San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Jul 31, 2017 at 12:05 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
  2. Jul 31, 2017 at 12:14 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Just carry this and a roll of shop towels and you're good. Clean it out with the shop towel then lube with the tri-flow lubricant.
  3. Jul 31, 2017 at 12:34 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I lube my when they start squeaking. Maybe once a month? Takes 1 minute to do both sides, just some tri-flow dry lube. I apply when I park at home so it can sit and soak all night.
    This stuff -
    Uniball is more expensive so that's one reason why people go ball joint. Ball joint also correct alignment, so for those that aren't wheeling too hard ball joint is just fine.
    You have those exceptions like Danny who wheels the fuck out of his 4runner and by some miracle his ball joints haven't failed.
  4. Jul 31, 2017 at 12:42 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Uniball make it harder for alignment? Not sure what you mean by ball joint correct alignment.
  5. Jul 31, 2017 at 12:45 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Sorry, when you lift your truck you throw the suspension geometry out of whack. The stock UCAs can't handle it so you can't get into proper alignment specs. The ball joint upper control arms and uniball type will both fix that. For some the ball joint fix the issue and are a cheaper option, uniball is overkill for them. If you plan on wheeling the truck uniball is a better option, but more expensive. Also some that live in salt prefer the ball joint as they're less exposed and for them it will last longer. In ca obviously not an issue, but figured I'd mention it.
    If you can score a great deal on ball joint UCAs, they're a solid option, but the uniball are stronger, offer better articulation, correct alignment, and will allow you the full length of travel from extended travel coilovers.
  6. Jul 31, 2017 at 2:08 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Those BJ that camburg uses have a pretty surprising amount of articulation. 36 degrees is pretty good.
    ItsRichieRich likes this.
  7. Jul 31, 2017 at 3:29 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
  8. Jul 31, 2017 at 6:42 PM
    bigbarlo
    bigbarlo The Church of @ODNAREM OC Chapter 80085
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
  9. Jul 31, 2017 at 9:06 PM
    tcjacado
    tcjacado Well-Known Member
    @Gamma this is your local thread
  10. Aug 1, 2017 at 4:00 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
  11. Aug 1, 2017 at 9:36 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    See ya boys and girls when I get back, Vegas then maybe Havasu!
    Going to meet up with my wife's Sister from Switzerland and were going on a short tour, and since there will be 3 girls I have a suspicion that they will want to shop!!
    Well since we will be in Vegas don't be surprised if I disappear and come back accidentally hammered, what happens in Vegas...
    Hope you all have a great weekend!!
    Oh and I still have a bunch of stuff I need to get rid of soon, Ill post up more pics when I get back, somebody wants this stuff damnit, lol.
  12. Aug 1, 2017 at 9:42 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    FIFY :drunk:
    Have a fun trip Jason! :thumbsup:
    I'll pick up those parts when you get back, or when we all come up to help you move. Whatever works for me, you're not far.
  13. Aug 2, 2017 at 1:04 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Does anyone happen to have the Ballistic tool to tighten rod ends?? I'll drive anywhere in San Diego to get one haha. Don't want to wait for shipping and need it asap
  14. Aug 2, 2017 at 1:45 PM
    MadTaco461
    CA
    Kinda stock
    Best bet is probably calling up fab shops that make/work on hard core rock rigs.
  15. Aug 2, 2017 at 1:56 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I just decided to make one. Took 45 minutes.
    Thanks though!
  16. Aug 2, 2017 at 2:02 PM
    MadTaco461
    CA
    Kinda stock
    That was going to be my next recommendation,lol. Most of my specialty tools I made from stuff around the house.
    tcjacado likes this.
  17. Aug 2, 2017 at 2:03 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    It's probably the ugliest tool I've ever made hahaha but free is better than $45
  18. Aug 3, 2017 at 12:08 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    This fit a lot better than I expected! There's plenty of clearance behind the grill. I just need to figure out the top mounting arms for the bracket itself and then these two 12" pusher fans are going live. I didn't mount them onto the frontmost cooler itself because these wouldn't fit at 12" in size; plus, the mounting kit that comes with them goes between the fins of the coolers and I don't want all that weight hanging off of them. The purpose of these fans are for slow-moving trail runs where there isn't even speed or wind to optimize the flow of air to the coolers -- I read somewhere it was ~7mph but I could be wrong -- and will be nice in stop and go traffic. The fans will be toggled via a switch in the cab.
  19. Aug 3, 2017 at 9:21 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Any 2a guys or gals looking for a rifle scope? Selling my Vortex Strike Eagle 1-6x24 with Aero Precision lightweight mount. Basically just sighted it in, then shot another 30 rounds after. Collecting dust for the last 8 months. $350 obo IMG_6688.jpgIMG_6690.jpgIMG_6695.jpgIMG_5766.jpg
  20. Aug 3, 2017 at 9:58 PM
    climbhigher23
    climbhigher23 Well-Known Member
    SoCal
    2017 QS TRD Off-Road 4x4
    2.5" King w/Adj 285/70/17 Wildpeaks Ray 10's
    Not a bad deal.
    If I had some extra cash I'd take it
