Sanity check...
Discussion in 'Suspension' started by Bmw2Taco, Feb 17, 2023.
  1. Feb 17, 2023 at 11:16 AM
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    '18 DCSB Sport 4x4 Auto, no additional weight, road truck.
    I have the below on order:
    5100's on all 4 corners
    2887's
    1/4" anti taco lean spacer
    HS AAL (reusing extended U-Bolts from block lift)
    HS 1/2" shims
    OME Carrier drop kit FK29
    I currently have a block lift in rear with tapered shims (supreme suspensions). I also have diff drop installed.
    Do I need HS tapered shims? If so, what degree?
    Needle bearing?
    Just trying to make sure I get it all done while I have the truck on jacks...
    Thank you!
  2. Feb 18, 2023 at 6:27 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    I’m not sure you need shims but I’d do the needle bearing. I am running 887 coils and nitrosports and love them
