San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. Jul 16, 2023 at 9:09 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ugh, sorry:( is it leaking from one of the connectors, especially the same one as before?
    Sounds like that connector may be deformed or scratched. Yeah, a new one may be needed, hopefully they aren’t too expensive.
    Does anyone know the PSI Tacoma fuel pumps work at?
    Smcsherry[QUOTED] likes this.
  2. Jul 16, 2023 at 10:00 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    I was telling her, it looked like it was tweaked to the side, it didnt take much hand pressure to get in back into place, but I dont think it was fulling sealing on the flare
  3. Jul 16, 2023 at 1:52 PM
    OnHartung'sRoad
    That was really good of you to try, though! Good thing that came out of it was a you showed her how to do it, I’m sure it was helpful as she is the kind of person that will be able to do it now.
    Drainbung and Smcsherry like this.
  4. Jul 16, 2023 at 3:31 PM
    Smcsherry
    Smcsherry Well-Known Member
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    Yeah, so we don't think I will need to replace anything else right ?? Haha I don't if I should try to do this myself or have Jason do this for me. Also I was talking to my uncle. And he has a guy he goes through that apparently he's a toyota tech. And there might be a recall on some part ? Idk if I understood correctly.
    Sage63 likes this.
  5. Jul 16, 2023 at 5:02 PM
    OnHartung'sRoad
    There is a fuel leak recall for certain models- put your VIN here to check if your truck has it or any other recalls:
    https://www.nhtsa.gov/recalls?gclid...rPw_9jVrwFty2hhX6a0aAqmcEALw_wcB&gclsrc=aw.ds
  6. Jul 17, 2023 at 11:58 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    HPFP around 2000psi
  7. Jul 17, 2023 at 1:57 PM
    OnHartung'sRoad
    Oh, ouch! That’s high enough for a gas tattoo if you put your hand in the stream!
    Speed Freek[OP] and Drainbung like this.
  8. Jul 17, 2023 at 9:59 PM
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    Fabzonearmor on Instagram could probably help you out
    Logans2001[QUOTED] likes this.
  9. Jul 18, 2023 at 7:51 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Hope all are well, felt less like being in purgatory today than yesterday so that's a plus. Ill take any win when I feel like Im melting and I used to be good at extreme heat, but now that I no longer live in Az full time I have become what is known as a 'WEATHERWUSS!" I need to build a sauna and get myself acclimated to heat again, anybody here able to help me build one?? haha...
  10. Jul 18, 2023 at 8:02 PM
    Speed Freek
    Correction that would be an injection, at that pressure it is far beyond a tattoo! Those stop at the Dermis layer....ha. Im also a EMT-P so i have seen the results, it's beyond gnarly especially when the subject/patient tries to "walk it off for a day or two" also as a Diesel tech I have seen in happen in my Workplace when the tech makes an error...not a pretty sight.
    But we all know how us men can and usually are. There is good reason why we die sooner than our female counterparts..we tend to ignore things till it's too late to reverse or at least catch and make the best of it.
    Based on that statement, my wife will outlast me, she is far more cautious, lol...
  11. Jul 18, 2023 at 9:10 PM
    OnHartung'sRoad
    Yeah, jet inoculations work as low as 1200 psi, so it does look like I was a bit off….
  12. Jul 18, 2023 at 9:50 PM
    Speed Freek
    Well to be fair the ID system on a Toyota 4D is in the 780+ psi so depending on angle of attack and fan% results may vary depending on distance from source, but yeah either way you aren't going to have positive stories about that scenario, haha.
    Drainbung likes this.
  13. Jul 19, 2023 at 7:34 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Just come over and hang out in my un-insulated garage. It's gotta be well over 100 in there the last few days.
  14. Jul 21, 2023 at 8:53 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Greetings to my new neighbors from a traveler who has transplanted from the OC area to the SD area. :cheers:
    Anyone here interested in adopting about a 1yr old female cat?
    Long story short, my niece had a stray cat that had a litter under her house a while back and this is the last of the bunch... from how I understand it.
    Anyways, she's approx 1yr old, not fixed, a little timid, but very playful and likes to be petted.
    My niece already has cats of her own as well as me.
    Anyways, just hoping to find a loving home for this one if anyone is interested?
    I just moved from OC to SD area. PM me if interested?
    Btw, :wave: @sdsurfer if you are still around?
  15. Jul 21, 2023 at 10:35 PM
    WileECoyote
    SoCal
    @LOLLY :wave:
    LOLLY likes this.
  16. Jul 21, 2023 at 10:59 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    It's been a while!
    WileECoyote[QUOTED] likes this.
  17. Jul 22, 2023 at 3:02 AM
    WileECoyote
    SoCal
    Yeah it has.
    We still need to do a night run up the peak. Night runs are always fun up there.
    Plus, we just might see the "ghost lights". :eek::goingcrazy:
    @JaCado :wave: Jay, if you're down for a night run up the peak some day? I got work to do on the truck right now though like my CV axles, upper/lower ball joints, bed bolts, and a few other things.
    Plus, my unpacking and setting it all back up. Working Mon-Sat and I have to complete a certain task for my new job too... My point being it will be a while before I can do anything.
    Anyways, I still want to do a night run, but it will be quite a while before I am able to do anything... MONTHS before I am able to do anything. That is how busy I am at the moment and how important I must complete the "task" for my new job, which I can't talk about what I do now. Technically, I'm not even supposed to say where I work... LMAO... which is pretty stupid as one only has to follow me when I'm going to work? :notsure::facepalm:
    But yeah, I've been busier than shi* for the past few months... Pretty much going on a year almost and believe me, I am TIRED!!!
    Right now, I'm just glad I finally moved as the commute was killing me... almost literally at times.
    Well, getting ready to leave for work and enough of the BS of my life story. Just letting you all know what has been going on.
    L8 for now. :fistbump:
  18. Jul 23, 2023 at 10:45 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    SKULLY, theolee and OnHartung'sRoad like this.
  19. Jul 23, 2023 at 6:52 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Do you guys have a go to shock rebuilder for SD? I know there’s Acutune, but I’m wondering if any members do it for a bit cheaper.
    Gonna be down at the SD Zoo on Thursday
  20. Jul 23, 2023 at 7:23 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Downsouth Motorsports
