Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. May 12, 2016 at 11:43 AM
    #241
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    But I don't have enough for another down payment.
  2. May 12, 2016 at 11:45 AM
    #242
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    whats gap insurance? Isn't a car considered totaled if the repair is worth more than the car itself?
  3. May 12, 2016 at 11:45 AM
    #243
    AFMurse2014
    Devin
    San Antonio
    Gap insurance is through Toyota. Basically they will cover the remaining value due to depreciation.
    The trucks a lease-to-own
    highwhey likes this.
  4. May 12, 2016 at 11:49 AM
    #244
    Iamraiderpower
    Iamraiderpower Well-Known Member
  5. May 12, 2016 at 11:50 AM
    #245
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    I thought these trucks go up in value when used.
  6. May 12, 2016 at 12:06 PM
    #246
    AFMurse2014
    Devin
    San Antonio
    5206 Miles.
    I thought I could of expected more from Toyota :( I feel let down...
  7. May 12, 2016 at 12:07 PM
    #247
    Iamraiderpower
    Well whats your plan?
  8. May 12, 2016 at 12:12 PM
    #248
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    you have the right to feel let down. im let down for you too. that really did escalate quickly. whats next?
  9. May 12, 2016 at 12:38 PM
    #249
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    I was curious as to how much my truck would be valued in a trade in...they told me 29-30k. It's a 2016 Tacoma 4wd TRD offroad manual transmission with tech and tow pkg and 10k miles. Lol...
  10. May 12, 2016 at 12:43 PM
    #250
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Any spot there is rubber on the main fuel feed line you can cut the hose and insert a $1 paper fuel filter. That will keep the fine grit that gets past the sock filter from getting into the injectors.
  11. May 12, 2016 at 2:15 PM
    #251
    AFMurse2014
    Devin
    San Antonio
    It's a high pressure system so I doubt there's a bunch of rubber lines or a paper filter would work
    12TRDTacoma likes this.
  12. May 12, 2016 at 2:16 PM
    #252
    AFMurse2014
    Devin
    San Antonio
    Not sure. If they do total it, I don't have anything to trade or pit down for a new truck.
  13. May 12, 2016 at 3:11 PM
    #253
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    The first thing that should have happened was the tank dropped and inspected inside and see how much sand is really in there. If someone had a long scope they could have looked inside. No one's doing anything because no one knows who's going to pay. It's a shame for the owner and the insurance company. If someone dumped sand in the tank you can sure bet it's going to be a hell of allot more than a few grains of sand.
    Lawfarin likes this.
  14. May 12, 2016 at 3:23 PM
    #254
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    nvnv likes this.
  15. May 12, 2016 at 3:51 PM
    #255
    AFMurse2014
    Devin
    San Antonio
    Truck ran perfect after fill up though
  16. May 12, 2016 at 4:31 PM
    #256
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Honestly I think Toyota is f...ing with you. Those people can't figure out how to check transmission fluid correctly but you think they actually troubleshoot anything?. If truly water was to the wheels than nothing should have happened.
    I agree with @chris4x4 that most likely culprit is that you sucked some water through evap system since its super low, also you could have screwed one or more o2 sensors as those absolutely go bad with salt water near them, lastly you could have shorted fuel pump itself since plug is low for relieving fuel pressures.
    So if you got water in system that probably blew injectors but instead of replacing them I would get them cleaned and checked one at the time, replace only those bad if any, next in line is fuel regulator, purge all fuel lines, drain charcoal canister if anything is there, clean fuel pump plug (grey plug used to be on driver side frame goign back towards fuel tank), Check fuel pump itself, since those are higher pressure, water could have destroyed it in seconds.
    Once you fix truck.... trade it for 2 gen.
    No DI injectors to blow with little water.
    Now before some retard claims its impossible to suck water from evap, let me point out where evap is.
    Drop spare tire and look towards the tank, there is charcoal canister there and secondary air filter (one nobody cleans until they need to replace charcoal)
    That system runs under vacuum, so if anything there is not properly sealed any amount water there will get sucked into the fuel system.
    With DI injectors any amount of water will destroy them.
    Good luck OP. I would try fixing and trading your truck.
    And I get the joke that Offroad truck can not go offroad, but that is Turd Gen... there are plenty of 1gen and 2gen that played submarine running with out issues.
    :thumbsup:
    12TRDTacoma and T4RFTMFW like this.
  17. May 12, 2016 at 7:10 PM
    #257
    TacoSeattle
    TacoSeattle Well-Known Member
    2016 Tacoma TRD OR 4x4 v6 SB Quicksand
    Talked with my Service Manager at Toyota of Bellevue and related these happenings and asked him about the fuel system.
    His immediate response was that it is a closed pressurized system and contaminants cannot be introduced into the system except via the filler cap and if the cap were loose or otherwise there would be a check engine warning light.
    His other immediate response what that someone poured sand or otherwise down the filler neck if that is indeed the problem.
    WMDtech likes this.
  18. May 12, 2016 at 7:25 PM
    #258
    AFMurse2014
    Devin
    San Antonio
    Well that's two dealers who claim sand down the filler neck. Maybe it happened somehow? Apparently a minute amount of sand will trash this thing....
  19. May 12, 2016 at 7:29 PM
    #259
    AFMurse2014
    Devin
    San Antonio
    I was looking at the fuel system diagrams, and noticed there's the air inlet, and filter on the evap system by the spare, and a charcoal filter on the filler neck itself for the vent tube (I believe)... I wonder if pressure washing the nooks and crannies somehow drove sand down it? I don't think they lab tested the gas to see if fuel.
    In fact, they never dropped the tank, only removed fuel lines after the tank and found cloudiness and 2 grains of sand (in the Starbucks bottle) that are so small I literally cannot see them
  20. May 12, 2016 at 7:33 PM
    #260
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    I second the props to the member going out of his way!!!
