San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Mar 28, 2017 at 6:36 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    :wave::pccoffee: Morning TW peeps...
    Byb127 and eccracer104 like this.
  2. Mar 28, 2017 at 6:39 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
  3. Mar 28, 2017 at 7:39 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    :pccoffee: Good morning :wave:
    anthony250f, sdsurfer and Byb127 like this.
  4. Mar 28, 2017 at 10:24 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    :pccoffee: pass some of that coffee for me.
    eccracer104 likes this.
  5. Mar 28, 2017 at 10:40 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Seriously. Today is one of those days for sure
  6. Mar 28, 2017 at 12:40 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I'd rather be in Baja! San Felipe 250 race is this weekend...
    Speed Freek[OP], MadTaco461 and erice like this.
  7. Mar 28, 2017 at 3:42 PM
    MadTaco461
    CA
    Kinda stock
    Those whoops are huge.
  8. Mar 28, 2017 at 3:52 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    They are no joke and for the most part there isn't a good rhythm to them either, they are just brutal on your truck. A stock 2nd gen will get high centered in the big ones if you go nice and slow.
    MadTaco461[QUOTED] likes this.
  9. Mar 29, 2017 at 11:08 AM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Anyone know of any reliable shops that have experience in regearing the newer Toyotas? I'll be going to 40s on 20s soon and the next mod right after that is regearing to 4.88 with a rear air locker. I know Jason can do a rear gear/locker install but he said he wouldn't be able to do the front clamshell-style diff.
    Speed Freek[OP] likes this.
  10. Mar 29, 2017 at 12:41 PM
    MadTaco461
    CA
    Kinda stock
    The next most reliable place I know of is Yotamasters in corona. Bit of a trek from San Diego though.
  11. Mar 29, 2017 at 12:44 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    You might be able to ask James at The Truck Shop if he can do that. They've been reliable for the work I've had done.
    edit: Do NOT go there for diffs.
  12. Mar 29, 2017 at 1:07 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Avoid at all costs. I've had 2 separate friends get Diffs setup there and both times they've been set up incorrectly
  13. Mar 29, 2017 at 1:08 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Shit, I had no idea. Thanks for letting us know.
  14. Mar 29, 2017 at 1:10 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    ^^^^^^^^this guy gets it. Sad to say, I had lots of customers that have came to me after having unfortunate experiences with the truck shop.
  15. Mar 29, 2017 at 2:56 PM
    Spvrtan
    Kris
    Yea, I went there for an alignment and they couldn't get it done right. Went to an Express Tire and they dialed in my alignment perfectly.
  16. Mar 29, 2017 at 3:18 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Try them on a dirtbike at 40mph, farking horrible!!! I got that section in 2008 and it was miserable....relentless.
    Yep, I took one apart and was gonna do gears and the only way to measure backlash is to reassemble the entire clamshell in order to check. Terrible design IMO, but Im not an engineer soooo. If I had my own 4x4 I would do my own just to practice, no joke. I just dont want to do a customers and have any issues, I am 99% sure I can do it but that 1% makes me worried...
    I have taken one apart and didnt feel comfortable so I reassembled it. If it was my own truck I would go for it!
    I have one on a current build I need to do right now as well. I have a local driveline shop that does the fronts for me, maybe I will hang out and watch them, that would be a smart idea actually.
    Yep, you and me both man. When James was doing everything all was well. I have the same issue, so much work Im slammed all the time, but thats because of the work I do, not employees, been there done that, over it. Hard to have employees that will do the same as you will when it comes to detail!
    2000man and YotaGurlIAm like this.
  17. Mar 29, 2017 at 3:23 PM
    Spvrtan
    Kris
    What local shop do you go for the fronts? Maybe I can hit you up for the rear and have them do the front. Also, what if I could get a hold of a front diff from a parts recycling yard. Could you work on that for however long you need and then just plop that onto my truck when it's ready?
  18. Mar 29, 2017 at 3:26 PM
    jeffz0rz
    san diego
    I want to say there's some sort of tool you need to split the clamshell third member on the front. I can't remember exactly.
  19. Mar 29, 2017 at 4:13 PM
    Speed Freek
    ECGS sells fully assembled diffs and then you send your core back, they are probably the best in the country if you have a bit of time.
    I had Oceanside Driveline do some for me way back, and they were solid. Like I said I have one needing to be done (actually 3 if you count the 2 waiting!) so I am going to call and check to make sure they still have a tech that can do them as they are not your typical 3rd members...or you could just put a used one in after the shop builds the diff like you said.
    They are an interference fit so yeah they dont just fall apart, its also a MFer to measure the backlash as you cant really put a regular dial caliper on them to check backlash (you would need a super long tipped dial indicator) and need a way to lock the carrier as not to mess with your measurement. I saw some videos but it was super redneck "wing it" type of stuff trying to get the backlash right. But one could measure it on the pinion flange before and just match it afterward (or a bit tighter actually since new will wear in a bit), but thats not the right way to do it.
  20. Mar 29, 2017 at 4:59 PM
    Speed Freek
    Poor little car getting blown away by a class 1! Are they using Powerline rd this year? Looks like it..
