San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Apr 25, 2018 at 11:26 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Started on the corners for the rear bumper. These bases are pure beef (ie. 2x6 and 3/16"); going to add upward-angled tube for rub bars.
  2. Apr 26, 2018 at 6:42 AM
    DangerClose
    DangerClose Well-Known Member
    2014 TRD Sport DCSB / 2001 SR5 4X4 XC
    Do you still need help with your chain link fence?
  3. Apr 26, 2018 at 5:34 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Yes I do for sure! I ran a small Case bucket/loader and cut a path through everything but one side last night (that part is going to take some work to get through as the neighbor has been dumping palms and random trees over the fence for years!) But I have a chainsaw so I can make a path through that with a little help however, so no worries there.
    Been beyond busy with work so I havent gotten as far as I would like to by now. But I have the corners marked so I just need to run a stringline and mark the spots 10' O.C. and use my new auger to make some holes and plant the posts.
    I sprained my L. wrist about 2 months ago (didnt think much of it) and now I have really bad carpal tunnel on my left arm/wrist, since started favoring it and using my right hand way more so now its its getting it too, pretty much because everything I tend to do generally requires what equates to a retard-strength grip :rofl:
    So in short, yes absolutely I do! I would be super pumped on any help I can get! I already have about 150' of poles ran that I need to hang the fence up on so far and another 100' of poles that are now a mistake after changing the plan of where the gate will be, oops! Hindsight is 20/20....o_O
  4. Apr 28, 2018 at 8:51 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    If you are interested in it, I can make you a screaming deal on a DJM UCA kit for a Tacoma. I bought it lightly used about 10 years ago and never installed it, sold my 5 lug 1st gen a few years ago so I have no use for it.
    Doesn't help with the bushings for the lowers (5lug parts are a PITA to search for on line) but it is something.
    You can basically have it in exchange for future labor (I don't need anything right now but I am sure I could use a hand with something eventually). Would rather see it put to use then taking up space, I am trying to do some spring cleaning and pare down the hoard of toyota stuff.
    Glad you were able to get past the issues with the code enforcement and crazy neighbor and are moving forward with your shop.
    After starting the process on mine over a year ago, groundbreaking was 2 weeks ago. Foundations are being poured on Monday I can't wait...
  5. Apr 28, 2018 at 9:21 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    If and when youre gonna hang the fence I can swing up there and lend a hand. Looks like youve come a long way since we worked on some beer n mexican food last year lol Good work man!
    Drainbung and eccracer104 like this.
  6. Apr 28, 2018 at 10:47 AM
    Speed Freek
    Awesome, Yeah that would be great, I was looking to replace the uppers too, the popping sound is still there so The uppers are next on the list!
    And your pad looks great! Looks like it happening now! Stoked for you!
    I'm currently doing some dirt work and adding that perimeter fence, next up is some more concrete slab in front and behind he shop then Ill get the lifts put it as well as build my roof.
    Sweet, thanks! Yeah quite a bit has changed, I've been working my ass off every chance I get as usual...I went out and got the first corner pole set yesterday afternoon and bought all the corner poles. Today my plan is to try and set as many poles as I can solo since I havent had anyone to help yet, starting with the other corners so I can set some string lines up to mark the holes.
    And holy hell that posthole auger makes quick work of the holes!!! I love that thing!! Now that I own it I done have to worry about having to return it...
    I can definitely use some help this weekend if anybody has time. Im probably going to be doing all this by myself, with my wife helping, but shes quite the trooper, lol. Ill be out there in a little bit after some food and digging holes.
    I spent about an hour clearing all the Poison vines out from that area dressed like Indiana Jones trying to cover my entire body, lol. But got it all cleared away from where I need to work, those Poison Oak vines must have been 5+ years old! A couple of them were about 2" in diameter and going 30' up into the Oak Trees!!
  7. Apr 28, 2018 at 10:49 AM
    Speed Freek
    I need to cruise by and check it out, I would love to see how you are doing everything!
    Drainbung and Falldownhard like this.
  8. Apr 28, 2018 at 11:06 AM
    Prayn4surf
    Socal
    I cant today but I can swing by and help tomorrow for a couple hours. Gonna try and clear half my garage today. Setting posts is a 2 person job. If you set your lines today and get the holes augered we can pull out the dirt and start setting posts tomorrow. You have concrete ret to go I assume?
  9. Apr 28, 2018 at 12:06 PM
    Speed Freek
    Yes I’m planning on have the corners done, stringline, mark holes with paint.
    I have about 15 poles so I’m gonna get more and a pallet of concrete today at some point.
    I have about 10 bags of concrete on hand at the moment but I’ll get more.
    Thanks for that bud, that would really help!
  10. Apr 28, 2018 at 12:09 PM
    Speed Freek
    So here is Bobs @Drainbung gears That I swapped for him!
    Forgot to take pics of the front. Oops!
    5C3EB242-B328-4641-B354-21CCBDFD9BC4.jpg 4DB7EA47-AA7F-4D31-9CBB-1B678C855B0C.jpg
  11. Apr 28, 2018 at 12:40 PM
    Richie Rich
    760 (San Diego)
    Likewise. I would love to check out your shop build too. Lemme see if I can dig that DJM kit out of storage (I last saw it a year or two ago) and we can meet up.
    Basically this is what my shop is going to look like (had to teach myself Sketchup to do this).
    taco 16, tcjacado, 2000man and 3 others like this.
  12. Apr 28, 2018 at 12:43 PM
    Speed Freek
    Wow, great layout!! Thats going to be absolutely awesome!
    Cool just let me know and I'd be down to meet foe sure.
    Richie Rich[QUOTED] likes this.
  13. Apr 28, 2018 at 1:29 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    I can probably lend a hand tomorrow afternoon, What time you thinking of cruising up?
    Speed Freek[OP] likes this.
  14. Apr 28, 2018 at 1:31 PM
    Prayn4surf
    Socal
    I would say morning before it gets too hot. I have to pack tomorrow afternoon as I am leaving monday. But could work 9:30 to 1
  15. Apr 28, 2018 at 5:46 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Sweet, I'll give you a shout tomorrow (Sunday) and swing by at some point to pick it up. I can help you after work this week for sure. I get off at 4 and can be at your place by 4:30 so we'll have plenty of daylight.
  16. Apr 28, 2018 at 7:13 PM
    Speed Freek
    So me and the wife measured, marked, drilled, and concreted all the front poles in and the corner where the gate will be. So I’ll need help stretching about 300’ of link.
    I have stretchers and a come-along.
    So this is Poison oak right??
    eccracer104, Prayn4surf and Drainbung like this.
  17. Apr 28, 2018 at 7:23 PM
    Speed Freek
    I would be more than stoked for the help! Ill order pizza and get some beverages and whatnot. Ill do 90% of the hard stuff, no problem and thanks in advance, shoot me a text if I can get you something!
  18. Apr 28, 2018 at 7:36 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Text inbound. I'll be over in the morning.
  19. Apr 28, 2018 at 7:54 PM
    Prayn4surf
    Socal
    Cool man will be there at 9:30 am send me your addy again. @Tombiology70 you want me to grab ya?
  20. Apr 28, 2018 at 7:56 PM
    Prayn4surf
    Socal
    Looks like it...3 leaf is a dead give away...my dads imune and i dont think ive ever gotten it even when my sister got it so i think im good hahah
    Dont burn it lol
