Speed Freek
    Speed Freek[OP] likes this.
  5. Aug 3, 2016 at 9:21 PM
    Shennanigans
    Eric
    none.... yet
    I think the part that is really fucked is a few inches up, as the threads make it through. With a ton of effort I got it half way through the upper arm but it got lodged in there and we had to use a ton of force to get it out
  6. Aug 3, 2016 at 9:28 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    When I put my kit on, same kinda thing happened on my passenger side. It took alot of twisting to get it to line up enough when the arm was on to get it through the last (rearward) sleeve. Try putting a different (few inches long) bolt/ratchet extension in the fucked up hole, and use that leverage and a heavy hammer to try and massage it back in the right direction.
    SKULLY likes this.
  7. Aug 3, 2016 at 9:38 PM
    Shennanigans
    Eric
    none.... yet
    good idea, I'd like to avoid having to cut it off. I think im gonna try a drill bit first tomorrow i found a way to shimmy my drill in and *should* be able to clear it up a little bit
  8. Aug 3, 2016 at 10:23 PM
    Shennanigans
    Eric
    none.... yet
    also can you explain what you mean by that? like put it and tr to hammer the fucked up part out?
  9. Aug 3, 2016 at 10:41 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Truthfully, that part that is fucked is just a spacer. So even if you have to cut it off, you can space it out fairly easily.
  10. Aug 3, 2016 at 10:59 PM
    BrownMike
    San Diego
    1999 Taco 4x4
    -Put half of the other bolt/rod/ratchet extension inside sleeve that needs to be straightened from whatever side is tweaked.
    -Use a hammer to "tap" the bolt/extension in which ever direction to try and straighten out the end of the sleeve. Essentially using the bolt/ext. as a pry bar by applying force in any direction perpendicular to the shaft.
    It really shouldn't take too much to get that bolt back in if it came out easily. Lay the bolt on flat ground, and roll it to make sure its not bent.
    And maybe try some lube, that always helps with tight holes haha
  11. Aug 4, 2016 at 11:10 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    All you need to do is use an angle grinder with a de burr on the end to enlarge the opening a bit and it will go right through.
    4Running Daily likes this.
  12. Aug 4, 2016 at 12:09 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    Hi all, Does anybody have 4 spare wheels in your home or garage I could borrow for just two days?
    I desire to have my wheels Powder Coated, and shop needs me to turn in the wheels without tires,
    and I need my truck take the 4 wheels to the tire shop to have tires removed and then drop off my wheels to the paint shop.
    The best quote I got so far is $50 per wheel.
    (doesn't include the charge to take tires off, put back on, balance and alignment)
  13. Aug 4, 2016 at 1:09 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    What size wheels ?
  14. Aug 4, 2016 at 1:38 PM
    Shennanigans
    Eric
    none.... yet
    Thanks for the tips everyone. dunno what i was doing so stupid yesterday, @nfs257 came over and we had that bolt in in all of 5 minutes. my coil bucket is for sure bent, must have been the accident, but everything is in.
    Crom, 06HAOLE and nfs257 like this.
  15. Aug 4, 2016 at 2:33 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Great to have friends and Tacoma World to help!
  16. Aug 4, 2016 at 2:37 PM
    Shennanigans
    Eric
    none.... yet
    anyone have an ads spanner wrench i can use to adjust the coils more easily?
  17. Aug 4, 2016 at 6:47 PM
    SKULLY
    Dave
    San Diego
    06 DCSB
    Good on @nfs257 !! If there is anyone that knows how to unfuck something that got fucked up it's Chris! :rofl:
    Crom, 06HAOLE, 4Running Daily and 4 others like this.
  18. Aug 5, 2016 at 9:01 AM
    Speed Freek
    Not really it is extremely thin I might have another stock one laying around though good for one small impact..
    So fucking things up does learn you something! I knew it! :thumbsup:
    nfs257, SKULLY[QUOTED] and 06HAOLE like this.
  19. Aug 5, 2016 at 9:07 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    A Fox spanner works too. I have one in Escondido you are more than welcome to borrow
  20. Aug 5, 2016 at 9:12 AM
    David K
    You home today?
