San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Apr 14, 2020 at 10:08 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    it cost me $15 On Amazon showed up in 24 hours...buy one bro
    Drainbung and BLKTRUCK like this.
  2. Apr 15, 2020 at 7:52 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    yeah, so we can celebrate our freedom as we are restricted in our movements and gatherings!
  3. Apr 15, 2020 at 9:04 PM
    Eastcoastin
    Eastcoastin Well-Known Member
    Oahu/San Diego
    TRD Sport DCSB 4x4 V6
    Pelfreybilt Baja Designs errythang, 20” Onyx6, S2 Sports, & Squadron Pros King 2.5 Resis w/700 springs/Rear 2.5/12" ALCAN Leaf Springs Total Chaos (Rear Relocation, UCA, spindle gussets, LCA skids) Archive Hangers/shackles Toyo 285/75/17 MTs VTX Rogues InSight RetroFits Leer x100 Camper Custom Car Grills thin lip mesh grill mod w/braptor light mod Tail pipe chop
    Anyone here have a left handed drill bit/extractor set? God apparently hates me. It’s not seized, just in there pretty good and shallow enough that I couldn’t get a good grip with the vice grips.
  4. Apr 16, 2020 at 9:11 AM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Hey John, I can probably weld a bolt over it and turn it out, shoot me a text if I can help.
  5. Apr 16, 2020 at 3:27 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    If you have a rotory you can cut a slit in the top and use a flathead. Have had to do that many times. Works like a charm.
    Sdtrueblue and CaliTaco718 like this.
  6. Apr 16, 2020 at 5:04 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Is anybody here familiar with zoning regulations in SD?
  7. Apr 19, 2020 at 11:28 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    does anyone have, or know anyone with, a sheet metal brake? I need to make one bend. mild steel sheet 4" x 7" x .130 thick.
    need to go from flat to as close to 57 degrees (acute) as possible.
  8. Apr 22, 2020 at 12:38 PM
    Speed Freek
    So do we need to make an active zombie map yet like the San Francisco's Poop maps? No reports of walking dead as of yet so I assume not.
    And @cwadej I dont have a metal brake, but HF has some pretty inexpensive ones there that will do that no problem. I just use my aluminum welding table and clamp it down to a flat piece of steel and hammer the edge after a bit of heat has been applied.
    I have a tube bender but thats obviously not gonna help for what you need...
  9. Apr 22, 2020 at 12:41 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    they look stupid on any truck other than a raptor.
  10. Apr 22, 2020 at 12:55 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    yeah, i just dont want to buy a cheap brake for a single small item, and i dont really have room for it here anyway.
  11. Apr 24, 2020 at 2:47 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
  12. Apr 24, 2020 at 3:15 PM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    The best mod!
  13. Apr 24, 2020 at 3:20 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    Cuts down on reg fee right?
    Edit: THIS is the best mod, half the cost and no smog :cool:
  14. Apr 24, 2020 at 3:35 PM
    Nomad26
    Escondido, CA
    Must be nice... :anonymous:
    I used to have a Ram registered in AZ and my Jeep in CA because I didn’t want to pay the fees here. My Jeep died and I traded the Ram for my Tacoma and the address I used in AZ I could no longer use (ex-bf) so I had to suck it up. Sucks.
  15. Apr 24, 2020 at 3:40 PM
    BrownMike
    San Diego
    1999 Taco 4x4
    Yeah I bought some lands out there mostly for registration purposes, well worth it in my opinion!
  16. Apr 26, 2020 at 10:19 AM
    Speed Freek
    If you put a shell on it I believe you can get it classified as non-commercial which should lower the reg fees. :thumbsup:
    Drainbung likes this.
  17. Apr 26, 2020 at 10:22 AM
    Speed Freek
    I might go to HF in the next few days and I possibly pick one up, I always need more tools, if so I'd be more than happy to bend that for you, that is if you haven't done it by then.
  18. Apr 26, 2020 at 1:12 PM
    CaliTaco718
    CaliTaco718 Instagram: socalmike9000
    Chapel HIll, TN
    2019 TRD Sport DCSB 4x4 MGM
    Falken AT4's.
    Hey any you guys use an OBD Scanner app? I started playing with Car Scanner and it's pulling a C0100 and P0152 code...One of these is an Bank2 sensor one high voltage...A little concerned to this at 5k miles though.
    However....the OBD Link app included with the dongle, is not pulling any code and no CEL..:confused:
  19. Apr 26, 2020 at 7:00 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    thanks. I've actually decided to go a different way. new design takes out 3 parts so hopefully will be sturdier.
    i appreciate it though.
  20. Apr 27, 2020 at 7:26 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    anyone know where (in san diego) i can take my kayak out that isn't the ocean or crowded beaches?
    04taccoo likes this.
