San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Aug 6, 2020 at 11:19 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    That's the recommendation if you wheel hard enough. Spindles at the least. You likely won't need coil bucket gussets. That's typically seen on LT setups.
    I have a set of spindles with TC gussets ready to go if you're interested.
    :cheers:
    eccracer104 and Falldownhard like this.
  2. Aug 6, 2020 at 2:31 PM
    donaldt24
    donaldt24 Well-Known Member
    Not Donald
    San Diego, CA
    2015 White TRD Sport 4x4
    Anyone know a good tire shop in the downtown area (within a 10 mile radius) that can mount my new titan 7 wheels without scratching them?
  3. Aug 6, 2020 at 2:42 PM
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    Bears's tires is the best spot if you don't trust discount tire. The discount tire on sports arena takes good care of me.
    BrownMike and donaldt24[QUOTED] like this.
  4. Aug 6, 2020 at 3:36 PM
    johnnywideopen
    johnnywideopen Well-Known Member
    Johnny
    San Diego
    2002 2.7L SR5 4x4 manual extra cab
    I need a recommendation for a shop, hopefully in north county, but really wherever, that you’d trust to press in new front bearings and hubs and all the spacers/clips/stuff and torque down the 203lb nut on first gen spindles.
  5. Aug 6, 2020 at 4:44 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    I’d recommend @Speed Freek the OP of this thread is in Vista. His phone number is listed in his profile.
  6. Aug 6, 2020 at 4:49 PM
    Falldownhard
    Falldownhard @tacomavanzandt
    Evan
    San Diego
    2015 Toyota Tacoma TRD Off Road 4x4
    Things and Stuff.
    Second recommendation for @Speed Freek
    GlitterGulch likes this.
  7. Aug 6, 2020 at 4:52 PM
    jesus619taco
    jesus619taco Well-Known Member
    Speed freek is a very busy dude understandably. Never had work by him but I've tried and still in line for some stuff. All good makes me work on my own stuff instead of being lazy haha.
  8. Aug 7, 2020 at 8:23 PM
    donaldt24
    Not Donald
    San Diego, CA
    I ended up going to Bear’s. Thank you for the input, they were cool!
    MunchTIME[QUOTED] likes this.
  9. Aug 10, 2020 at 7:33 AM
    desertjunkie760
    Shane
    Check My Sig.
    Little project I worked on yesterday. I FINALLY decided to install this setup. I've had this sitting for over a year and a half but it hasn't been on the priority list. I'm very excited! :bananadance: For those of you who have installed a hard mount HAM, how did you route the antenna cable?
    Trimming the plastic on the shifter housing.
  10. Aug 10, 2020 at 7:33 AM
    desertjunkie760
    Shane
    Check My Sig.
    Trimming the bezel and rough fitment.
  11. Aug 10, 2020 at 7:57 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Mine was run through a grommet under the driver floorboard, run along the frame, up into the driver tail light housing and then out to a tailgate mount.
  12. Aug 10, 2020 at 9:30 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Through the roof lol
  13. Aug 10, 2020 at 9:32 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    @desertjunkie760 mine is routed through the main grommet on the drivers side firewall, up and under the windshield cowl, along the windshield, and along the rain gutter to a mag mount at the rear of the roof.
    desertjunkie760 and Drainbung like this.
  14. Aug 10, 2020 at 10:00 AM
    desertjunkie760
    Shane
    Check My Sig.
    o_O:sawzall:
    eccracer104 and Drainbung like this.
  15. Aug 10, 2020 at 10:35 AM
    desertjunkie760
    Shane
    Check My Sig.
    I was thinking of just running it under the "b-pillar" cowl and through the door. At least temporarily as I'm imagining my antenna mount will change in the near future.
  16. Aug 10, 2020 at 10:53 AM
    anthony250f
    Anthony
    San Diego, CA
    What I did before the roof was under the passenger seat. Fairly large grommet there.
    Drainbung likes this.
  17. Aug 10, 2020 at 10:57 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    That’s how I ran the CB antenna wire
  18. Aug 10, 2020 at 11:07 AM
    desertjunkie760
    Shane
    Check My Sig.
    Serious question. How did you route yours via the roof?
    there's a couple grommets under the cab. I was hoping to retain somewhat of a water seal if possible.
  19. Aug 10, 2020 at 11:25 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    I did the roof on my first gen, a little scary but once its done its done! haha I believe I ran mine up the A pillar, between the headliner and roof. Been there for a few years and no leaks. Its the best place for most antennas (ground plane). Nice part is you can remove the whip with one allen key and then its only 2" above the roof. Also, I have the same radio, works great!
  20. Aug 10, 2020 at 11:27 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
