Sand in the tank, headlights, or electrical issues, the saga continues for the 4th time? (10/9/18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFMurse2014, Apr 23, 2016.
  1. Nov 28, 2016 at 1:27 PM
    #1061
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Man... you must be really desperate..!! Holy shit ..."go to a Ford"..!!
  2. Nov 28, 2016 at 1:36 PM
    #1062
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Came from a Ford. 2 of them actually. No significant issues, families run for for over 40 years, and to this day, nothing significant.
    I know not a popular choice around here, but I bought my last 2 fords used with 150k+ miles, and both are still on the road today lol
  3. Nov 28, 2016 at 4:15 PM
    #1063
    over60
    Muskoka, Ontario
    Right where they died, eh...?? hehehe Just kiddin' man... Glad you had good luck with them... I did not and 1 was a freakin' Lincoln Town car... nothing but repairs after repairs...!
    I went Jap and am not going back to GM or Ford.
    Mush Mouse and robssol like this.
  4. Nov 28, 2016 at 5:34 PM
    #1064
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Guess we're done here then. Enjoy your Ford.
  5. Nov 28, 2016 at 7:02 PM
    #1065
    Jeffwels
    Jeffwels Well-Known Member
    Jeff
    2017 TRD OR DerberCerb
    I only went through half the 50+ pages so sorry if this was already brought up, but since the issue persists... Do you know what the codes are it is throwing after you reset the battery the last time? Do you have an aftermarket intake or air filter? Are you getting any smoke when it sputters? If so, what color?
  6. Nov 28, 2016 at 7:39 PM
    #1066
    AFMurse2014
    Devin
    San Antonio
    No Smoke, the codes are any combination of cyl 1-6 injector circuit codes. usually 1,2,3,4.
    No aftermarket engine/intake mods. Only the aftermarket plug and play lights. no splicing, no cutting etc.
  7. Nov 28, 2016 at 7:59 PM
    #1067
    Jeffwels
    Jeff
    When installing the passenger side ballast for the HID did you remove anything from the airbox assembly? Any chance anything got loose over there and possibly getting the MAF wet when cleaning? I know Im grasping at straws here, but I feel for you on the problem. I would be out of patience.
    The dealer trying to directly blame the lights seems like a stretch unless a wire/s were inadvertently stripped or exposed when installing the lights.
  8. Nov 29, 2016 at 7:27 AM
    #1068
    AFMurse2014
    Devin
    San Antonio
    Nope, no need to disassemble anything.
    Anyways, I checked the filter, intake, throttle body, etc. It's definitely a computer error, as after the truck is turned off, the electronic throttle body motor that operates the butterfly valve whines loudly. I have the unplug it to get it to stop. Basically it sounds like it's trying to move but is already as far as it can go.
    It also just throws random codes. Sometimes a TPS codes, other times injector circuits, other times no code
  9. Nov 29, 2016 at 7:28 AM
    #1069
    AFMurse2014
    Devin
    San Antonio
    No alterations, splices, etc to any factory wiring
  10. Nov 30, 2016 at 7:19 PM
    #1070
    AFMurse2014
    Devin
    San Antonio
    Well, after 13 days, multiple unanswered calls and 2 unanswered voice messages, I went into the dealer today. (I'm nightshift, I SHOULD of been sleeping.)
    They
    Didn't
    Have
    any
    Record.
    My Advisor has been out sick, so apparently that means NO ONE follows up with his customers?
    Absolute shit if you ask me. Apparently the Technition had my truck in the stall and was on the phone with the Toyo Field Specialist. I was promised a call back this afternoon, and got nothing.
    4 page single spaced complaint has been sent in to Toyota Corp. This is outrageous. I am 700 deep into a rental car as of today. Absolutely dogshit service and shotty work.
    Biscuits likes this.
  11. Nov 30, 2016 at 7:25 PM
    #1071
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
  12. Nov 30, 2016 at 7:55 PM
    #1072
    prowl647
    prowl647 Well-Known Member
    What dealer? I am in Sacramento area and would like to avoid the place you took your taco to
  13. Nov 30, 2016 at 9:15 PM
    #1073
    AFMurse2014
    Devin
    San Antonio
    Momentum of Fairfield. For now on, after this incident, I will be going to Vacaville. Only issue is the length of drive for the shuttle folks... I am literally 5 mins from the Fairfield Dealer.
