San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Sep 12, 2017 at 3:52 PM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    16's :headbang:
    just cause i've got 16's :anonymous:
    ItsRichieRich[QUOTED] likes this.
  2. Sep 12, 2017 at 3:55 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    16s and I have 17s now
  3. Sep 12, 2017 at 3:56 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    20's
    It comes down to personal preference. Rubber for 16's is cheaper.
    tcjacado and ItsRichieRich like this.
  4. Sep 12, 2017 at 4:06 PM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Por que?
    tcjacado likes this.
  5. Sep 12, 2017 at 4:07 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    17s so you can upgrade your brakes down the road with no clearance issues
  6. Sep 12, 2017 at 4:08 PM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    I was thinking of going 17s and rock 285/70-17 but that might cause a lot of rubbing? Not too sure what size wheels to get.
  7. Sep 12, 2017 at 4:17 PM
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    Yes, If staying in No. County, then Crossings at Carlsbad or Encinitas Ranch. Very nice courses and not too much. TP is a PIA to get a tee time.
    uhplifted[QUOTED] likes this.
  8. Sep 12, 2017 at 4:23 PM
    climbhigher23
    climbhigher23 Well-Known Member
    SoCal
    2017 QS TRD Off-Road 4x4
    2.5" King w/Adj 285/70/17 Wildpeaks Ray 10's
    CMC
  9. Sep 12, 2017 at 4:24 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Don't worry about rubbing, you want bigger tires. You can cure rubbing by cutting and trimming. Either 16" or 17" will be a good choice. 17" if you want to upgrade to 4runner brakes down the road. 16" if you want to save a little $$$
  10. Sep 12, 2017 at 6:43 PM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Man, 17s it is then huh? Bigger brakes and better brakes does sound exciting since I'm known for my late braking ;)
    nfs257 and tcjacado like this.
  11. Sep 12, 2017 at 6:52 PM
    Falldownhard
    Falldownhard @tacomavanzandt
    Evan
    San Diego
    2015 Toyota Tacoma TRD Off Road 4x4
    Things and Stuff.
    I'm running that tire size, I've noticed very little rubbing. but thats due to the CMC. Its mostly when i turn into driveways a little fast do I rub. Will be having some more trimming done to help out.
    Speed Freek[OP] likes this.
  12. Sep 12, 2017 at 6:53 PM
    tcjacado
    tcjacado Well-Known Member
    Lol. You ain't kidding!:eek:
  13. Sep 12, 2017 at 6:55 PM
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    LOL!
  14. Sep 12, 2017 at 6:57 PM
    tcjacado
    I really want a back bumper but not at your expense. Lol
  15. Sep 14, 2017 at 6:19 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Testing..
    Pluto, the Tundra
    Built by Spvrtan and last updated pluto
    #toyota #tundra #overland #4x4 #supercharged #40s #trd #black
    I started this build in late 2014 with the vision of creating an all-around capable adventure rig
    View build page:
    http://buildprint.io/b/pluto
    Mods
    Wheels
    Method Double Standards (Removed)
    18x9 and painted white with blue accents
    Method Double Standards (Done)
    17x8.5 and painted dark gray
    Tires
    BFGoodrich KM2s (Removed)
    My first set lasted over 40k miles!
    Mickey Thompson MTZ P3s (Done)
    40x13.5
    Goodyear Wrangler MT/R w/ Kevlar (Planned)
    42x14.5
    Performance
    TRD performance dual exhaust system (Done)
    SDHQ secondary air injection pump i (Done)
    TRD supercharger (Done)
    Got this installed a few months before Toyota announced they were discontinuing the supercharger program (even though they were always made by Magnusson).
    Drivetrain
    Air locker (Planned)
    Going with an air-actuated locker for the rear differential
    4.88 gears (Planned)
    Probably going to go with Nitro's ring and pinion for both differentials
    Spidertrax wheel spacers (Done)
    Adds 1.25" at each corner
    Suspension
    BDS 7" bracket lift (Done)
    Atlas 4.5" leaf packs (Done)
    Expedition-style
    ICON front coilovers (Done)
    Large-lifted application variation with remote reservoirs and CDC valves
    KING coilover springs (Done)
    Rated at 800lb
    ICON rear shocks (Done)
    Large-lifted application variation with piggybacks and bypasses
    Coachbuilder tie-rod ends (Done)
    These help to correct some of the angles the bracket lift pushes on the steering rack
    Coachbuilder +3 shackles (Removed)
    About 3" longer from bolt-to-bolt, which increases the rear height about 1.65"
    Custom +5 shackles (Done)
    Armor
    Relentless Fab front bumper (Done)
    Defender version; steel
    White Knuckle Off Road sliders (Done)
    3/16"-walled outer tube
    BudBuilt gas tank skid (Done)
    Made of 3/16" stainless steel
    ARB rear diff breather (Done)
    Relocated stock breather up behind taillight
    SDHQ ABS skids (Done)
    Lighting
    Spyder projector headlights (black) (Done)
    Spyder LED taillights (black) (Done)
    4 x Rigid Industries Duallys (Done)
    2 x Baja Designs Squadron XL Pro (Done)
    Mounted on the A-pillar
    6 x KC HiLiTES Daylighter (LEDs) (Done)
    Mounted on the roof rack
    Exterior
    RKSport ram air hood (Done)
    Fiberglass construction with functional scoop and heat vents
    EAG Viscious grill (Done)
    Matte black
    Cosmetic
    Debadged OEM chrome emblems (Done)
    Electrical
    Artec battery tray (Done)
    Recovery
    ARB air compressor (Done)
    Twin motor high-performance portable air compressor
    Warn winch (Done)
    ZEON Platinum 12k with synthetic line
    TRED Pro (Done)
    ARB static rope (Done)
    2-3/8" x 30' strap (17,500lbs capacity)
    ARB tree saver (Done)
    3" x 10' strap (26,500lbs capacity)
    Safety
    Fire extinguisher (Done)
    Drake Offroad extinguisher mount (Done)
    Storage
    Lock'er Down center console box (Done)
    Utility
    Cooler/fridge tray (Testing)
    Replaced the short seat in the rear!
    Custom bed rack (Done)
    Aluminum material (~45lbs); built by Pelfreybilt
    Gobi Ranger roof rack (Done)
    Bed & tailgate Line-X'd (Done)
    24-gallon water system (Progress)
    Dee Zee "heavyweight" bed mat (Done)
    Logs
    Other
    Pluto's first log entry (2017-09-11 09:16:22)
    Build info exported via Buildprint
  16. Sep 14, 2017 at 6:49 PM
    climbhigher23
    SoCal
    Helluva rig
  17. Sep 14, 2017 at 8:50 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    needs a rear bumper.
    Tacofart and eccracer104 like this.
  18. Sep 14, 2017 at 9:07 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    MadTaco461 and Prayn4surf like this.
  19. Sep 14, 2017 at 9:11 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  20. Sep 14, 2017 at 11:11 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
