Sanity check on lift kit choices
Discussion in 'Suspension' started by Pyrotech, Nov 27, 2022.
  1. Nov 27, 2022 at 8:08 AM
    Pyrotech
    Pyrotech [OP] Well-Known Member
    I finally decided it was time to to add a lift to the truck, 2021 SR% 4x4 double cab, bed rack an RTT adds ~ 200lbs of static weight plus RCI gas tank skid. with 300lbs additional at times.
    Front will be getting an SSO slimline winch bumper with Stage 2 high clearance kit. winch TBD
    ICON 05-Up Tacoma Multi Rate RXT Leaf Spring Kit w/ U Bolts - 51101
    Bilstein Toyota Tacoma B8 5160, Shock Absorber, Rear - 25-242539
    Bilstein Toyota Tacoma B8 5160, Shock Absorber, Rear - 25-242379
    Bilstein Toyota Tacoma B8 6112, Suspension Kit, Front - 47-234413
    ECGS Bushing
    plan is run the leaf packs at stage 2, and the fronts for 2" of lift, best I can tell is that will leave me nearly level with a slightly higher rear ~.75"
    is there a must have item that I am missing?
  2. Nov 27, 2022 at 8:30 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Carrier bearing drop might be needed and some aftermarket UCA's in the future ( not necessary but helps). Other than that, look into the bilstein 650 lb springs for the 6112. Other than that, looks good sir
    Road Bull and Pyrotech[OP] like this.
  3. Nov 27, 2022 at 8:43 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Consider a 2 - 3 degree shim for under the leaf spring.
    Pyrotech[OP] likes this.
  4. Nov 27, 2022 at 9:42 AM
    Pyrotech
    I am looking at the dirt king ball joint UCAs in the very near future. I originally had my eye on the SPC but with the miles I drive the life span of those may be a factor.
  5. Nov 27, 2022 at 9:44 AM
    Pyrotech
    thanks, I was wondering how much of a shim would be needed. I will need to refresh myself on measuring driveline angles
  6. Nov 27, 2022 at 9:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Skip the UCA's, skip the goodies you listed and get a set from ADS.
    You're carrying some weight, so why not have shocks valved (and set up) just for your vehicle especially if you're spending good money?
