Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. Nov 14, 2016 at 1:18 AM
    #981
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Truck's gonna explode when you wash it next.
    UberDingu likes this.
  2. Nov 14, 2016 at 8:21 AM
    #982
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Shhhhhh
  3. Nov 14, 2016 at 10:59 PM
    #983
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    I gently sprayed down my engine bay to wash off some of the mud yesterday. I was thinking about you the whole time. No problems in my case.
    I'm also starting to think I'd like brighter headlights. What's your status on the aftermarket lights?
  4. Nov 15, 2016 at 3:08 PM
    #984
    AFMurse2014
    Devin
    San Antonio
    After this whole issue, I've replaced the old Leds, with 2 stroke models from trs, and have siliconed and greased all connections from the trs Morimoto HIDs. Haven't had an issue yet.
  5. Nov 18, 2016 at 11:10 AM
    #985
    AFMurse2014
    Devin
    San Antonio
    Well you won't believe it...
    Washed the truck following my pismo trip.
    Guess what... It's disabled again.
    All aftermarket lights have been disconnected and fuses pulled...
  6. Nov 18, 2016 at 11:13 AM
    #986
    T4RFTMFW
    T4RFTMFW Well-Known Member
  7. Nov 18, 2016 at 11:17 AM
    #987
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    What the fuck...Noooooooooooooo.
  8. Nov 18, 2016 at 11:32 AM
    #988
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    Sorry for the zero-assumption question: Were you back to stock when you washed the truck or did you remove the aftermarket lights after the truck had problems?
  9. Nov 18, 2016 at 11:52 AM
    #989
    AFMurse2014
    Devin
    San Antonio
    Aftermarket were installed, although according to Toyota "all we did was unplug them"
    I ripped everything out and have stock bulbs in. Unfortunately, ive lost the high beam bulbs lol
  10. Nov 18, 2016 at 11:53 AM
    #990
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Uh Oh
  11. Nov 18, 2016 at 11:54 AM
    #991
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    Same symptoms? Rough running and no power, or completely dead?
    This is an amazingly tough one. I wonder if the lights could have done something that would last through a power-cycle? I can't think of what, unless it was actual damage that won't ever get better (nice thought, I know).
  12. Nov 18, 2016 at 11:55 AM
    #992
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    Did you try it with the stock bulbs unplugged (simulating "we just unplugged the aftermarket lights and it worked")?
  13. Nov 18, 2016 at 11:59 AM
    #993
    AFMurse2014
    Devin
    San Antonio
  14. Nov 18, 2016 at 12:00 PM
    #994
    AFMurse2014
    Devin
    San Antonio
    It'll idle. Not throwing codes oddly enough... It threw 8 of them, typical injector circuit codes, I cleared em and now it won't throw codes, but won't run. Just studders and stalls. But will fire right up
  15. Nov 18, 2016 at 12:02 PM
    #995
    AFMurse2014
    Devin
    San Antonio
    I pulled the battery cable. I'll wait a bit
  16. Nov 18, 2016 at 12:08 PM
    #996
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Holy shit....
    Goodluck OP.
  17. Nov 18, 2016 at 12:25 PM
    #997
    AFMurse2014
    Devin
    San Antonio
    Pulling the battery, now it shows codes but doesn't idle. Starts, stuffers, stalls.
  18. Nov 18, 2016 at 3:26 PM
    #998
    AFMurse2014
    Devin
    San Antonio
    Towed it to dealer. Waiting for a ride home
  19. Nov 18, 2016 at 8:33 PM
    #999
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    long-suf·fer·ing
    adjective
    adjective: longsuffering
    1. having or showing patience in spite of troubles, especially those caused by other people.
    2. AFMurse2014
  20. Nov 18, 2016 at 8:45 PM
    #1000
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    ^seriously!
    This is crazy. When in doubt, go back to stock.
    Do your LED bulbs plug directly into the OEM light socket and get power from it?
    If so, I'd look into doing a relay. That way the OEM light circuit is only powering a relay, (which will then will power the LED bulbs directly to the battery)
    Bypasing any weird signals backfeeding through the headlight circuit.
    Just brainstorming...
    Good luck OP
    the_dau likes this.
