Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. Sep 9, 2016 at 1:41 PM
    #601
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Aren't people having problems with some interior LED replacements causing weird problems? It seems like the system is overly sensitive. Automotive electronics are usually pretty robust against interference so I wonder if there's a weak link, an overall increase in sensitivity, or aftermarket products are getting worse when it comes to EMI/RFI?
    As a data point on the sensitivity of the electrical system, the folks that installed my shell blew the brake fuse and that brought in the check-engine light.
    Spare Parts likes this.
  2. Sep 9, 2016 at 1:41 PM
    #602
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
  3. Sep 9, 2016 at 1:42 PM
    #603
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i would request a demonstration of it acting normal, then directly hose off those connections to replicate. Sounds to me like the found another issue but using this as a reason.
    If this is true, Toyota now has a sensitive system which rivals the CANBUS shit system in Dodge and Mercedes. AKA good luck with modding.
    Chipskip and VolcomTacoma like this.
  4. Sep 9, 2016 at 1:43 PM
    #604
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Pretty much this. After the first BS, they need to show you whats going on, not just pull the "this what we think is happening, give us money"
    asuchemist likes this.
  5. Sep 9, 2016 at 1:48 PM
    #605
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    This is a quote from that article you referenced,
    What I'm getting from this thread is the Suzuki ECU has little or no sheilding from reactance.
    In a nutshell, reactance is an EMF "backwash" from a source of capacitance. HIDs need high voltage to fire and sustain. A capacitor charges and discharges to start HID bulbs. This sends an equal and opposite charge back to the source of initial potential (voltage). This is the sole reason point ignition systems employed a condenser (capacitor).
    Perhaps the Suzi rectifiers/ECUs weren't properly shielded whilst KHIs were?
    Interesting, I hope the Toyota engineers replicate it in front of you, good luck!
  6. Sep 9, 2016 at 2:23 PM
    #606
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I absolutely 100% believe this can happen. Anyone who has worked on any cars/bikes knows that adding any aftermarket electrical work may/can cause havoc on the Canbus system. Couple that with salt water, and you may have a recipe for disaster.
    Looks like the sand in the tank was a red herring, and while they performed that work, the HID kit got to dry up, and now that you got it wet again, the electronics are going haywire.
    T4RFTMFW likes this.
  7. Sep 9, 2016 at 2:32 PM
    #607
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Wow. I sure hope this is the issue and that you can get back to enjoying your truck!
  8. Sep 9, 2016 at 2:54 PM
    #608
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
    Long story short - I had something similar happen to me.
    I had a 2012 F-150 and put in a set of 2013 F-150 HID headlights. For whatever reason the truck did not like the lights. It wired up to the stock system, including the ballast with no issues. After a couple of days the truck would be dead, draining the battery. The lights would blink on and off like it was possessed and wreak havoc on the ECU. When the lights would blink on and off the truck would not start even though the battery had juice. I noticed it would occur especially when it was raining out, in WA State was almost everyday. I replaced the ballast multiple times but it would only last for a few days. Checked and re-checked the lights, wiring etc. for leaks or exposed wires.
    Bottom-line, something was screwy and I couldn't get to the bottom of it. I put the old lights back in and everything was fine.
    From the sound of your issues it is possible you're experiencing something similar. I hope it works out.
    WMDtech likes this.
  9. Sep 9, 2016 at 3:06 PM
    #609
    stan23
    stan
    Santa Clara, CA
    It would also explain why they couldn't find the cause for the limp mode originally. Canbus while pretty robust at telling you whats wrong and where, it doesn't get to specific like adding a ballast between your stock headlight connectors and the HID lights.
  10. Sep 9, 2016 at 3:08 PM
    #610
    T4RFTMFW
    T4RFTMFW Well-Known Member
    $14k later, and it's aftermarket headlights.
    Not sure what emotion I should choose to feel.
  11. Sep 9, 2016 at 3:23 PM
    #611
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    So if this is true when do you get your 14k back? Id have to see it reproduced!
    medic2230 likes this.
  12. Sep 9, 2016 at 3:25 PM
    #612
    T4RFTMFW
    That's the insurance companies 14k. I'd assume they would, but if the dealer had due cause for the repairs (and they did) I would think with court costs that wouldn't be worth pursuing.
  13. Sep 9, 2016 at 3:29 PM
    #613
    stan23
    stan
    Santa Clara, CA
    I would be relieved! Electrical gremlins are the worse and it sounds the source of the problem has been found.
    IMO, the issue should have been found the first time around.
  14. Sep 9, 2016 at 3:31 PM
    #614
    medic2230
    Murph
    Bama! Roll Tide
    So they are just now discovering that there were HID's installed?
  15. Sep 9, 2016 at 3:34 PM
    #615
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    This is only an issue when wet. And what's funny, is the lights never quite working properly. They function normal, so you'd think if they were shorting out they'd be showing some signs...
    In going to reduce everything to stock and video me pressure washing the truck (hood popped)
    Well see what happens
  16. Sep 9, 2016 at 3:34 PM
    #616
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    TLDR, Cliff notes please
    nv529 likes this.
  17. Sep 9, 2016 at 3:37 PM
    #617
    T4RFTMFW
    In short, you're lazy.
    nv529, oldschoolczar and nevadabugle like this.
  18. Sep 9, 2016 at 3:38 PM
    #618
    VolcomTacoma
    Jeff
    NorCal
  19. Sep 9, 2016 at 3:40 PM
    #619
    stan23
    stan
    Santa Clara, CA
    You hit the nail in the head the first time around.. Instead of the dealer doing real troubleshooting, they just started 'replacing'
  20. Sep 9, 2016 at 3:41 PM
    #620
    medic2230
    Murph
    Bama! Roll Tide
    I'm willing to bet it will happen with stock lights too.
    Only part on the lights that can really be affected by water is the relay box on the HID harness. Had my set turn themselves on one time when water got in the relay.
