San Diego BS Thread.
Discussion in 'Southern California' started by Speed Freek, Nov 23, 2010.
  1. May 27, 2024 at 5:00 PM
    Speed Freek
    Speed Freek [OP] Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Almost forgot to wish everyone and especially our veterans and current enlisted a happy Memorial day, thanks to them we aren't speaking German or Japanese as our primary language!! :cheers::oldglory:
  2. May 27, 2024 at 5:02 PM
    Speed Freek
    Im a 5 lug and no body lift, that would look silly having the frame hanging down so far.
    If you have a 6 lug there are some kits out there that can really help with the install. On a 5 lug its quite the MFer to say the least.
    daveeasa, orbot[QUOTED] and Drainbung like this.
  3. May 27, 2024 at 9:35 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Always do the hard way first. The rest is easy.
    Speed Freek[OP] likes this.
  4. May 28, 2024 at 11:09 AM
    Speed Freek
    Or better yet....being 80% done takes 20% of the time but the last 20% takes 80% of the time, ask me how I know, haha!
    Hope you are doing well in the great north David!
    Tacorvette progress report:
    So yesterday I changed out the wastegate spring to the lowest I had which on my boost gauge shows about 3psi, perfect for toning it down for the wife to drive it now, the 12psi spring setup was absolutely ridiculous for trying to drive normally! I could be in 3rd gear and when the boost comes on both tires start spinning like Im on wet ground, even with 275 wide tires it still blows them off rather easily.
    Now I can use (once I program it in) my dial-a-boost so I can select 7 modes of boost levels, I will set the 1st detent as no PWM on the controller so it stays at 3psi and graduate the other 6 detents at 3psi each for a total of 21psi on max which isnt really practical until I get super sticky rear tires and/or the AWD conversion with 4 sticky tires ideally.
    It's finally coming along and now I can start to enjoy it for a while before I tear it apart again for the AWD system once I get my plan in place, gotta start collecting some parts for the upgrade and then see how I can make everything fit where there is very little space somehow. AFAIK I was the first person to successfully swap an LS into a 5 lug and get it to work, and I did it back in 2011. and the truck still looks like its stock aside from the brake kit behind the front wheels and the intercooler peeking through the valance. I'll be curious to see how I can do with mileage on longer trips and see if I can get into the high 2#mpgs now that I have increased the volumetric efficiency of the engine with the turbo, not to mention the stroker setup which adds a considerable amount of torque in the lower rpms which is better for street driving.
    JLD124, MadTaco461, Drainbung and 2 others like this.
  5. May 28, 2024 at 2:03 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    If you look closely you can see him move right after the Fodder settles, Drivers side, back door. I think we was inside laying down, so that rear seat is a good blast shield.
    Could have been a lot worse if he was in a busy parking lot close to other vehicles and people.
  6. Jun 4, 2024 at 11:55 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Anyone have a 8” e locker 3rd member? Mine blew up and has a hole in it….
  7. Jun 4, 2024 at 9:35 PM
    Speed Freek
    Well damn, being inside the truck changes my perspective slightly. Should have been able to smell it even easier, lol.
    Might have a little case of Tinnitus after that brief sudden pressure increase. :eek:
    SoCaltaco65[QUOTED] likes this.
  8. Jun 4, 2024 at 9:40 PM
    Speed Freek
    Damn, even broke the cast center housing! I don’t have one here, but I’ll check around and let you know if I find something.
  9. Jun 5, 2024 at 8:03 AM
    SoCaltaco65
    That and hearing loss...
  10. Jun 10, 2024 at 2:53 PM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Anyone have a good alignment shop in n.county and if so what did they charge? Always use True Line in El Cajon but last time I went wasn’t super stoked. Have heard people recommend SD Truck Shop…anyone know what they charge? They are closer but always super busy…just called but was put on hold for 10 min and gave up lol.
    2009Access4x4 likes this.
  11. Jun 10, 2024 at 3:31 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I always go to Truck Shop for that. I believe it's right around $100 for alignment. Yeah they can get pretty busy sometimes and you may have to wait on hold or call back on occasion but they know their stuff and haven't led me wrong. They're also an offroad shop so if you have offroad mods they know their way around em.
    Set up an appointment if you want it done quickly. I usually ride a motorcycle so I will typically just drop it for a day or two to work on it at their pace.
    SoCaltaco65 and SKULLY[QUOTED] like this.
  12. Jun 10, 2024 at 4:07 PM
    565hunter
    565hunter Active Member
    Tom
    2015 DCSB Habitat camper
    I've used North County Wheels and Tires at the recommendation of Harry at JDF. 760-737-7141 I believe the alignment guy is named Slim.
    SKULLY[QUOTED] likes this.
  13. Jun 10, 2024 at 6:59 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    D & E alignment in Escondido. Paul is super knowledgable and done an awesome job on my truck.
    SKULLY[QUOTED] and daveeasa like this.
  14. Jun 10, 2024 at 7:31 PM
    daveeasa
    David
    PNW
    And quick and not expensive. But you gotta deal with their ad-hoc approach to scheduling. I really wanted to use them for my 3rd truck but I had a super tight window of half a day even though I knew more than a month in advance which day. They just wouldn’t let me pre schedule and of course when I called in when they told me to, the spots were all booked up.
  15. Jun 13, 2024 at 8:33 AM
    YotaFAB
    YotaFAB Well-Known Member
    Accurate alignment in Oceanside is pretty good
  16. Jun 14, 2024 at 9:45 AM
    SoCaltaco65
  17. Jun 14, 2024 at 10:00 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Is this a good place to post a "For Sale" of my 06 Tacoma Quad Cab? I'd like to sell it locally. I am in 92131, Scripps Ranch.
  18. Jun 14, 2024 at 10:04 AM
    SoCaltaco65
    not sure, could try offer up maybe?
  19. Jun 14, 2024 at 4:07 PM
    Tacoma San Diego
    Tacoma San Diego Well-Known Member
    2013 DCSB 4x4
    6112's/5160's with Deaver stage 3, GFC camper, Evo 10S and home-built bed drawers. Solar w/100 Ah battery.
    There is an area for posting Tacoma's for sale on this site (Buy / Sell / Trade), you should post there so you know it goes to a good home. I would also post other sites, so you don't limit yourself.
    Drainbung likes this.
  20. Jun 14, 2024 at 4:27 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    For a 2nd generation you say? How much? Scripps Ranch
