Sand Sinking
Discussion in 'Off-Roading & Trails' started by tacobo670, Jul 19, 2011.
  1. Jul 19, 2011 at 5:50 PM
    tacobo670
    tacobo670 [OP] if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    .... so im not getting the physics of driving /barging through sand. how ever u wanna call it, im confused. so im trying several times to get up n over a hill with some sandy spots (mostly compacted sand), n i keep bogging down n getting stuck n digging ruts.
    im thinking, larger tire patch on the ground = more surface area to stay on top of the sand.
    i know about the whole air-down thing, but i was with 2 other buddies n they had BFG's 285's n i got 325's. ---- no one aired down, yet they both made it up the hill except for me. they both got 3in lift, one had a camper n ATRAC n rear locker, other guy had front n rear plate bumper, LDS. i got 6in lift 33's
    i just dont get y it seems that the skinny tires get through the sand better than larger wider tires?
    any help/pointers/ideas?
  2. Jul 19, 2011 at 5:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Awaiting DavidK standard sand soapbox speech, with pics of the van stuck on the beach.....
  3. Jul 19, 2011 at 5:53 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    The tread design can have a lot to do with it as well. If you start spinning, an aggressive tire like a mud terrain will dig the sand out from under you really quick.
    Also are they in the same vehicle types? Might have skinnier tires but still be less pressure on the footprint from a lighter vehicle.
    Or maybe they are just better with the skinny pedal. Have they tried in your truck?
  4. Jul 19, 2011 at 5:55 PM
    tacobo670
    Ray
    Las Vegas
    LOL. i dont get it:notsure:
  5. Jul 19, 2011 at 5:55 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    What happened... where you in 4WD? Did you try to enter the sand with some momentum or just creep on? What year is your Tacoma?
    You say 'bogged down': where all 4 tires spinning up sand, one in front and one in back, or just the back?
    Air pressure is everything in sand if you are getting stuck at stock pressure... 4WD working for you is a big help.
  6. Jul 19, 2011 at 5:56 PM
    tacobo670
    Ray
    Las Vegas
    all of us roll tacoma's. i think we're all equal weight. guy with camper, guy with front n rear plate bumpers, n im 6in lift. would the brackets on my lift be that heavy to make weight difference?
  7. Jul 19, 2011 at 5:56 PM
    David K
    Education or helpful information exchange is all I am after here... nothing else.
  8. Jul 19, 2011 at 5:58 PM
    tacobo670
    Ray
    Las Vegas
    ya seemed like a 4 were digging in, couldnt see, didnt wanna roll down my window when all the sand was kicking up 12 ft in the air. tried 4hi and 4lo , crawling up, getting momentum. nothing was really working. never made it up n over, but the other 2 guys did. but it looked like they were killing the trucks! looks like it had ttterrrrrettttstststss.
  9. Jul 19, 2011 at 6:02 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Sounds like you had no speed to start. If you already have speed its pretty hard to sink in the sand. All you have to do is back pedal a quick sec and your right back on top of it. OR your tires just suck
  10. Jul 19, 2011 at 6:03 PM
    tacobo670
    Ray
    Las Vegas
    ya maybe i do just need to air down. but then that involves a whole new set of parameters on the mod budget, with having to purchase air tank, mounting hardware, tire deflators, etc.
  11. Jul 19, 2011 at 6:03 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Please stop speaking in text message speak and speak real english. Thanks.
    For sand, being aired down makes a huge difference. Also, like someone else stated, your mud terrain tires will dig a hole in sand a lot faster than an all terrain tire would which would cause you to bog down more. Also were you in 4LO or 4HI?
  12. Jul 19, 2011 at 6:04 PM
    tacobo670
    Ray
    Las Vegas
    ya i know, they'r pretty beat up from the rocks n trails n stuff.
  13. Jul 19, 2011 at 6:05 PM
    tacobo670
    Ray
    Las Vegas
    i got AT's tried in both hi n lo. but i think i need to make a switch that will make me drive in both at the same time!!!!! mind bottling!
  14. Jul 19, 2011 at 6:06 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Sounds like perhaps they are all heavier than you as well which is not always a bad thing for traction in sand.
    Oh and
    ATRAC!:D
  15. Jul 19, 2011 at 6:06 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Id rather drive slow to the nearest gas station on semi-flat tires than get stuck all day with aired up tires
  16. Jul 19, 2011 at 6:07 PM
    tacobo670
    Ray
    Las Vegas
    word.:cool:
    i concur
  17. Jul 19, 2011 at 6:11 PM
    tacobo670
    Ray
    Las Vegas
    well i guess ill try the airing down next time. n if it dont work, any one interested in some 18in flat black procomp 7033's with MT bajaATZ's 33x12.5 ?? slightly used. still has 70 percent tread.
  18. Jul 19, 2011 at 6:13 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    i just noticed something...you drive a manual...do your buddies as well? maybe your shifting is having an effect on your sinking..? :notsure:
    also..why get rid of the rims?
  19. Jul 19, 2011 at 6:13 PM
    macgyver
    Brad
    Canton, GA
    Also just thought about it...because you have 18's you also have a pretty stiff sidewall so they don't balloon as easily as lets say tires on a 16" wheel.
  20. Jul 19, 2011 at 6:17 PM
    tacobo670
    Ray
    Las Vegas
    one was manual trans like mine, other was auto. the guy with the camper was manual trans, AC 4x4 with ATRAC. i was just joking seeing as how i cant crawl up a sandy hill making my tires worthless for my truck therefore i was going to sell them. it was a joke. im not going to sell them. i've only seen one other tacoma here in vegas with the same rims as i have, n its still sitting in the showroom of the dealership! -true story
