San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. May 4, 2017 at 9:39 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    How to store back the last few days and last night it locked up on me. Went to the emergency room since Urgent Care was closed and I was there for seven hours. Got loaded up on oxycodone Valium and some other bullshit. These pain meds make me absolutely sick as fuck. Not even worth the ride. I have so much fucking work today and this throwing my back out is ruining everything
  2. May 4, 2017 at 10:56 AM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Holy crap man, that's not good. I'm dealing with shoulder/neck pain from past injuries/accidents. Take care of yourself and I'll bug you later about my "plans" for my truck. I'm in no rush and keep going back and forth with my setup anyway.
  3. May 5, 2017 at 8:18 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
  4. May 5, 2017 at 9:04 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Sounds like a King snake which are awesome... But if those are around then it might be hunting rattlers.
  5. May 5, 2017 at 9:33 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yes you are correct, the only reason I do it is because I can leave it in longer without replacing it since my truck has never even gotten close to heating up even though it has a V8 swap, but also has a large twin pass style aluminum trailer (once drove 3.5 hours with NO fans since they failed and was pulling a trailer that weighs about 3000# loaded.
    However in contrast I run about 25% coolant/75% de-ionized water, since it does need a higher boiling point and also a high pressure rad cap.
  6. May 5, 2017 at 10:10 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    @synergy10 I got the bed drawer installed last night, pretty stoked.
  7. May 5, 2017 at 10:41 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Jason 'Speed Freek' performed a flawless radiator fluid change... once the frozen drain valve (apparently tightened with Thor's hammer) was loosened!
    An adjustment to the amount of fluid needed might be noted... It was slightly less than a gallon, not two gallons to replace what drained out.
    A huge thank you as well for the new skid plate install. My factory plate (plate is a poor name as it is barely thicker than a beer can) was very dinged up after 7 years of Baja adventures on less the good roads.
    Jason also performed a safety check to help me feel comfortable on my next Baja outing, or just a drive down Highway 78 near home!
    Thank you Jason!
    PS, it was nice to see Tyler (socalduckslayer) again, who popped by.
  8. May 5, 2017 at 10:52 AM
    synergy10
    San Diego
    That came out clean! I like it! Might have to copy you and @jberry813 on this one. Thanks for the pics and info.
  9. May 6, 2017 at 11:05 AM
    Speed Freek
    Came out great.
    Glad I could help, have fun in Baja, and elsewhere for that matter!
  10. May 6, 2017 at 11:24 AM
    David K
    I am glad you are there!
  11. May 6, 2017 at 2:41 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Can anyone local use a front factory skid? Replaced mine and it's just taking up space so a decent 6-pack and it's yours :)
    2000man and eccracer104 like this.
  12. May 8, 2017 at 3:05 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Anybody want to adopt a 1yr 2 month old pup? The lady thinks he needs to stay in Socal due to the heat as we move to Tucson .
  13. May 8, 2017 at 3:17 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Damn... I wish we had the room for a dog. Best of luck finding a good home :thumbsup:
    2000man likes this.
  14. May 8, 2017 at 3:21 PM
    Hoangde
    Hoangde Well-Known Member
    Oop, too bad...
    I am looking for a male Chihuahua.
    Have a female Chihuahua at home and she is lonely.
  15. May 8, 2017 at 3:51 PM
    David K
    There are lots of dogs in Tucson plus they have AC in all homes and apartments there.
    TC yota and nfs257 like this.
  16. May 8, 2017 at 3:52 PM
    nfs257
    DFW
    She gone
    That's what I'm pushing but she is also pregnant and a little stubborn. I'm really hoping to keep him.
  17. May 8, 2017 at 6:23 PM
    2000man
    2000man The Church Of @ODNAREM San Diego Chapter 1904
    G
    SDMF CA
    Shadow 4x4
    Old school!!! Free!!!
    Need to swap out the woofer but it worked! Probably good for an Access Cab!
    Speed Freek[OP] likes this.
  18. May 8, 2017 at 6:48 PM
    2000man
    G
    SDMF CA
    Shadow 4x4
    Thanks Tom for the mid skid plate!!!
  19. May 8, 2017 at 6:50 PM
    Tombiology70
    San Diego
    Glad it worked out- have you rechecked the bolts yet?
  20. May 8, 2017 at 6:54 PM
    2000man
    G
    SDMF CA
    Shadow 4x4
    Umm not yet! :eek: Going out there now!!!
    eccracer104 likes this.
