San Diego "Yard Sale"
Discussion in 'Southern California' started by SKULLY, Feb 26, 2012.
  1. Nov 7, 2021 at 12:41 PM
    #5221
    TacoTuesday1
    SD CA
    WTB(orrow/use) your lawn sprinkler in SD
    need to put one in various spots under the truck for a little bit to rinse it
    got a bunch of salt on the frame recently and trying to clean it off
    Please PM if we can work something out and what you charge
    Thank you
  2. Nov 7, 2021 at 5:25 PM
    #5222
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
    i use a self clean high pressure car wash for these times.....and spent like ten minutes under my truck (high pressure soap)
  3. Nov 7, 2021 at 8:14 PM
    #5223
    TacoNoVeggies
    TacoNoVeggies Well-Known Member
    San Diego, CA
    '20 Off Road ACLB Quicksand
    Stock
    Location(s) in SD county? I'll be needing this after coming back from snow country in a month or two
  4. Nov 7, 2021 at 10:59 PM
    #5224
    TacoTuesday1
    SD CA
    sounds like something that would force salt higher up and deeper into cracks at 1600psi that it otherwise was not even into from the road, not to mention the limited angles able to achieve from a long stall wand laying next to a truck on the ground...
  5. Nov 7, 2021 at 11:12 PM
    #5225
    djcharlee
    djcharlee RETIRED SSGT OF MARINES
    Carlos
    Chula Vista, CA
    2020 Double Cab TRD OR
    Pro Comp Leveling Spacer 17" Icon Wheels Falken Wildpeak AT3W 285/70R17
    I am driving to Massachussets and back starting next week. What would be a good option for cleaning the undercarriage after I get back, any suggestions.
  6. Nov 7, 2021 at 11:43 PM
    #5226
    TacoTuesday1
    SD CA
    You tell me. You and me both man.
    Good options I can think of:
    If you have access to a shop with lift, drain grates, and water hose with spray attachment, you can lift the truck and get underneath, spraying it. Then squeegee water into the drain.
    Or, if you have a lawn with hose and house, the hose can be stretched out to underneath the truck with a cheap spinny sprinkler attachment and ran. Walk inside, do something else, forget about it, especially if water is cheap and there's not too much restrictions regarding drought/time use.
    Then come back outside later (10 minutes, whatever you want), and move around the location underneath the truck for full washing.
    Neighbors gonna look at you weird.
    With or without skid plates.
    Because I don't seem to have access to either of these two options right now, I may try to replicate number one.
    Now that I think about it, my apartment building may have a water hose hookup that HOA pays for.
    But there's no parking spot near it.
    So basically I have to find a way to park my truck near it, lay underneath without getting soaked, and connect a hose. Then I can either connect a sprinkler, or spray handle.
    Either that or I pony up and buy some shit like this for $50
    I'm not into "making my own" stuff like that (out of PVC pipe) ever since I made a brake fluid pressure bleeder out of a garden sprayer, for barely cheaper than a real one (Motive) that did not work as well.
    re your avatar EGA, IDK if Miramar still has the heated pressure washer lift bay outside at the auto shop. More for cleaning oil off a vehicle underside.
    Found a post on Reddit talking about this that mentioned a Chevron car wash in Chula Vista on H Street. I tried it. Requires the Deluxe version or something.
    You can definitely see some spray up out the floor but it's not much and only like 10 seconds.
    I guess if I end up buying the attachment I'll have to let you know to borrow it.
    Now that I think about it, even with the "sprinkler method" I used, I was still badly surprised when I got a closer look under the truck and found rust starting to develop in places it previously never had. In hindsight I could've moved the sprinkler around more spots.
  7. Nov 7, 2021 at 11:49 PM
    #5227
    djcharlee
    Carlos
    Chula Vista, CA
    Well, Ill see what happens when I get back towards the end off the month, if not beginning of Dec. Thanks for the information.
  8. Nov 8, 2021 at 10:04 AM
    #5228
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    I don't know if this would suit your needs but some drive-thru car washes have an undercarriage washer. Usually a Chevron with a touch free wash has these. I remember these locations having that feature.
    https://goo.gl/maps/d4PXFGeAoRre4wxu5
    https://goo.gl/maps/jv46uK1WKMhf3prY7
    https://goo.gl/maps/AAFR6kSsSaFw7DaA6
    Again, it may not suit your needs as it's a fixed washer in the ground and you drive over it as you enter the wash so all you get is one pass. And you'll have to pay more for the upper price tier as the cheapest wash doesn't include the undercarriage washer.
