SAS using Toyota Axle?
Discussion in 'Solid Axle Suspension' started by OLIVER2010, Oct 16, 2016.
  1. Jun 1, 2018 at 12:48 PM
    #81
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    There are two downsides to the 80 axle
    - steering if you want to run leaf springs SOA, there are only a couple options, sleep high steer arm which I think you can only run heims with, and hellfire (now ruffstuff) knuckles which are expensive. If you link or run SUA leafs it’s a non issue.
    - the wheel hubs are scalloped on the side, so you can’t add additional dowels for the wheel hub to locking hub interface, not a big deal but if you are pushing the limits with gearing, chromo shafts and big tires this interface becomes the weak link.
    Ultimate Toyota axle is 80 knuckles with a 9.5 third.
  2. Jun 1, 2018 at 1:47 PM
    #82
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Werd
  3. Jun 3, 2018 at 8:24 PM
    #83
    la0d0g
    running for the hills
    For crawling not hauling
    I like this thread. Makes me appreciate my ghetto garage build. It's all mine and all my work so when I break it I will just blame my shitty welds! :D
    Adude likes this.
  4. Jun 4, 2018 at 7:09 AM
    #84
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    Is a LP 9.5 really that much stronger than a HP 8" ? Serious question because I can't recall a direct comparison.
  5. Jun 4, 2018 at 7:43 AM
    #85
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Yes.
    slander likes this.
