Sanded or Unsanded grout?
Discussion in 'Garage / Workshop' started by teamfast, Apr 23, 2013.
  1. Apr 23, 2013 at 7:51 PM
    teamfast
    teamfast [OP] Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I did a small bathroom 5x10 and tiled the floor and shower walls. I used the exact same tiles for the floor as the shower and everything was set with 1/8" grout lines. I dont want to buy two separate types of grout as i think i can get the whole job done with one box.
    As I understand the rule is: unsanded for 1/8" or less, sanded for greater than 1/8"
    Can anyone attest to that?
    Thank you!
    I am almost done my basement, just in time for posting season :(
  2. Apr 23, 2013 at 8:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Pretty much.
    Just make sure the mix isn't too wet and you'll be okay.
    When fully cured, hit it with a grout sealer.
  3. Apr 23, 2013 at 8:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sanded is stronger
  4. Apr 23, 2013 at 9:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Agreed... but 1/8" is pushing it for sanded. It can be a bitch to work into the gap.
    Personally, I really like sanded... and it is a little more forgiving of being mixed a little too wet.
  5. Apr 24, 2013 at 6:00 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    i too did 1/8" grout lines in my bathroom tiling, ...believe i used sanded grout w/ some kind of latex modifier additive...
  6. Apr 24, 2013 at 6:10 PM
    dmeko0
    dmeko0 Well-Known Member
    Woodstock, GA
    '15 DCLB TRD Sport
    4" nerf bars, Westin bull bar, Lund tri-fold bed cover, Pop-lock tailgate lock, TRS Morimoto mini d2s bi-xenon/ BHLM'd headlights, LED fogs/dome/map/license lights (jumper)
    you can use sanded, really it's up to you. i've laid thousands of square feet of tile. be cautious as to mixing up pretty close to the recommended specs as far as adding water and additives. keep in mind, the farther away you get from recommended specs the farther away from the desired color you are going to get. some of those mix in additives that are supposed to keep you from having to seal it afterwards tend to lighten up the color more. in my opinion i would use unsanded. as said before, it will be easier to work with. and then use a sealer afterwards. the spray cans are nice because of the ease. good luck