  9. Nov 8, 2021 at 12:03 PM
    #5229
    AZoverlandTaco
    AZoverlandTaco How do I change my profile name?
    Eric
    Flagstaff
    Toyota 4 Life
    Do you still have one of these tires?
  10. Nov 8, 2021 at 12:03 PM
    #5230
    AZoverlandTaco
    Eric
    Flagstaff
    Toyota 4 Life
    Anyone sitting on a used 295/70/18 tire they would like to get rid of?
  11. Nov 8, 2021 at 9:02 PM
    #5231
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    ISO of a silver driver side rear fender for a 3rd Gen '19. If anyone has one laying around let me know.
  12. Nov 12, 2021 at 2:06 PM
    #5232
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    Have a few things for sale:
    Set of 17x8 Pro Comp 51 steelies bolt pattern 6x5.5. 3 are in great condition, one has paint chipping around lug holes and rim. Asking 175obo
    Set of 1.25 inch hub centric wheel spacers bolt pattern 6x5.5. Asking 50obo. I have all the lug nuts for spacers and wheels. $200 combo deal if you buy the spacers and wheels.
    Brand new front dif 1inch drop spacer kit. Should work for 1st gen Tacoma, tundras and 3rd gen 4runners. Asking 15obo.
    I will also throw in 2 Amazon light bars with any purchase. Located in mission valley/Linda vista.
  13. Nov 13, 2021 at 7:46 AM
    #5233
    Mahana
    Mahana IG: @mahanakine
    San Diego, CA
    2017 DCSB Taco 2wd
    I’ll take the spacers. DM you now.
    04taccoo[QUOTED] likes this.
  14. Nov 13, 2021 at 6:23 PM
    #5234
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Have some 3rd Gen headlights. DRL version. No broken tabs. If anyone is interested. Perfect candidates for some retrofits. Looking to get $300. Pm if interested
  15. Nov 14, 2021 at 4:47 PM
    #5235
    Wannabe4x
    Wannabe4x Well-Known Member
    Conner
    EastCounty, SanDiego
    2nd gen TRD PreRunner
    Spindle lift, 285/70/17s, Methods
    FOR SALE as combo or pieced out. Leer shell with working shocks and locks, pretty sure it’s for a 1st gen but I made it work for my access cab 2nd. Slide windows with screens and privacy tint I installed, not professional but is decent and can be taken off. My insulation fell off the roof and I still have it.
    Have a custom built bed platform with removable middle, carpeted. Asking $450 for the shell and $180 for the platform, or $600 for both.
    Penis painted tailgate not for sale LOL
    Located in La Mesa CA,
    call or text 619-876-6409 to reach me fast
    8243BD39-7559-49A8-8B00-D75257816937.jpg 69C7DCEC-00F6-4B9F-A50D-8B6697F88588.jpg2D76B017-EFF7-4591-85E5-8E9593AE195F.jpg
  16. Nov 14, 2021 at 10:17 PM
    #5236
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    Does anyone have one of the Harbor Freight 20-ton shop presses taking up space that they're looking to get rid of? I've seen a few pop up online but they tend to sell quickly.
  17. Nov 15, 2021 at 7:34 AM
    #5237
    jessetoedtman
    jessetoedtman Well-Known Member
    Jesse
    San Diego
    2010 Tacoma SR5 DCLB 4x4
    Anyone need a Portaband? I purchased this from Harbor Freight, used it on 3 cuts and ended up getting a Milwaukee M18 bandsaw for a killer deal from a friend. $100 its yours, pickup in San Marcos.
  18. Nov 16, 2021 at 9:15 PM
    #5238
    1201TACO
    1201TACO Well-Known Member
    Vincent
    San Diego
    ‘12 Tacoma Prerunner SR5 V6
    is this still available?
  19. Nov 16, 2021 at 9:53 PM
    #5239
    TacoTuesday1
    SD CA
    wtb 4.10 gear set (front and rear diff) from 2nd gen 2.7L I4 taco
  20. Nov 17, 2021 at 8:22 PM
    #5240
    04taccoo
    Cyrus
    San Diego
    4x4 conversion
    Wheels and spacers sold
