San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Jun 14, 2017 at 10:20 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    What is the tool? Isn't it just a spacer?
  2. Jun 14, 2017 at 10:27 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    He did mine.
  3. Jun 14, 2017 at 10:29 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    A little more involved from the videos I've seen. ECGS sells a couple tools, one for removal and another for install but I realized that it's something that would probably be better left to the pros...
  4. Jun 15, 2017 at 11:41 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Its a special removal tool, and to install its a bearing race installer, I have one modified to fit perfectly.
    The removal is the more difficult part..
    Tombiology70, Drainbung and sdsurfer like this.
  5. Jun 15, 2017 at 9:27 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    If anyone knows of a 2010 to 2015 tacoma double cab 4x4, please let me know! Been searching high and low with no luck.
  6. Jun 15, 2017 at 9:59 PM
    Tombiology70
    San Diego
    Hey turns out I'm a freaking moron- I bought my Kings used and turns out the set I ended up getting were the extended travel with the 650# springs.
  7. Jun 16, 2017 at 4:26 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    :pccoffee:
    Whats one of the benefits of an extened front coilover? More travel? Also whats compression adjuster? .
    I was looking into suspension and hopefully by blackfriday i have enough saved :) for stage 2
    . So i have the next 5 months to save.2,500 and hope there is a super duper good deal. But that means saving 500 a month :/ i may have to brown bag the beer meets if im serious about this lol. I can spend 40 easy on food and beer each meet. :/
    Maggot61 and eccracer104 like this.
  8. Jun 16, 2017 at 7:50 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Extended travel needs aftermarket UCAs to take advantage of the "extended travel" and it's another 1/2 inch or 3/4 inch of travel over the "standard travel" option.
    I think you were looking at fox, fox has a dual speed compression adjuster for high and low speed. It allows you to fine tune how the coilovers react over bumps. You can make it softer/stiffer and slower/faster to your liking. It's a really cool feature IF you know how to use it. I have adjusters on mine and never touched them. To really yield a benefit you need to run the same section over and over again to feel the changes from making adjustments. Once you have it set up it'll be better than the same foxs without them.
  9. Jun 16, 2017 at 7:54 AM
    Hagendazsss
    San Diego, CA
    Nice thanks mike.
    i was planning to get spc uca anyways but for 3/4 " may not be worth it not sure yet.
    And that makes sense with the adjustments however i dont think i would every try to mess with that. I have tried messing with compression settings on my mountain bike before and... yeah i messed it all up.
  10. Jun 16, 2017 at 8:16 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    :rofl: yes very similar to the suspension on a bike. I have the adjusters on my Icons, but honestly haven't even touched them. It would be cool to mess with the settings and see how it changes things, but I don't re-run the same section to feel the changes.
    Hagendazsss[QUOTED] likes this.
  11. Jun 16, 2017 at 10:37 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Adjusters are fun. You can notice out in the desert actually. If we do some desert runs this fall /winter you can run a section over while making changes
  12. Jun 16, 2017 at 11:17 AM
    Speed Freek
    Get the extended version, but get UCAs like mentioned, DO IT! And having compression adjusters are very nice to have, get those too.
    eccracer104 and MadTaco461 like this.
  13. Jun 16, 2017 at 11:20 AM
    Hagendazsss
    San Diego, CA
  14. Jun 16, 2017 at 11:21 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Pssshhh, I know of a mall we can test those bad boys out on.
  15. Jun 16, 2017 at 11:21 AM
    MadTaco461
    CA
    Kinda stock
  16. Jun 16, 2017 at 11:26 AM
    Hagendazsss
    San Diego, CA
  17. Jun 16, 2017 at 11:28 AM
    Speed Freek
  18. Jun 16, 2017 at 11:33 AM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
  19. Jun 16, 2017 at 11:34 AM
    Hagendazsss
    San Diego, CA
    MadTaco461[QUOTED] likes this.
  20. Jun 16, 2017 at 11:39 AM
    MadTaco461
    CA
    Kinda stock
    :rofl::bikewhoops:
