SAS info. 90 model truck, Trans questions.
Discussion in 'Toyota Trucks & SUVs' started by luk8272, Jun 16, 2010.
  1. Jun 16, 2010 at 4:20 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My truck has the 3.0 and to mine and the previous owners knowledge it is stock. I'm the 3rd owner. The 2nd owner purchased it in 92. The reason for this info is because to my knowledge all v6 trucks came with the Chain driven T-case.
    However this truck has the Gear driven case, which should only be found on the 4cylinder trucks.
    I was getting a list of parts together as well as money, but now I need to know what is needed to get me from the T-case to the solid axle? This is what I was going to get but now i'm just lost.
    http://www.marlincrawler.com/transfer-case/t/c-adapters/1988-95-3vz-e-30-liter-v6-drivetrains
    Yes I have never done this before so please give good useful advice none of the "if you don't know you shouldn't be doing it" because we all need to learn somewhere. Thanks.
  2. Jun 16, 2010 at 4:23 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    The V6's came with the chain driven t-cases. The 22re came with the gear driven. Marlin can get you the crawler box and whatever adapters you need
  3. Jun 16, 2010 at 4:24 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I have corrected my original post. Thanks I hadn't caught my mistake.
  4. Jun 16, 2010 at 4:30 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I screwed up my first post. lol
  5. Jun 16, 2010 at 8:05 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    What do I need to go from my Tcase to the front axle?
    I don't know what the exact reason for having to swap from a chain driven to a gear driven case is(would someone like to explain). Why did I need the Tcase adapter with the chain driven case?
  6. Jun 16, 2010 at 8:39 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Thank you for filling that in. It was driving me $%^&ing nuts. I was looking at it and wondering why my shaft wouldn't be sufficient. I was told I had to have the adapter with the chain driven case. Couldn't figure out why. Then realized my truck for some odd reason had a gear driven case and then wanted to know what if anything I would need to mate the case to the axle. I looked at what I had here and was at a loss for why things just wouldn't go right together, it looked like it would to me.
    But now i want to know why my v6, auto has a gear driven case? everything I read says that v6 only came with chain driven.
  7. Jun 16, 2010 at 8:52 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    This all started with some poor info and half hearted knowledge, but it was enough info to get me into trouble. lol. I looked at it for a while and couldn't see the reason it wouldn't work, chalked it up to inexperience on my part.
    Thanks man it was driving me batty.
