sas question "axles" to be specific
Discussion in 'Suspension' started by Yota_dvl, Nov 19, 2010.
  1. Nov 19, 2010 at 12:39 PM
    Yota_dvl
    Yota_dvl [OP] Well-Known Member
    Jesse
    Central Utah
    03' Ext cab 4x4
    SAS KIT - trail-gear 5" lift alcan springs greasable shackels gears front 410 rear 411 Kicker subs 3,000 mile drive to Alaska, 3,000 back "Mod" rear diff breather
    what axle would work best for cheap ?
    ... i dont want to build a new one for it (that gets pricy) so i wanna pull an old axle. i know that i could pull it for a 79-85 truck or runner but then its shorter width wise then the rear,. I cant find one off a land cruiser... so where do i find one thats close to a dana 44 with 6 lug bolt pattern with the pumpkin on the correcct side ? ... will older chevy axles work?
  2. Nov 19, 2010 at 7:39 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    jeep wagoneer if i remember correctly.
  3. Nov 19, 2010 at 7:47 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    87-91 Jeep Grand Wagoneer front axle is one option.
    Do some google searching and you'll find many options. Just depends on what you wanna do.
    I'm personally familiar with the Waggy axles cuz I put an 89 under my jeep. It's 61" WMStoWMS, same lug pattern, no vacuum disconnect, 11" disc brakes, yadda yadda yadda.
  4. Nov 19, 2010 at 7:47 PM
    Blue
    Dylan
    Sierras