  14. Nov 30, 2016 at 9:17 PM
    #1074
    AFMurse2014
    Devin
    San Antonio
    In my complaint I did mention that I would pursue lemon law (not really applicable, the wording is difficult, but it states it has to be warranty repairs... non of this has been under warranty). I also stated that I would start to pursue a lawyer, but would rather not due to my upcoming deployment to the Middle East (gotta go f*ck up Taliban!) and that I am requesting either my truck gets fixed the right way officially, or I would like to start a buy back or a trade.
    Finally, if none of the above I want my lease terminated and all extra costs I have fronted repaid.
    Fat chance. Little lonesome me against Corporate Toyota... No match.
    Biscuits and Chipskip like this.
  15. Dec 2, 2016 at 10:29 AM
    #1075
    AFMurse2014
    Devin
    San Antonio
    Well. 14 days. They called me back, 2 days later than they promised. Left a message as I was just getting off work (can't walk and tslk on a phone in uniform ) after a 14 hr night shift. I tried to call back twice, no answers so I drove in. They asked me a bunch of accusatory questions on what happened(most of them I already answered 14 days ago...)
    Ive been up for 21 hours straight. I'm tired, sore, hungry and pissed. But, I'm uniform so I have to keep my composure.
    I turned the heat up a bit and explained this is the third time and im losing faith in their service, such as telling me sand dissolves, and then going to the lights, and now this. I asked about buy backs as l no longer trust the truck and there's obviously an issue. She told me there isnt any options as none of this was manufacturer defect and its something in doing.
    Way to support your customer and product Toyota.
    I'm exhausted with this process, I've now spent over 2500 on rental vehicles due to this truck, and this current one is approaching 1k. I've made 3 truck payments with no truck to show for it, the other 9 I atleast had it in my garage.
    I've quite literally never experienced such blatent lack of concern for the customer, lack of support, and accusatory behavior from a company before.. I've received better service from Comcast...
    I'm a patient person but this y is over the top, I'm being bullied by Toyota.
    Anyone know any lawyers that handle cases like this, or anyone willing to atleast write a letter to try and bolster this.
    I dont think my expectations are too high... I just want a truck I can drive, and not worry about it breaking down.
  16. Dec 2, 2016 at 11:06 AM
    #1076
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Good luck Devin! Hope you get some closure.
  17. Dec 5, 2016 at 9:03 AM
    #1077
    AFMurse2014
    Devin
    San Antonio
    Well. It's 18 days now...Getting close to or over 1k in rental fees, and I've heard from Toyota twice, each time I've had to walk in and demand conversation... and they've beat around the bush, offered no answers/support They always tell me "we will call you later today" and I end up calling them 2 days later, or driving in. The last time this happened, it was Wednesday... it's now Monday and still no call back, even though I've left messages.
    When asking about options, I was basically laughed at, and told "there's no proof of manufacturer defect" and that I cant terminate my lease, or pursue buy back options. I was also told that it's pretty much my fault, and they are standing firm on the initial diagnosis of Sand in the tank the first time, lights the second time (with dust found in the tank) and now who knows what the third.. Same symptoms, same events, same presentation.
    There is zero customer service from this dealer, any bay area CA folks, steer clear from Momentum Toyota.
    In fact, I submitted a complaint to Toyota Corp, and have yet to hear back from them, and it's been 5 or more days.... With the last...4... claims I had responses, by phone, within 2 business days.
  18. Dec 5, 2016 at 10:15 AM
    #1078
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    As many of us suggested the first time... get an attorney. You don't have much in the way of alternatives. Well, unless your truck were to take a tragic ghost ride off a cliff
    Chipskip likes this.
  19. Dec 5, 2016 at 2:14 PM
    #1079
    Sam B
    Samuel
    Poway, Ca.
    none
    I'm still mulling over how sand got into a sealed system gas tank on a truck thats supposed to go in sand/dirt/mud. That needs some explaining...... from Toyota!
    Dalandser and AFMurse2014[OP] like this.
  20. Dec 5, 2016 at 3:20 PM
    #1080
    AFMurse2014
    Devin
    San Antonio
    That's what I said.
    Sam B[QUOTED] likes this.
