Sandjunkie '11 Taco Build Up
Discussion in '2nd Gen. Builds (2005-2015)' started by sandjunkie, Oct 15, 2010.
  1. Apr 23, 2012 at 8:46 AM
    #181
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Awesome!
  2. Apr 25, 2012 at 7:16 AM
    #182
    DBitar
    DBitar Well-Known Member
    Danny
    05 PreRunner SR5 LongBed
    Awesome build, i have a radiant red tacoma, and im looking into the ballastic jesters, since you have them, how close do you think the red wash on the rims are in color to the radiant red tacomas.
  3. Apr 25, 2012 at 9:17 AM
    #183
    sandjunkie
    sandjunkie [OP] Well-Known Member
    Aaron
    OC
    Thanks. I think it is very close. The inserts are put on by you so they can be powdercoated/painted a different color if you want.
  4. May 15, 2012 at 8:31 PM
    #184
    sandjunkie
    Aaron
    OC
    I had a slight annoying vibration that I could not diagnose as a driveline or tire balance in the seat of the pants. It caused the passenger seat to shake at speeds greater than 70 mph and was most pronounced on really smooth surfaces. It was perplexing because it seemed to show up immediately following a tire rotation after my lift, wheels, and tires were installed and road force balance. Everything was smooth as silk until I got my truck back from a routine service and tire rotation.
    Today I installed two two parts and the vibration is completely gone.
    The first one is the correct lug nuts from wheelers offroad with the shank to center the wheels on the hub. They are the gorilla splined ones for $1.99 each on this site. The second was these rings to center the wheel on the hub and take up the slack between the wheels and the hub. http://www.amazon.com/gp/product/B00...ls_o02_s00_i00
    So for $50, it's finally glass smooth. Hopefully this will help someone else struggling after new rims. It basically comes down to hub centric vs lug centric and the right parts to make sure a well balanced wheel and tire drive like one.
  5. May 23, 2012 at 3:09 PM
    #185
    sandjunkie
    Aaron
    OC
    Alcans came today!!!:yay:
  6. May 26, 2012 at 10:26 AM
    #186
    sandjunkie
    Aaron
    OC
  7. May 26, 2012 at 11:04 AM
    #187
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    now sir thats a teaser...you need to post up pics of them installed already lol
    or do you need help??? :spy:
  8. May 26, 2012 at 5:04 PM
    #188
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    Sub'd for one of my favorite builds
  9. May 26, 2012 at 10:41 PM
    #189
    sandjunkie
    Aaron
    OC
    Up at the cabin playing this weekend. They'll need to wait. I should be able to knock them out myself with some air tools.
    Thanks Man!
  10. Jun 4, 2012 at 9:25 PM
    #190
    sandjunkie
    Aaron
    OC
    New recovery point. Need to add a D-ring.
  11. Jun 6, 2012 at 10:29 AM
    #191
    kiteboarder
    kiteboarder Well-Known Member
    Danny
    SoCal
    I drive stick. Only.
    To come.
    Wow! Glad I ran into your build thread! Much more detailed photos than the ones on IG. Sick truck man - It's one of the best Tacos I've ever seen!
    -Danny
  12. Jun 12, 2012 at 8:14 AM
    #192
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    pic with the alcan leafs??
  13. Jun 12, 2012 at 6:58 PM
    #193
    sandjunkie
    Aaron
    OC
    Unfortunately, they are still on the garage floor. Every weekend it has been some other priority. I should be able to get them installed in the next couple weeks. Pics will be posted when I do.
  14. Jun 12, 2012 at 6:58 PM
    #194
    sandjunkie
    Aaron
    OC
    Thanks Danny. Lot of fun following you on instagram.
  15. Jun 12, 2012 at 9:21 PM
    #195
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    eh i just saw the pic of your alcans!!! how do you like em?
  16. Jun 12, 2012 at 9:33 PM
    #196
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    Which Alcans did you order for the RCD setup?
  17. Jun 13, 2012 at 5:06 AM
    #197
    zacksblacktaco
    west virginia
    06 trd sport access
    not being nosey but i ordered the rcd yesterday with the alcans. how much were your alcans?
  18. Jun 13, 2012 at 5:17 AM
    #198
    sandjunkie
    Aaron
    OC
    Alcans were $660 shipped with new u-bolts.
  19. Jun 13, 2012 at 5:18 AM
    #199
    sandjunkie
    Aaron
    OC
    They are custom. I had the weight set just a bit over stock with a 4 inch lift and torque spring added to ensure axle wrap would not be a problem.
  20. Jun 25, 2012 at 8:31 AM
    #200
    sandjunkie
    Aaron
    OC
    I ordered custom Alcans which took about a month to get and about another month to get the time to do the install. I ordered them with 4 inches of lift and stock carrying capacity. They also included a torque spring to make sure the axle wrap went away. These things are soo buttery smooth. It's awesome. Vibration and Driveline thunks are non existent. Bumps in the road that were harsh and I could feel the bumpstops hitting on occasion are now taken with ease and no ill shuddering from the truck. All in all well worth the $600 investment. This is how the lift should have been done from the start.
    Stock Leafs with 4 inch Block
    Stock vs Alcan
    Alcan ready for U-bolts
    Alcan Springs
    Straight off the jack stands. It has settled to near perfectly level.
