San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Sep 15, 2019 at 12:48 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I have taken my Tacoma all over Baja (see my trip reports). This time, I was a passenger and it was nice to let someone else drive... fun with Curt LeDuc, in fact. This was a made for TV event and all Ford Raptors... I was a ride-along guide.
    OffroadThinker and Drainbung like this.
  2. Sep 16, 2019 at 9:22 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Looks like you got to have a good time David! Awesome.
    I gotta try and get me some of that fun I keep hearing about! Since I've moved I've been working like crazy, either on the property, or working on trucks. But Im making progress albeit slowly since I can only do so many things at once, lol.
    However I've been getting my desert stuff ready, just have to install airbags on the new RV (well new to me, its a 99, but better than my last one an 85', that Fker was beat!)
    Now I just gotta fix my Jeep and replace the rear gears and its set for another season of abuse. Also get some armor and other goodies for my dirtbike, as well as a new helmet (I damaged the last one in a big crash!!) and I should be ready to rock.
    Soooo ready for some desert weekends!!
  3. Sep 16, 2019 at 9:34 AM
    David K
    Be careful amigo... you aren't getting any younger, and those injuries take longer to heal the older you get!
    Speed Freek[OP] and Drainbung like this.
  4. Sep 18, 2019 at 5:41 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
  5. Sep 18, 2019 at 9:40 AM
    David K
    Oh, thank you very much!
    Speed Freek[OP] and sdsurfer like this.
  6. Sep 21, 2019 at 10:53 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Anyone got some TC washers laying around they might wanna sell?
  7. Sep 21, 2019 at 4:32 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Anyone have a detail guy in north county? Mobile or not. Need the Tundra ceramic coated and 4Runner needs a wet sand and full buff
  8. Sep 21, 2019 at 10:21 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Adonis Detail in Vista.
    Tim 760-815-5933
    He is not cheap but saved the paint on my X-runner. It was so bad I thought I was going to have to get it resprayed. He did a full correction and ceramic coat.
    Normally does exotics but does good work no matter what vehicle it is.
    Reminds me, I have to have him look at my new truck.
  9. Sep 22, 2019 at 4:09 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
  10. Sep 23, 2019 at 5:49 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Bit the bullet and got fox 2.0 f&r shocks. And probably going to go with wheelers aal. Question though. for the taco lean should i adjust preload or get a spacer? Also are bump stops necessary or is it something i can hold off on.
    erice likes this.
  11. Sep 23, 2019 at 6:50 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    What’s up Hagen!
    You still need bump stops. Stock bumps will work, but Going aftermarket like wheelers or durobumps is a nice upgrade.
    I would recommend doing a u-bolt flip if your already working on the rear leafs.
  12. Sep 23, 2019 at 7:13 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    The proper way to compensate for taco lean is to adjust the coil. A spacer will work but I wouldn't off road hard with one unless you limit your bump travel in the front.
    Bump stops for the front or rear?
  13. Sep 23, 2019 at 7:23 AM
    Hagendazsss
    San Diego, CA
    Cool i wasnt sure if adjusting the coil differently on each side would put the suspension "bounciness" out of whack
    Both bump stops i guess
    What up!
    Cool i was planning to eventually will upgrade the bumpstops but wasnt sure if it was necessary right away. But if im down there adjusting the leafs it makes sense to do it all in one shot.
    Speed Freek[OP] likes this.
  14. Sep 24, 2019 at 7:05 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Love reading people's for sale ads, "No expenses spared on this build." "Smittybuilt" " Caliraised"
  15. Sep 26, 2019 at 7:58 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Q: When does it suck to be a cop?
    A: When you get pulled over in your cruiser by another cop. LOL
    I seriously doubt that's what happened, but it's fun to think it did. ( Escondido)
  16. Sep 26, 2019 at 9:32 AM
    Hagendazsss
    San Diego, CA
    Lol. They probably still haven't cleared the scene from pulling someone else over. You can see the front cops rear emergency light on the left side of his bar. But who knows. Sometimes im hauling ass in my g ride afraid I'll get pulled over and im always on the lookout for state troopers lol
  17. Sep 26, 2019 at 11:21 AM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    can't make OT at home...ride out that shift change.
    LukeCC and Titus94 like this.
  18. Sep 26, 2019 at 11:57 AM
    Hagendazsss
    San Diego, CA
    No over time for our agency unfortunately
    LukeCC likes this.
  19. Sep 26, 2019 at 12:20 PM
    hoarder23
    Shay
    NJ
    Scratches
    Then you just fucked up
    Tombiology70 likes this.
  20. Sep 26, 2019 at 1:14 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    What? Colton & Coors Inc.?
    LukeCC, Drainbung and Titus94[QUOTED] like this.
