San Diego Meet #5 Ocotillo Wells Desert Run
Discussion in 'Southern California' started by SocalMan22, Nov 17, 2008.
  1. Jan 1, 2009 at 10:53 PM
    #321
    SocalMan22
    SocalMan22 [OP] Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    putting a v8 is alot of work good luck man and hope to see you out there sometime.
  2. Jan 1, 2009 at 11:11 PM
    #322
    caliKxracer
    caliKxracer Well-Known Member
    kyle
    san diego
    2000 Tacoma Prerunner
    Supercharged, Linked and Caged
    yea, i figure itll be down for atleast 2 weeks. Maybe a little bit longer because im going to try and do a one piece driveshaft. and finish up some more little things
  3. Jan 1, 2009 at 11:17 PM
    #323
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    linked with a 1 piece? bad idea... and a custom v8 swap in two weeks? doubtful. hope for being done in a minimum of 2 months. its alot more than you think... custom engine and tranny mounts, custom cross members, custom driveline... not to mention wiring if you go with fuel injection, cutting out firewall to scoot the motor back, blah blah blah.... good luck but dont take shortcuts. you will pay for them in the end.
    you want the links, stick to the 2 piece , keep the slip yoke in the driveshaft. you want to convert to one piece... make sure you have a th400 (or the likes of depending on the motor you use) trans and a solid mount at the tranny, 5 inch slip in the driveshaft.
  4. Jan 1, 2009 at 11:29 PM
    #324
    caliKxracer
    kyle
    san diego
    v8 would be a hopeful thing lol.
    But I didnt think staying with a two piece would be a good idea.
    I just found out when this truck was raced(last year) it had a completly different drivetrain setup that what is in it now. thats why i ran into these problems.
    Would i be better off extending the drive shaft to needed lenfth and just beefing up the spline?
    because the stock spline is to short and is getting pulled out and the teeth are just being grinded off
  5. Jan 2, 2009 at 12:19 AM
    #325
    allupinsydeyou
    so cal / vegas
    no.. you need to just re-strap the rear end so it stops pulling out. all that gnar ass travel doesnt mean a damn thing when the guy on stock leafs and 5150's is blowing past you because your driveshaft separated. what length straps are you running at the moment and what are your plunge and anti-squat numbers?
  6. Jan 2, 2009 at 7:18 AM
    #326
    caliKxracer
    kyle
    san diego
    Thats what i thought i needed to do, but the grinding started on the street, from just stop on start moving, I think the driveshaft is just not long enough, I can see the teeth on the spline when its sitting at normal height. i dont know those numbers how can i check?
  7. Jan 2, 2009 at 10:21 AM
    #327
    caliKxracer
    kyle
    san diego
    I was talking about the date I go to ocotillo almost every weekend
  8. Jan 2, 2009 at 12:19 PM
    #328
    allupinsydeyou
    so cal / vegas
    seeing the splines at ride height really means nothing... it all depends how long the slip yoke is. you need to look over the geometry of your entire rear end if you are having problems like that.
    as for measuring plunge, set your rear end full bump and look at your slip yoke and mark it with a soap pen or a sharpie, then full droop it and make again... now measure between the 2 points... thats your plunge number.
    i recall you a while back saying you were pulling over 30 in the rer of your truck, IF that is even a true statement (which i highly doubt) you reallly might want to consider strapping it at either 24 to 26 inches. its time you learn to adjust the dampening of the rear of the truck. you will see it said many many times over and over.. 14 inches of finely tuned well dampended travel is better than 40 inches of dirty hooker shit dampened travel.
    ill put money on it you restrap the rear and adjust your pinion angle through the cycle of the suspension... you will be golden.
  9. Jan 2, 2009 at 12:44 PM
    #329
    caliKxracer
    kyle
    san diego
    thanks for the help, ill check the numbers when i get my truck back.
    and on the rear travel, The person I bought it from told me it was strapped at 36, wether its true or not, but he jacked the rear end with the tires on the ground and walked under the rear(hes 6"2) so it may not be 36 inches but its def not 18 or 20 lol.
    I already know the slip yoke is too short, my center bearing got pulled into literally two pieces last week.
    is there anyway I can check how much travel is in the rear with shocks?
  10. Jan 2, 2009 at 2:47 PM
    #330
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    HEY! The friends I have going to the meet want to spend the night on Friday. I don't remember anyone establishing a spot to meet where they can meet up the others also spending Fri night in Ocotillo Wells. Let me know please so I can relay the message. Thanks.
  11. Jan 2, 2009 at 4:35 PM
    #331
    caliKxracer
    kyle
    san diego
    yea, There is a small chance( i have a friend at AGM) that my truck will be done friday, if thats the case, ill try and make it out, if not next meet.
  12. Jan 2, 2009 at 6:16 PM
    #332
    allupinsydeyou
    so cal / vegas
    you have to pull the coils off of the coilovers and squat the ass end till its resting fully bumped. take a measurement from center wheel to top of bedside, then jack it up until limit strap is tight... take measurement. subtract first one from the second one. im betting the guy who sold it to you was either full of shit or amazing at geometry. just restrap the rear s you dont have to dump 1500 into a new driveline.
    and as for the meeting on friday night, ill be spending friday night out there as well but sure as hell aint camping by blow sand... i have seen disasters happen in those camp sites.. ill be off to the right of the bridge just before the blue inn. so will a few of my boys. your more than welcome to share camp with us.
  13. Jan 2, 2009 at 6:19 PM
    #333
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I'm still up in the air as to whether or not I'll make it. I called Toyota SD today and he said they're waiting on the insurance company for an adjustment. He said they have to replace the whole back end. Once he gets approval, he estimates about a week to complete it.
  14. Jan 2, 2009 at 8:17 PM
    #334
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    x2
    Did anyone actually set up a meeting place???
  15. Jan 2, 2009 at 8:26 PM
    #335
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Camp out down the way by the airport blowsand can get high traffic
  16. Jan 3, 2009 at 11:48 AM
    #336
    allupinsydeyou
    so cal / vegas
    and thats why we camp next to the bridge. easier and less people.
  17. Jan 3, 2009 at 8:03 PM
    #337
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i posted somewhere in here but this thread is huge and could've been easily missed...
    dtrujillo63, myself and a few others will be camping out off Highway 78 just a mile or two from the Ranger Station in a area called Blowsand hill. we'll be somewhere north from Highway 78 off of Main St. which is a dirt road.
    check out the Google Map for area approximation...
  18. Jan 3, 2009 at 9:45 PM
    #338
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    Awesome! I'll pass along the information. Expectations are high for this meet! Besides the camera, I'm thinking about the camcorder as well. I'll need a reason for it? Does anyone go streaking after they've had one too many? LOL. :D I also checked out the weather...High of 72. Low of 39! Damn that's going to be cold. Maybe I should bring a heater and plug it in! :rolleyes: Hmmm.
  19. Jan 3, 2009 at 11:25 PM
    #339
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    You guys should have a cb on for people showing up friday night??
  20. Jan 3, 2009 at 11:27 PM
    #340
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    I told denny and monkey to have the cb channel on 21 by 630.
