Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. Oct 11, 2016 at 9:59 PM
    #961
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    I agree that I dont think problem was cause by the HID or LED, but since i am not 100% sure, I am kinda backing out from installing any of it right now.
    Thinking about creating a new circuit just for headlight and install a canceller on the original line, so I can install HID "safely"...
    Lawfarin[QUOTED] likes this.
  2. Oct 11, 2016 at 10:07 PM
    #962
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    A lot of those kits have there own relay. Not only does this isolate its power from the factory wiring but it's to regulate the voltage drop what causes one of the HID's to turn off and stay off while the vehicle is started and running. I'm not sure about the kits they used and if they use their own external relay, but the truck also uses a relay and the circuit is fused. Extremely little chance that any sort of back feed or interference could actually make its way to the ECU. Either way I personally wouldn't worry about it. And if there is ever a problem just keep your original bulbs to put back in. I really believe it's a crank position sensor issue that's causing the truck to not start. I've seen them be very intermittent in vehicles before and there is a known issue with them on certain 2016 tacomas. But then again with electronics anything is possible. I've seen lots of weird and crazy shit in the 12 years I've been in the automotive industry working on cars and trucks. Hopefully they both get the issue solved
  3. Oct 12, 2016 at 4:54 AM
    #963
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    how could you even think that. OP sprays engine bay with LED and HID kit in and truck goes nuts and shuts down basically. Swaps out to stock bulbs sprays the shit out of it zero issues with the truck. Pretty sure thats a closed case that the HID or LED kit was 100% the culprit.
    12TRDTacoma and jonnyozero3 like this.
  4. Oct 12, 2016 at 5:23 AM
    #964
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    I pressure washed my engine bay yesterday but because of your thread and a few others a took my LED's out and replaced them with the factory bulbs before I did it.
    Nickel likes this.
  5. Oct 12, 2016 at 9:49 AM
    #965
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Just to recap..it was not the HID's that caused the issue it was 1 specific type of LED's.
  6. Oct 12, 2016 at 10:55 AM
    #966
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Correct, at least from what I can ascertain--it's the older (discontinued) XB LED bulbs.
  7. Oct 12, 2016 at 4:09 PM
    #967
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    well.. the other user had the new 2 strokes.
    I'm not sure which one it is, I haven't had a chance to go back and individually test again.
    Inconclusive at this point
    T4RFTMFW likes this.
  8. Oct 12, 2016 at 4:47 PM
    #968
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    The plot thickens!
  9. Oct 12, 2016 at 5:11 PM
    #969
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Ha, it worked!
    Fwiw, even after reading every post in this thread I got morimoto hids from TRS anyway and they're great.. I've power washed my truck twice since installing them with no issues. Either way seems the diagnosis has shifted to the LEDs so my experience with the HIDs is probably irrelevant now.
  10. Oct 12, 2016 at 5:13 PM
    #970
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    OP doesn't even have a clue what's going on. Just because it hasn't happened again doesn't mean it won't. I've been a professional mobile electronics installer for 12 years. I've seen a lot of crazy things happen. I've also seen a lot of techs blame issues on aftermarket equipment and products when in fact it's had nothing to do with the issue. I'm extremely leery on this case. Lots of variables obviously I don't know, but just based on the problem and what they are claiming is causing it I'm calling bullshit. If OP wants to send me the lights I'll install them and record the whole thing. Take my pressure washer and head over to our Toyota store and grab a tech steam and my multimeter and really start diagnosing it.
    Nickel likes this.
  11. Oct 12, 2016 at 7:41 PM
    #971
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    I have been following this thread a bit. At one point you had a huge Bill. Like $14k. Where does that stand? This is still crazy to me.
    Have ran retroa/HIDs for years in multiple vehicles without issue.
  12. Oct 12, 2016 at 7:45 PM
    #972
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    His insurance paid it because the dealer (incorrectly IMHO) determined the problem was caused by sand in the fuel tank which migrated into the fuel system and dissolved under the pressure but came out of solution in the injectors or some such crap. OP mentioned the new diagnosis to the insurance company but they declined to pursue the issue.
    [Edit: The insurance company is the only one that gets a gold star in this fiasco.]
  13. Oct 12, 2016 at 9:07 PM
    #973
    AFMurse2014
    Devin
    San Antonio
    I know that my truck has exhibited issued 3 times. Each time was after water exposure. I know that the dealer can replicate the issue after unplugging lights, and didn't charge me any labor because they knew they screwed up this last time.
    I am currently speaking with trs and we are trying to figure things out. They've gone and processed a refund for the 2 stroke LEDs since I had fitment issues.
    I have not had a chance to test them with water yet. I do plan on reinstalling the old LEDs and spraying the truck down to see if the problem is isolated to them. If I was the HIDs, well never know because I attacked them with a ton of silicone and dielectric grease.
    There IS a problem, we just need to pinpoint where
  14. Oct 13, 2016 at 4:15 PM
    #974
    Sam B
    Samuel
    Poway, Ca.
    none
    Thanks for the update Devin.
  15. Oct 14, 2016 at 7:47 AM
    #975
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I think I would take this guy up on his offer, sounds like he would get to the bottom of this, and find what is really going on.
    Biscuits likes this.
  16. Nov 13, 2016 at 4:29 AM
    #976
    AFMurse2014
    Devin
    San Antonio
    So I took the truck back to Pismo, even HAD to drive through some standing tide waters, as the tide was way high and came all the way up to the sand road, and asphalt by the gate.
    Romped the dunes and did countless donuts, slides, and roosts.
    Haven't washed it yet, buy so far.... No issues.
    T-Rex266 and nevadabugle like this.
  17. Nov 13, 2016 at 8:35 AM
    #977
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
    What did u have as lows, highs and fogs this time?
    I've had 2Strokes, LED interior and exterior lights for a while now and been though heavy rains we get here in the north west. No issues
  18. Nov 13, 2016 at 1:46 PM
    #978
    AFMurse2014
    Devin
    San Antonio
    I had my interior LEDs from superbrightleds, my Morimoto HID 35w 5k, the XC Led projector fogs, and the 2 stroke LED highs.
  19. Nov 13, 2016 at 2:09 PM
    #979
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    Let me know next time you are in Pismo. My schedule is pretty impacted, but I could probably hang out for a while if you are out there.
  20. Nov 13, 2016 at 3:21 PM
    #980
    AFMurse2014
    Devin
    San Antonio
