San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Oct 17, 2018 at 11:24 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    If you’ve lost any air pressure on a sealed system you have a bad seal so a recharge will only temporarily solve the issue.
    Unless you’re just changing PSI. That’s different.
  2. Oct 17, 2018 at 11:30 AM
    desertjunkie760
    Shane
    Check My Sig.
    Yes, this is true. My statement was very generic and obviously there are exceptions.
    I interpreted the bold for my initial response.
    DangerClose likes this.
  3. Oct 17, 2018 at 11:53 AM
    desertjunkie760
    Shane
    Check My Sig.
    Is that logical or am I missing something?
  4. Oct 17, 2018 at 12:12 PM
    motodh
    motodh Well-Known Member
    San Marcos, CA (North County San Diego)
    2017 DCLB OR
    eccracer104 likes this.
  5. Oct 17, 2018 at 12:17 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  6. Oct 17, 2018 at 1:20 PM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    Yea, I got my front coilovers rebuilt a year ago but I think my rear shocks -- while I haven't seen any leaks -- could use a check on nitrogen since they haven't been maintained since I bought them.
  7. Oct 17, 2018 at 1:40 PM
    Falldownhard
    Falldownhard @tacomavanzandt
    Evan
    San Diego
    2015 Toyota Tacoma TRD Off Road 4x4
    Things and Stuff.
    @Speed Freek is your man for sure!
  8. Oct 17, 2018 at 1:55 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I never thought there would be someone less motivated than @Titus94 to work on their own truck, but here we are.
    oni06, eccracer104, itaro and 2 others like this.
  9. Oct 17, 2018 at 2:08 PM
    motodh
    2017 DCLB OR
    I would love to work on my Taco but drilling into a brand new truck frame versus rebuilding my old '85 4Runner is a different story... especially when the Taco is our daily driver for my wife and kids.
  10. Oct 17, 2018 at 2:30 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Actually, I don't think Colton has painted his sliders yet, so he's back in the lead.
  11. Oct 17, 2018 at 4:18 PM
    motodh
    2017 DCLB OR
    Any one near San Marcos (or anywhere in San Diego) with a roof top tent on their truck? I'm planning to get a RTT soon but my wife wants to see the space inside before we order one. Thanks!
    DangerClose, itaro and Tombiology70 like this.
  12. Oct 17, 2018 at 5:08 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I was just thinking that schrader valves with such high pressure will leak a bit over time, hose fittings may leak a bit over time IE: not necessarily a bad component ?
  13. Oct 17, 2018 at 5:32 PM
    motodh
    2017 DCLB OR
    That’ll be awesome to see your tent. Which model do you have? The hard sell is convincing my wife that a $1000 RTT is better than our $100 ground tent.
    itaro likes this.
  14. Oct 17, 2018 at 5:50 PM
    desertjunkie760
    Shane
    Check My Sig.
    That’s always the hard sell and $1k is a good deal for one. You have a long bed too so you can always go with the larger size like @Prayn4surf has. Not sure what model exactly.
    I guess it’s not out of the realm of possibility to loose a little pressure but I’d be willing to say most leaks that start don’t stop. Once you loose too much pressure you loose shock performance and something needs to be replaced, even if it’s just a seal.
    A hose fitting is something that can often times just be retightened if a leak starts. Assuming you’re still referring to a shock, if a leak starts in a hose you’re dealing with fluid not gas.
    More often than not, if you’ve lost gas pressure, the IFP seal is bad and the shock is emulsified and needs a rebuild, assuming their are no exterior leaks. If you just do another charge you’re just adding to the problem.
    DangerClose and motodh[QUOTED] like this.
  15. Oct 17, 2018 at 6:27 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    That's not funny, you laugh alone!
    sdsurfer and YumaTRD like this.
  16. Oct 17, 2018 at 6:34 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Put a gauge on the valve.
  17. Oct 17, 2018 at 9:16 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I thought since the volume in a shock is low, the quick loss of gas when checking with a gauge can drop ~10 psi. Most tire gauges only go to 100psi so he still needs a special gauge.
  18. Oct 17, 2018 at 10:10 PM
    h5863emtmatt
    h5863emtmatt Well-Known Member
    San Diego
    17' TRD OR 4x4 DCSB
    Method Vex311, Toyo Open Country AT, 2.0 Fox Performance Coilovers/Reservoir, Total Chaos UCA, Pelfreybilt, Prinsu Cabrac
    Let me know, going to throw my set up on soon for a desert trip. Spring Valley area
    motodh[QUOTED] likes this.
  19. Oct 17, 2018 at 10:15 PM
    motodh
    2017 DCLB OR
    It’ll be great to see your RTT. Any plans on heading up the 15 anytime soon? I’m about an hour north from Spring Valley.
  20. Oct 17, 2018 at 10:19 PM
    h5863emtmatt
    San Diego
    17' TRD OR 4x4 DCSB
    Not really. I was up the 15 headed to Cleghorn last Sunday. I’m free this Sunday Monday if you come south.
