San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Aug 10, 2020 at 11:31 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I've heard good things about this radio. I'm by no means knowledgeable on these setups. I just want a better option than the Boefang hand helds I'm currently using. The 65 watt power will be nice to have available if needed.
    The guy I bought the radio from gave me a wall transformer so I was playing with the setup last night. I'm pretty excited about it. I can easily adjust squelch and save up to 100 named memory channels which I'll be saving the known "Race" channels to start.
    I like the second option as a fall back plan. Thanks! I'm not shoving more wires through the firewall grommet. Already have enough going through there.
  2. Aug 10, 2020 at 11:33 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Lies, its never enough. We'll all eventually find something else to add. Like some heated cupholders....
    eccracer104 and Drainbung like this.
  3. Aug 10, 2020 at 11:36 AM
    desertjunkie760
    Shane
    Check My Sig.
    I prewired 5 switches when I did my fuse block so all I have to do is add the accessory and switch later on. It was a big project at the time but the "plug and play is nice now." I'm only using two of the switches at the moment.
  4. Aug 10, 2020 at 11:55 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    Yeah HAM is way clearer than a mojority of CB setups since they are usually not tuned correctly. I have the one in the truck, then 2 UV-8R's for other people.
  5. Aug 10, 2020 at 12:01 PM
    desertjunkie760
    Shane
    Check My Sig.
    You do t see a lot of CB setups on the west coast. They were big when I live on the East Coast but I rarely see them out here.
    That’ll be my exact setup. I have my current UV-8R and a spare for CYA. With the hard mount I’ll have two “loaners” and/or a backup.
    Drainbung likes this.
  6. Aug 10, 2020 at 12:08 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    What antennas are you guys using for this Kenwood?
    ideally I'd like to mount a half wave on the driver fender to mirror the radio antenna, but more realistically a quarter wave for the 2m
  7. Aug 10, 2020 at 12:13 PM
    BrownMike
    San Diego
    1999 Taco 4x4
    What HRO told me to grab when I bought the setup
    Larsen
    NMO 150 (2m)
    Frequency: 144-174 MHz
    Gain: 3dBd / 5.2dBi
    Electrical: 5/8 wave
    Height: 49"
    Power Rating: 200 Watts
  8. Aug 10, 2020 at 12:19 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    3/4 NMO Cables are under headliner
    3BF69D1F-956B-4422-BB08-B2DA36A13564.jpg C0544564-5B00-444E-ABF6-5B0112F71BB9.jpg
  9. Aug 10, 2020 at 12:20 PM
    anthony250f
    Anthony
    San Diego, CA
    Using a tram 5/8 wave and also a tram 1/4 wave. Both work very well
    same radio
    Drainbung and eccracer104 like this.
  10. Aug 10, 2020 at 12:24 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    odd you went with tri-band for a single band radio. I'm thinking Laird B132s ona fender mount I'll make
  11. Aug 10, 2020 at 12:28 PM
    anthony250f
    Anthony
    San Diego, CA
    The dual band antenna actually goes to a dual band radio. The other antenna is dedicated to the kenwood
  12. Aug 10, 2020 at 12:29 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I put silicone around the grommet, after several years of fuckery there was no evidence of water under the carpet.
  13. Aug 10, 2020 at 12:45 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    i meant to quote bronwmike
    anthony250f[QUOTED] likes this.
  14. Aug 10, 2020 at 1:07 PM
    desertjunkie760
    Shane
    Check My Sig.
    Which one's for the Kenwood?
    Edit: looks like the tram 1/4 wave?
  15. Aug 10, 2020 at 1:28 PM
    2008taco
    chris
    san diego
    I did the same. Problem is I'm out of switch spots, so I'm working on this.
    hoarder23 and Drainbung like this.
  16. Aug 10, 2020 at 1:43 PM
    anthony250f
    Anthony
    San Diego, CA
    The long 5/8 wave but sometimes i use a 1/4 wave vhf antenna
    you can see the short vhf antenna here
    619D1582-E29C-4FDB-BEFD-E68D9763CD93.jpg 6BE9B124-9C3C-4865-95D2-435EDA0F4D71.jpg
    the 1/4” short vhf works almost as good as the 5/8
  17. Aug 10, 2020 at 1:52 PM
    desertjunkie760
    Shane
    Check My Sig.
    How's the performance with the shorter 1/4" short? I'd rather not have a huge antenna if I can avoid it.
    Edit: I see your comment under the pictures now :facepalm:
  18. Aug 10, 2020 at 1:55 PM
    anthony250f
    Anthony
    San Diego, CA
  19. Aug 10, 2020 at 3:07 PM
    BrownMike
    San Diego
    1999 Taco 4x4
  20. Aug 10, 2020 at 3:41 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    Cool. i looked it up and it showed tri band. prolly fat fingered something. thanks for the link
    BrownMike likes this.
