San Diego: NIB ID speakers, sub, and an amp
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by paranoid56, Jun 5, 2014.
  1. Jun 5, 2014 at 12:34 PM
    paranoid56
    paranoid56 [OP] Well-Known Member
    San Diego
    14 double cab taco
    bought this awhile ago and never ended up installing any of it.
    $600 picked up in SD. (over 700 in parts)
    Image Dynamics ID12 V.3 D4 12" subwoofer, Image Dynamics CTX-65.cs component and CTX65 coaxial speakers, Sonic Electronix will include a free RE Audio XTX500.5 5-channel amplifier.
    • 12" Dual 4 ohm ID V.3 Series Car Subwoofer
    • 6-1/2" 2-Way CTX Series Component Speaker System
    • 6-1/2" 2-Way CTX Series Coaxial Car Speakers
    • 5-Channel XTX Series Full Range Digital Car Amplifier XTX500.5
    Quantity: 1
    12" Dual 4 ohm ID V.3 Series Subwoofer
    Power Handling:
    Peak: 450 watts
    RMS: 250 watts
    Impedance: Dual 4 ohm
    Mica Polypropylene cone woofer
    Rubber surround
    Black anodized aluminum high temperature copper voice coil
    Stamped steel basket for improved rigidity and better power handling
    Optimized motor structure that uses finite element analysis for symmetrical and long linear excursion
    Also found as: ID12D4 V.3, ID12 D4 V.3, ID12 D4, ID12D4, ID12V.3 D4
    Sensitivity: 88.6dB
    Mounting Depth: 6"
    Cutout dimensions: 11"
    Quantity: 1 Set
    6-1/2" CTX Series 2-Way Car Component Speaker System
    Power Handling:
    Peak: 400 watts per set / 200 watts each side
    RMS: 200 watts per set / 100 watts each side
    Recommended Power Range: 25-200 watts per side
    Mica-Polymer cone
    Butyl rubber surround
    Silk dome tweeter
    High-energy neodymium tweeter magnets
    4 ohms impedance
    High temperature and high power voice coil
    Sensitivity: 89 dB
    Frequency Response: 55-25,000 Hz
    Top-mount depth: 2-3/4"
    Quantity: 1 Set
    6-1/2" CTX Series 2-Way Car Speakers
    Power Handling:
    Peak: 400 watts per pair / 200 watts each
    RMS: 200 watts per pair / 100 watts each
    Mica-Polymer cone
    Silk dome tweeter
    4 ohms impedance
    Sensitivity: 90 dB
    Frequency Response: 58-22,000 Hz
    Quantity: 1
    XTX Series 5-Channel Full Range Digital Car Amplifier
    RMS Power Rating (14.4V)):
    4 ohms: 60 watts x 4 chan. + 200 watts x 1 chan.
    2 ohms: 90 watts x 4 + 300 watts x 1 chan. chan.
    Bridged, 4 ohms: 180 watts x 2 chan. + 300 watts X 1 chan.
    Dynamic power output: 1500 watts
    Pulse Width Modulated MOSFET power supply
    LED power (green) and protect (red) indicators
    Wired remote included
    Fixed bass boost (12 dB at 45 Hz)
    5/3 channel operation
    2-Way System Protection circuitry (thermal and short circuit)
    Heavy duty brushed aluminum alloy convection cooled heatsink for efficient heat dissipation
    Nickel-plated RCA level inputs
    Nickel-plated 8-18AWG screw terminals
    Input sensitivity:
    Low level: 200mV-6V
    Variable high-pass filter (30-300 Hz, 24 dB/octave)
    Variable low-pass filter (50-1000 Hz, 24 dB/octave)
    Signal to noise ration: 90dB
    Phase Shift Control: 0 - 180°
    Frequency response: 10-30,000 Hz
    Dimensions: 10-5/8"L x 7-1/2"W x 1-15/16"H
    4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
    pics
