Sand tire pressure
Discussion in 'Off-Roading & Trails' started by DoktorSlowburn, Oct 27, 2024.
  1. Oct 27, 2024 at 1:44 PM
    DoktorSlowburn
    DoktorSlowburn [OP] Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    Hey all!
    I’m out here at Oceano dunes and the taco has been doing just fine. I’ve been running 13psi both front and rear, but I’m noticing that the rear tires don’t have as great of a contact patch as the front. I’ve *almost* gotten stuck a couple times, so I’m wondering- do I need to go even lower in the rear?
    The bed is completely unloaded so it makes sense, there’s more weight in the front.
    I almost feel like running 10-11 in the back and 15 in the front would be better, but wanted to hear if anyone who’s more experienced with sand has any input.
  2. Oct 27, 2024 at 1:46 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Are you on true beadlocks? If not, are you prepared to fix an unseated tire?
  3. Oct 27, 2024 at 1:47 PM
    DoktorSlowburn
    Escondido, CA
    Nope, no beadlocks- but yes, I’ve got the equipment to reseat a tire (or swap for the spare) if needed.
  4. Oct 27, 2024 at 1:53 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    In the case, try 10, but I'd roll slowly. Nothing sucks like unseating and having your rim thrash the sidewall.
  5. Oct 27, 2024 at 2:07 PM
    DoktorSlowburn
    Escondido, CA
    Understood! The sand out here is pretty deep, so I’ve been cruising at like 20mph, maybe 25 if I’m trying to overcome a dune and it’s been working out well. Avoiding hard turns as well, unless the situation requires it. Haven’t been doing badly IMO for my first time in sand.
    I have lugged the engine a couple times going up dunes but I’m getting better at it quickly.
  6. Oct 27, 2024 at 2:09 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Momentum is your friend and make sure you're pointing down when you stop
  7. Oct 27, 2024 at 2:13 PM
    DoktorSlowburn
    Escondido, CA
    Yep, those are the main two things I’ve been trying to keep in mind. That and approach angle- I didn’t get a chance to install my Baja bumper before coming out here so I’m occasionally limited by the stock bumper.
  8. Oct 27, 2024 at 8:40 PM
    DoktorSlowburn
    Escondido, CA
    Got stuck real good after a failed climb, lol. Traction boards and a shovel were my saving grace. Think I probably did a number on my clutch but hey, made it back to camp.
    First time getting stuck though! And was simply because I came backwards down a dune and didn’t see what I was reversing into. Lesson learned :rofl:
    LOLLY likes this.
  9. Oct 27, 2024 at 9:02 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Yeah go a bit lower if you think it’d help with the type of sand you’re on. Rear is lighter so needs less psi than the front.
    Here’s a bit of wisdom from Ronny Dahl
    https://youtu.be/fVS354sgU8o?si=dv69jBNbkNw-ocuk
  10. Oct 27, 2024 at 9:09 PM
    DoktorSlowburn
    Escondido, CA
    What ultimately worked best for me was 14 up front and 11 in the rear. Although when I got STUCK stuck there was no way I could air any further down without popping a bead. Only happened once though and because I was a dumbass and failed a hill climb at night. Still had a good time though! My first ever self-recovery.
    BKinzey and LOLLY like this.
