San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Aug 14, 2017 at 12:49 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Has anyone riden Lake Elsinore MX track? I'm going tomorrow but have never been there if anyone wants to join.
    Forecast shows it being partly cloudy 70-77 degrees with very little wind in the morning.
  2. Aug 14, 2017 at 2:08 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    It's fun. Kinda slick when wet. It's dry lake bed dirt.
  3. Aug 14, 2017 at 2:25 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Hopefully the cloud cover will keep it damp enough that they don't water the blue groove.
    tcjacado and MadTaco461[QUOTED] like this.
  4. Aug 14, 2017 at 4:33 PM
    MadTaco461
    CA
    Kinda stock
    The hose isn't bad just the water truck. Give it half hour after the water truck to let the track dry out. Should be great weather. Probably low 80 s
  5. Aug 14, 2017 at 4:39 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Oh yeah. Perfect time to try and shake off the horrendous amount of arm pump I'll have :laughing:
  6. Aug 14, 2017 at 4:56 PM
    MadTaco461
    CA
    Kinda stock
    You'll have arm pump for sure.
    eccracer104[QUOTED] likes this.
  7. Aug 14, 2017 at 7:46 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
  8. Aug 15, 2017 at 8:50 AM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    GOOOD MORNING MY NINJAS!
    I'm really not that excited, figured I'd get the energy flowing through in this thread.
    tcjacado and eccracer104 like this.
  9. Aug 15, 2017 at 9:33 AM
    synergy10
    San Diego
    Morning!
    eccracer104 likes this.
  10. Aug 15, 2017 at 11:31 AM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Totally random question.. is it possible to run a welder off a stock and/or auxiliary battery with a powerful enough inverter?
  11. Aug 15, 2017 at 11:46 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    It's a redundant setup. Your converting DC voltage (battery) to a AC voltage steuped up to 120VAC at 60 hertz (Inverter). Then connecting a welder that is stepping down the 120VAC to 25VAC and then rectified back to DC voltage at 25VDC so you can weld.
    If you want to have welding capabilities on the trail, then run directly off the battery and avoid all the loss due to thermal dynamics. You would need two batteries in series to have 24VDC, this will get you up to 250 amps of output. I carry the readywelder.
    https://www.amazon.com/Ready-Welder-10000-Battery-Operated/dp/B004N31LUI
  12. Aug 15, 2017 at 11:48 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    ^^^ is the man to answer that.
  13. Aug 15, 2017 at 11:49 AM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    What's a good portable air compressor that you guys run? I'm not looking for one that needs to air up 37" tires (Right now I am running stock, I might move up to 285/70/17). Looking for one that is of great value. Don't need the best one, just need one that works.
  14. Aug 15, 2017 at 12:05 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Viar 0088 (I think). You can find it on Amazon.
  15. Aug 15, 2017 at 12:15 PM
    Spvrtan
    Kris
    Thanks for the info! So I have a triple-battery setup in my Tundra. The 2 auxiliary batteries (Odyssey PC1500) are wired in parallel as one and are mounted in the bed. If I ran a welder directly off of that, I'd get roughly a few minutes of total weld time in?
  16. Aug 15, 2017 at 12:18 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    You should be about to get 20 minutes before you will need to recharge the battery. Enough time to fix a link or a mount.
  17. Aug 15, 2017 at 12:34 PM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
  18. Aug 15, 2017 at 2:22 PM
    synergy10
    San Diego
    That looks familiar. A guy I wheeled with aired up with one of those and it seemed to out perform mine: https://www.amazon.com/Master-Flow-...id=1502831798&sr=1-33&keywords=air+compressor
    I'm leaning towards onboard air but may just get a better portable one later.
    In other news...I know it's a long shot but does anyone on here have hookups for OEM Honda parts??? I don't frequent the Honda forums as much, if at all, anymore.
  19. Aug 15, 2017 at 2:39 PM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    What are you looking for?
  20. Aug 15, 2017 at 2:43 PM
    synergy10
    San Diego
    98 Accord LX V6 Coupe w/ Auto trans:
    -Radiator
    -Upper radiator hose
    -Lower radiator hose
