San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Sep 6, 2016 at 6:03 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    It's a luxury I don't want to give up.
    If you are planning to use them I'd recommend that bed liner spray paint so you can touch it up after scraping the paint off.
  2. Sep 6, 2016 at 6:32 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Check for any kinks in the line, if not run a uv dye thru it and check for leaks
    anthony250f[QUOTED] likes this.
  3. Sep 6, 2016 at 6:37 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I was putting the uv dye but could not get any freon to enter the system lol
  4. Sep 6, 2016 at 7:14 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Thanks- I am leaning towards doing the Rustoleum spray for just that reason but wanted to check out options and do it right the first time :thumbsup:
  5. Sep 6, 2016 at 11:33 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Tombiology70 likes this.
  6. Sep 7, 2016 at 4:31 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I've tried several types of paint. Nothing out of a spray can lasted more than 1 or 2 runs on the leading faces. I like monstaliner, though it can be a pain in the ass if you have fillins on your sliders. Holds up well to the sand blasting and is easily touched up.
    Tombiology70[QUOTED] likes this.
  7. Sep 7, 2016 at 9:38 PM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    I sprayed mine with self etching primer and used rustoleum truck bed liner. I like that the texture is rough and touch-ups are easy. You will get all kinds of rock chips if you off road so don't waste the $
  8. Sep 8, 2016 at 9:32 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Have you tried removing both shraeder valves and blowing compressed air in? I would start disconnecting the line and blow them out to make sure you dont have a clog. If any stop leak was used it tends to crystalize when it has contact with air. I would make sure your condensor, drier, and lines at least have a clear path.
  9. Sep 8, 2016 at 9:54 AM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    Left for work today and it was under 70 degrees. Got a little excited that summer is leaving. Lol
    SKULLY and MadTaco461 like this.
  10. Sep 8, 2016 at 11:01 AM
    anthony250f
    Anthony
    San Diego, CA
    I will try that. I don't have a vacuum or manifolds anymore though lol
    I've replaced both lines off the conpressor, the conpressor, and the drier
    Never used any of that stuff
    Shrader valve are brand bew
  11. Sep 8, 2016 at 12:10 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Valley powder coating in East County. They're right off of Old 80
  12. Sep 8, 2016 at 2:55 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I want to thank Jason, 'Speed Freek' for doing my conversion to synthetic oil today, great job!
    Leaving in the morning with 3 other 4x4 Toyotas on an 11 day, 1,700 mile expedition. I just wanted everything up to speed in my 2010 Tacoma.
    New spark plugs (NGK)
    New Gear oil in the diffs and transfer case (Mobil 1, 75-90)
    New ATF synthetic in the tranny
    New synthetic oil in the engine (5W-40)
    Speed Freek[OP] and Drainbung like this.
  13. Sep 8, 2016 at 11:46 PM
    Spvrtan
    Kris
    Anyone know of quality shops in SD that can tear down the front suspension and do ICON coilover rebuilds in a day (broken seal and swapping in higher rated KING springs)? I don't have any spare coilovers that'll work with my drop-bracket lift kit so I can take the coilovers and send them into a shop for rebuilding (eg. DSM).
  14. Sep 8, 2016 at 11:50 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Try Jason @speedfreek. He is independent and works in Vista from his home. He does great work and can usually do any job within a few hours.
  15. Sep 9, 2016 at 2:02 AM
    Spvrtan
    Kris
    I thought Jason couldn't do ICONs?
  16. Sep 9, 2016 at 6:14 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Hmmm... Wasn't aware of that.
  17. Sep 9, 2016 at 7:36 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Just buy ADS haha
  18. Sep 9, 2016 at 7:50 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I brought a set of Icon shocks to ORW, they had it done in a day. Granted they ordered the wrong seal kit, I had to buy that from DSM. The whole time the guy behind the counter bascially bashed Icon and was stroking Fox which was pretty annoying.
    Not sure if I'd take them there again because of their counter people, but if you need it done in a day they can do it and they're not leaking so there's that.
  19. Sep 9, 2016 at 7:57 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    The Truck Shop in Miramar area is a quality shop. You should check them out.
    YotaGurlIAm and eccracer104 like this.
  20. Sep 9, 2016 at 8:03 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I called them first when I had mine rebuilt, they don't stock the rebuild kits and have "a wall of seals we can just match up the size". Realistically that would be just as good, I just wanted to use Icon parts in the Icons. But they can do it in a day if I remember correctly. Great pricing as well :thumbsup:
    sdsurfer[QUOTED] likes this.
