Sap stains
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kaykakess, Jun 21, 2022.
  1. Jun 21, 2022 at 9:02 PM
    Kaykakess
    Kaykakess [OP] Member
    Sooooo if pine sap hardens on my hood… I took goo gone to it and removed all sap but what do I do to get rid of the nasty stain it left. Or is my paint ruined now.
  2. Jun 21, 2022 at 9:04 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    WD40 works- test a spot first.
    ScrippsRanch67 likes this.
  3. Jun 21, 2022 at 9:30 PM
    Kaykakess
    I got the sap all off but it’s like a bubble stain. Left over
  4. Jun 21, 2022 at 9:36 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Is the clear coat still there? Often when sap bakes on, it etches the clear coat.
  5. Jun 21, 2022 at 9:40 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Friend of mine parked his new, and I mean brand new Toyota Hybrid RAV4 under a tree for a spell and it is royally f*cked.
    We tried all manner of cleaning it up but it wouldn't come off.
    He could care less, but I was aghast ...
  6. Jun 21, 2022 at 9:44 PM
    Kaykakess
    The clear coat is grey bubble looking under where the sap was
  7. Jun 21, 2022 at 9:49 PM
    Kaykakess
    I need my clear coat back it’s a brand new truck my soul hurts aha
  8. Jun 21, 2022 at 9:54 PM
    dfanonymous
    Yeah, sounds like you might need to go pick up some touch up
  9. Jun 22, 2022 at 4:44 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You need a professional ceramic coating to prevent those sap stains, or bird poop ruining the finish on these trucks. My truck gets covered with both. Some warm water and a rag usually takes them right off with no ill effects. I recently had a good layer of baked on bird poop i'd been ignoring. I finally removed it with some extra elbow grease. Didn't see any imperfection s in the finish after over 2 1/2 years. That stuff simoniz used is amazing.
  10. Jun 22, 2022 at 4:59 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    Gel hand sanitizer works on those drops of sap. Put just enough to cover the sap and let it set a few minutes then wipe it off. Might take a few times depending on how thick it is. I keep a little bottle in my truck just for that.
  11. Jun 22, 2022 at 8:34 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Send some pics. I know exactly what you're talking about here. Buffing the paint should remove the stains, but it's ideal to try other methods before cutting into the clear coat.
  12. Jun 22, 2022 at 8:36 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    alcohol, goo gone, polish, road tar remover, acetone, clay bar. lots of options. i'd probably try some some alcohol or clay bar first.
    my coworker got bleach or some other caustic chemical on his gloves and i had a dull area of paint on my door. where he touched it nothing would get it out so i used a tiny bit of polish and it removed it in 10 seconds.
  13. Jun 22, 2022 at 8:37 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Id probably clay it....if its etched, will need buffed. If its deeper than that your screwed.
  14. Jun 22, 2022 at 9:10 AM
    Lphonzy09
    Lphonzy09 Well-Known Member
    Texas
    2022 Midnight Black Metallic SR5
    Everyone has a smart phone, you should post some pictures of the "damage"
    I would buy some buffing pads if you have a household drill (surprisingly, these do the job if you know how to buff)
    Amazon.com: Car Foam Drill Polishing Pad Kit 22 PCS, 3 Inch Buffing Pads : Automotive
    Watch youtube videos on how to buff. That is important. Utilize some Compound (griots garage) from AutoZone (this specifically is noobie friendly as it stays "wet" so you don't burn the paint).
  15. Jun 22, 2022 at 1:34 PM
    05 4x4
    05 4x4 Well-Known Member
    on the first rain of the year redwood trees drop a staining dust on the cars and if it gets wet you cant get the stains out... It has happened to me twice on white cars and both times my detailer was able to get it out with a clay bar and a typical exterior detailing, although I am sure he works some magic on it... Just send it to the detailer or try some clay bar yourself and some type of clear coat paint correction and polish.
  16. Jun 22, 2022 at 1:52 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    this
    I would try to get a professional detail person to tackle it. If it etched into the clear it may be a matter of how deep before you need some form of refinish. Start with the least invasive, and get a professional. Why guess and take chances when not sure what to do when a reputable and knowledgeable detailer may have seen and dealt with it before.
