San Diego "Yard Sale"
Discussion in 'Southern California' started by SKULLY, Feb 26, 2012.
  1. Jul 22, 2023 at 6:44 PM
    #5861
    TacoTuesday1
    SD CA
    FS regear parts
    2nd gen Tacoma
    4.10’s, 4x4, front and rear
    Rear is 8.4”
    60k mi running
    SD
    $300
  2. Jul 23, 2023 at 2:50 AM
    #5862
    TacoTuesday1
    SD CA
    wtb: rear diff third member. Don't need axle housing
    8.4"
    any ratio
    LSD or open. non elocker
    05-15 2nd gen
    362656630_1059160418597865_4280249230799_470304804840398644a1c320f5033781b69a3b1d.jpg
  3. Jul 23, 2023 at 7:43 AM
    #5863
    TacoTuesday1
    SD CA
    FS truck bed sleeping platform
    Cost me about $250 to build
    Asking $150obo
    pics don’t show the foam I’ll take more ASAP
    bed is a couple months old. Made with sideways 2x6 supports to give you room for drawer storage underneath
    5/8” smooth plywood for strength, and carpeting upholstered with glue and staples
    I have it in my 2nd gen DCSB 5’ bedrug lined bed
    it can be removed to store
    Shortly after I purchased 4” foam from a military surplus store and cut it (kept the cuts) to fit at an angle.
    Because yes, you can sleep up to 6’ tall in a shortbed if you go at an angle.
    Simply lay the bedding, sleeping bag, etc of your choice on top
    I am hoping fitment will work without a bedrug if you don’t have one. I know with mine the cut is tight enough where it takes effort to get them in.
    The plywood is cut vertically into two panels
    why 4” foam? Because it adds comfort and that’s what’s most popular.
    Bed is also strong and roomy enough to haul cargo, in addition to anything stored underneath out of sight.
  4. Jul 23, 2023 at 10:21 AM
    #5864
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    2nd Gen double cab Prinsu cab & cap rack pair. This was the first generation Prinsu from when Zach was still making this stuff out of his home. Same great shape and functionality of the newer ones just a different front wind fairing shape. The load bars are also the original rectangular ones but i have used the hell out of this thing from cargo to rtt and never had a problem with them.
    Could use a re spray or powder coat if you care about it. $250 for both, don’t want to split them up.
    banditcamp likes this.
  5. Jul 23, 2023 at 12:37 PM
    #5865
    FrostyTaco05
    FrostyTaco05 Overbudget Off-roader
    SoCal
    2014 DCLB
    More mods than it should have...
    These still available? Will definitely take them off your hands if they are. :D
  6. Jul 23, 2023 at 12:40 PM
    #5866
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    Would you be interested in shipping?
  7. Jul 23, 2023 at 1:05 PM
    #5867
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    i’m not against it but you do realize it will be at least $100 probably?
  8. Jul 23, 2023 at 1:22 PM
    #5868
    banditcamp
    daniel
    Yeah. I figured that but it's a really good deal regardless. If you don't have luck selling it locally on a week or so hit me up. I am interested.
  9. Jul 23, 2023 at 3:50 PM
    #5869
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    They sure are, shoot me a pm!
  10. Jul 23, 2023 at 5:57 PM
    #5870
    YotaFAB
    YotaFAB Well-Known Member
    got a stock one with stock LSD in my garage. has about 140k on it. I regeared to 4.88 only reason for pulling
    TacoTuesday1[QUOTED] likes this.
  11. Jul 23, 2023 at 6:55 PM
    #5871
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I have a pair of McNeil 2" bulge fiberglass fenders painted in MGM that need a new home. They are clearly used and could use some TLC but will still bolt onto the truck and serve their purpose. They do have cracks & some chipping that you should be able to fix with some fiberglass repair.
    I also have a custom snorkel that I used with the glass. Made out of aluminum & TIG welded together. Cutting is done to fit the snorkel so I would prefer all be sold together.
    $300 for the package?
  12. Jul 24, 2023 at 5:55 PM
    #5872
    TacoTuesday1
    SD CA
    FS Cornwell coolant refiller
    Also have Toyota adapter separate
    $150 obo
  13. Jul 24, 2023 at 9:49 PM
    #5873
    TacoTuesday1
    SD CA
    selling black mesh in SD, PM if interested
    got them in bulk to copy this guy's idea for shell window inside gear mounts
    still need to figure out what eyelet clamps to get under the stock bolts to hold them
    might cut out a majority center row or two in mine to retain finger room to open window. Haven't decided how many panels I'll put per window or which spots
    OnHartung'sRoad and banditcamp like this.
  14. Jul 25, 2023 at 9:11 AM
    #5874
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I like this, it’s a good idea as a protective screen so you can keep windows open and not worry about your dog or other gear tearing up the bug screens! As for window opening- all you need is finger room enough to unlatch and slightly open the window- at least on mine I can push the window to open or close it from the outside if it is unlatched and slightly opened.
    How much of a space are you putting behind the screen? Are you using spacers?
    ScrippsRanch67 likes this.
  15. Jul 25, 2023 at 9:13 AM
    #5875
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I did a similar thing
  16. Jul 25, 2023 at 9:30 AM
    #5876
    OnHartung'sRoad
    Looks good! I got the plastic heavy duty accessory pet screens on my shell and like the OP’s idea of more storage space on the sides- but in your case this looks great for dogs and unruly children! ;)
  17. Jul 25, 2023 at 5:27 PM
    #5877
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Generator is Gone!!!
    BrownMike likes this.
  18. Jul 27, 2023 at 5:09 PM
    #5878
    TacoTuesday1
    SD CA
    Not mine
    Ventura CA, FB
    appears to be 2G ACLB 6’
    theolee likes this.
  19. Jul 27, 2023 at 6:36 PM
    #5879
    xx3xil3xx
    xx3xil3xx Well-Known Member
    ESCONDIDO/SAN DIEGO, CA
    06 runner
    Sold
  20. Jul 30, 2023 at 8:33 PM
    #5880
    TacoTuesday1
    SD CA
