San Diego "Yard Sale"
Discussion in 'Southern California' started by SKULLY, Feb 26, 2012.
  1. Aug 8, 2020 at 4:32 PM
    #4481
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Let me know if you decide to get rid of a set. ;)
    eccracer104 and Drainbung like this.
  2. Aug 8, 2020 at 4:38 PM
    #4482
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  3. Aug 8, 2020 at 4:41 PM
    #4483
    campoman45
    campoman45 Well-Known Member
    Al
    96 tacoma 4x4 extra cab
    headers, warn winch, Detroit lockers 2 inch lift
    \im looking for rock guards for 1st generation tacoma 96 extra cab
  4. Aug 8, 2020 at 4:59 PM
    #4484
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Will most likely have a set for you soon...
  5. Aug 8, 2020 at 4:59 PM
    #4485
    Hagendazsss
    San Diego, CA
    :bananadance:
  6. Aug 9, 2020 at 10:34 AM
    #4486
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Chrome exhaust tip $20.
    Exhaust tip is dirty, was removed at 45k miles.
    North County.
  7. Aug 9, 2020 at 2:46 PM
    #4487
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    I have some 1st gen bilstein 5100s with stock coils on 3rd clip up for sale. Bilsteins have about 5000 miles on them, coils about 140k. Asking 150
    BrownMike and Drainbung like this.
  8. Aug 10, 2020 at 7:57 AM
    #4488
    sicki
    sicki Well-Known Member
    can someone use those shock bucket spacers with Fox ext travel coilovers? may need to add spacer to OEM bumps too though yeah?
  9. Aug 10, 2020 at 8:46 AM
    #4489
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    wait a minute.... is that what those spacers were for that came with the kit ?!?!?!
  10. Aug 10, 2020 at 8:50 AM
    #4490
    MunchTIME
    SD, CA
    So these aren't installed correctly as in they should have spacers on top of the shock?
  11. Aug 10, 2020 at 9:16 AM
    #4491
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    No, they are installed correctly. Spacers are a cheap way to compensate for proper setup.
    Prayn4surf likes this.
  12. Aug 10, 2020 at 9:17 AM
    #4492
    desertjunkie760
    Shane
    Check My Sig.
    Theoretically you can use spacers with any shock but it's not advised. I'd ask what you're trying to achieve in using a spacer?
    Yes, if you use a spacer you'll also need to check your bump travel and make sure you're not going to bottom out on the shock before the bump.
  13. Aug 10, 2020 at 9:19 AM
    #4493
    Nomad26
    Escondido, CA
    I'm not sure. These were meant for the taco lean.
    sicki[QUOTED] likes this.
  14. Aug 10, 2020 at 9:27 AM
    #4494
    sicki
    I would have to check droop too so as to make sure it stops at CO travel not on UCA uniball
  15. Aug 10, 2020 at 9:31 AM
    #4495
    MunchTIME
    SD, CA
    My C/Os are Fox 2.5 Ext with 700lb 14" springs, Accutune says we shouldn't crank them any longer than 21" when the truck is sitting level. I just cant believe how little lift I get from these is all, was thinking the missing spacers was maybe the problem.
  16. Aug 10, 2020 at 9:59 AM
    #4496
    desertjunkie760
    Shane
    Check My Sig.
    Yes
    That's due to the suspension geometry, not poor shock design. At 21", you still have enough droop travel for the shock to work on rebound and not cause poor ride quality. These trucks aren't intended for the amount of lift we try and give them.
  17. Aug 11, 2020 at 10:51 AM
    #4497
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    SOLD
  18. Aug 12, 2020 at 10:09 PM
    #4498
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You guys finish the new set already?
  19. Aug 12, 2020 at 11:32 PM
    #4499
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
  20. Aug 12, 2020 at 11:42 PM
    #4500
    MunchTIME
    SD, CA
    I think I'll take those headlights
    Drainbung and Tombiology70 like this.
