Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. Apr 24, 2016 at 10:28 PM
    #41
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Hmmm. I think you should arrange for a ride to work and call the dealer to have it towed. Maybe water got into something and it won't dry out.
    For $15 (I think) you can get online access to the Toyota diagnostic information for a couple days and maybe sort it out with a lot of effort. It sounds like this is a tricky one. Like I said, I would call the dealer and have it towed.
    I think that wave tossed up an old cannon from a pirate ship and bashed your fuel line. That's why it's having such a hard time regulating fuel pressure. (Open to better theories!)
    Chipskip and AFMurse2014[OP] like this.
  2. Apr 24, 2016 at 10:43 PM
    #42
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you hear a loud humming from your TPS butterfly valve motor at the intake, I would suspect a bad TPS motor which is causing all these other codes to trip up as a result. Toyota tends to default their VSC program to power off once a check engine light issue is detected, why the mentality is beyond me. Nevertheless, try taking it to the dealer and let them mess with it. If they refuse to, it looks like you may have a somewhat pricey part bill on your hands.
  3. Apr 25, 2016 at 12:38 AM
    #43
    eon_blue
    Azusa, CA
    I'm betting some water got sucked up into the intake. Had it happen to me in my last vehicle (scion) during a huge downpour and my engine went into limp mode. Once eveything dried out and the car sat for a bit (couple hours) everything was normal again.
  4. Apr 25, 2016 at 12:24 PM
    #44
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    TPS codes are resolved. Now it's just the fuel pressure and injection codes with lean codes on both banks.
    Intake and filter/ throttle body are completely dry. First thing I checked lol
  5. Apr 25, 2016 at 12:30 PM
    #45
    eon_blue
    Azusa, CA
    I just had a P0171 'System Too Lean Bank 1' code yesterday, Toyota told me my MAF sensor was bad.
  6. Apr 25, 2016 at 12:33 PM
    #46
    Tacoma_Jake
    Tacoma_Jake Well-Known Member
    2016 Tacoma TRD OR DCSB
    Yea... wasn't there a guy on here who used his truck to cross some shallow river bed and eventually used crawl control to get himself "unstuck" from the silt?
    Sometimes these issues can be caused just as easily from a defective or out of spec tiny part from a 3rd party vendor. IE like a rubber seal, or grommet, etc...
    Keep us updated OP.
  7. Apr 25, 2016 at 9:51 PM
    #47
    AFMurse2014
    Devin
    San Antonio
    Trucks still out of commission. It's rough.
    Still the same slew of codes, all fuses checked out
  8. Apr 25, 2016 at 10:39 PM
    #48
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    At this point the dealer would be replacing parts to see what fixed it.
  9. Apr 26, 2016 at 3:06 AM
    #49
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Subbed for out come, seems to me if a wiring harness is getting wet, anything could be effected. I'v had real good luck with LPS1, a water and rust inhibitor, on my 4 wheelers that I ride under water. Just spray on and leave it there, works wonderfully.
    HalfWayThere likes this.
  10. Apr 26, 2016 at 10:52 PM
    #50
    AFMurse2014
    Devin
    San Antonio
    Toyota care towed my truck to the dealer without hesitation
  11. Apr 27, 2016 at 9:48 AM
    #51
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    How hard did you spray the engine? Each manual with every vehicle I've owner has said not to power wash the engine bay. I know you were trying to repeat the problem, but it might have caused more stuff to happen.
  12. Apr 27, 2016 at 11:28 AM
    #52
    AFMurse2014
    Devin
    San Antonio
    You know... I normally never really spray down an engine bay. I've done it on my old bronco and the 06 Ranger a few times after being really submerged or stuck, this was more of a spray down of the radiator and fan shroud areas and the underneath of the hood to get sand and salt out. I didn't directly target electronics and the engine has that plastic cover of it so it should of protected most of it.
    I think what did the damage is I sprayed the heck out of the undercarriage and control arms/bushings and control arms.... It over sprayed into the engine.
    Either way Toyota has my truck, said they'll do my 5k service and look into the issues. Corporate is concerned and tried to contact me but I was working. Service manager said its covered under warranty (before they even know what's wrong.) Should be good.
    Chipskip likes this.
  13. Apr 27, 2016 at 12:04 PM
    #53
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm going to guess, water in the DI relay box.
    12TRDTacoma, Aussiek2000 and ZachMX like this.
  14. Apr 27, 2016 at 2:50 PM
    #54
    AFMurse2014
    Devin
    San Antonio
    Relays and such are completely dry. I checked that immediately lol. This is a wiring harness/ injector connection issue. The codes that popped are circuit codes that lead to either breaks, or shorts in wiring. Aka the injector harness is not water tight
  15. Apr 27, 2016 at 2:51 PM
    #55
    AFMurse2014
    Devin
    San Antonio
    The dealer is working on it, I'll definitely update you guys with their word, and will think of a fix!
    HalfWayThere and Chipskip like this.
  16. Apr 27, 2016 at 3:04 PM
    #56
    Sandtaco
    Sandtaco Well-Known Member
    Henderson NV
    2016 TRD Offroad Access cab
    Maybe it is not water related at all, and something just happened to fail when you were on the beach in the water. I have hosed my engine compartment down a few times now and no issues.
    Good luck!
  17. Apr 27, 2016 at 3:19 PM
    #57
    AFMurse2014
    Devin
    San Antonio
    That could be it too! I really hope so, because you SHOULD be able to get an engine wet without it failing. I could understand if I pressure washed the fuse and relay panels or the ECM lol
  18. Apr 27, 2016 at 3:49 PM
    #58
    Gearheadesw
    Davenport Fl
    I drive in torrential rains in the summer down here in Florida, torrential. Driving on the hi-way, hitting standing water at speed with hundreds of other cars spitting water into the air, I'v never had a problem like yours. Should be able to take a complete wetting and survive.
    Sensiman12 likes this.
  19. Apr 27, 2016 at 4:46 PM
    #59
    AFMurse2014
    Devin
    San Antonio
    Dealer just called. Confirmed that the codes I pulled were "all injector codes". Like I told him. 4/6 of the injectors are 'failed'. They are currently looking for a short in the system, and the next step is the ECU but they are talking with corporate and asking if they can hold my truck another day.
    Sounds to me like my truck either had a predisposed wiring issue, or water/sand/salt got somewhere were it shouldn't have some how.
    Either way they are going to fix it under full warranty (so far) and hopefully I don't have any more issues.
    I did express that I am concerned/surprised that a truck marketed for off roading and can be seen romping through mud is disabled by small amounts of water. It'd be completely different if I ran through 2-3 feet or more of water, but I didn't lol.
    12TRDTacoma likes this.
  20. Apr 27, 2016 at 4:49 PM
    #60
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    My truck has been in water up to the doors and pressure washed underneath a dozen or more times with no issues
    Sensiman12 and 12TRDTacoma like this.
