Sat for 2 weeks in Galveston and then,
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scottybob6, Feb 3, 2019.
  1. Feb 3, 2019 at 11:52 AM
    scottybob6
    scottybob6 [OP] Member
    David
    2016 white Tacoma SR5 4 wheel drive
    Century topper
    Hey guys, just returned from a 2 week cruise and was parked in a 'secure' outdoor lot at the port of Galveston, TX. When I started my truck I notice I had no outside temperature reading. I thought this was strange as everything was working when I parked it. I payed little attention to it as I needed to get 3 other people loaded with luggage and on our way. Half way to Dallas from Houston I noticed my 'check engine' light had come on. I am due maintenance soon as I'm at 38K miles. Made it to my brothers house outside Big D and on the way to dinner my cruise control quit. I was doing 65 and it just quit. Would not come on no matter what. I drove it on to dinner and now I have no cruise control, check engine light and maintenance triangle lit up. Once dinner was done we left and when leaving the parking lot my 'TRAC OFF' w/ squiggly lines showed up on the dash. I decided I would wait until today to get with you guys to see if anyone ever had something like this before. Long story short, I just went out and started it up and the only thing showing is 'Maintenance Triangle' & no 'outside temp', I haven't tried cruise yet but no 'check engine' and no 'TRAC OFF'. Do you think it just missed me for two weeks and was being a little 'pissy'? Not sure what to think but once I get back on the road later today I'll post an update. Thanks for taking the time to read this lengthy post, I'm just a bit confused....
  2. Feb 3, 2019 at 11:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    You need a scan tool to pull set codes. Anything else is guess work. Not that someone can't guess right, but..........
    Still in warranty? Let the dealer do it.
    Out of warranty? You need to be finding a quality independant shop anyway.
    Even semi technically savvy? Get a scan tool and DIY.
    Or the 'quick and dirty' would be a parts house free scan, record the codes and research them.
    crackils and scottybob6[OP] like this.
  3. Feb 3, 2019 at 11:58 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My money is on rodents. Look for signs.
  4. Feb 3, 2019 at 12:16 PM
    scottybob6
    David
    Century topper
    Thanks guys, I have a scan tool but it's over 1000 miles away at home. I'll do a visual and check for rodents. I appreciate your input.
    toyotatacomaTRD likes this.
  5. Feb 3, 2019 at 12:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm guessing this will wind up in your in-truck tool bag in the near future........
  6. Feb 3, 2019 at 1:10 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    I second rodents. Especially around that wharf. Or worse, crabs...
  7. Feb 3, 2019 at 1:18 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Have you looked under your hood?
  8. Feb 3, 2019 at 1:40 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Nothing worse than coming home from a cruise to find out you got crabs.:eek:
  9. Feb 3, 2019 at 2:03 PM
    scottybob6
    David
    Century topper
    I made a fairly thorough inspection under the hood and did not see any obvious indications of damage from rodents. No frayed wires or any rat pellets but still don't have the outside temp. I drove it on the highway for a bit and 'cruise control' is working again, no 'Check Engine' light and the 'TRAC-OFF' not lit up, still have the 'Maintenance Soon' triangle. I'll post again when I get to the bottom of this. Thanks for your input,
  10. Feb 3, 2019 at 2:22 PM
    toyotatacomaTRD
    Was there any flooding during that 2 week window?
  11. Feb 3, 2019 at 2:38 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    When you initially started your truck, did it start right up or was the starter a little slow? I'm curious about the condition of your battery. I have seen a low and/or defective battery cause all of your listed symptoms other than the outside temperature issue. A voltage draw then surge can cause all sorts of strange things to occur.
    If you have access to a battery charger I would recommend completely charging the battery. Driving around usually will not accomplish a 100% charge. Make sure your battery is holding a charge. Some auto parts stores will check it for free. Before having it tested, you need to remove the surface charge that's created when you drive. With the engine off, turn on your hi-beam headlights for about 30 seconds. That should draw down the surface charge. Then have them test your battery. If it's the original battery it may be going bad. I've seen the stock battery last anywhere from a few months to several years. There is no consistency with their longevity.
    I would also disconnect a battery terminal and leave it disconnected for about half an hour or more. This will usually reset your computer. Yes, your codes will also be erased so when you get your OBDII scanner hooked up the initial error codes will probably be gone. If there is really a problem other than what was caused by low voltage when you first started your truck, the trouble codes will once again appear. Maybe a reset will also fix the outside temperature issue.
    If you have a multimeter you can also check the battery voltage. Again, the surface charge must be removed. At 100% charge the battery should read 12.73 volts. A 90% charge is 12.62 volts and a 50% charge is 12.10 volts.
  12. Feb 3, 2019 at 2:45 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah just go to a parts store and have em pull codes. Then Google the codes. I'd guess rodents as well.
    scottybob6[OP] likes this.
  13. Feb 3, 2019 at 2:46 PM
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    This is good information, my battery died out of NOWHERE one morning when I went fishing. Truck started right up as I went to get food and then got to my usual bait catching spot. The truck remained on since I left my apartment and was not shut off until I arrived at my bait spot. I was there for 15 minutes then got back in my truck and it would not even crank. Battery was completely DEAD. It would just click rapidly until I pressed the Start Stop button again. I tried a jump and couldn't even get my headlights on with the truck off. I had to get a tow to an autozone and the thing read 4 volts! 4 VOLTS! That's absurd. 2016 Truck and the battery died a little over 2 years later.
    Just relaying my experience in case it helps you consider more choices as to what could be wrong.
  14. Feb 3, 2019 at 8:42 PM
    scottybob6
    David
    Century topper
    No flooding to my knowledge AND it is the original battery. I'll check that next, also my outside temp gauge became operable again. I'm going with battery for now. I'll post when resolved. Thanks to all of you, much appreciated.
  15. Feb 3, 2019 at 8:49 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Check your air and cabin filter for signs of rodents
  16. Feb 4, 2019 at 12:03 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Loose battery cables will also do weird things.
  17. Feb 12, 2019 at 2:41 PM
    SD Quicksand
    Alex
    San Diego, CA.
    @scottybob6
    Anything new? Update??
    Just curious. Thanks
  18. Feb 12, 2019 at 3:08 PM
    scottybob6
    David
    Century topper
    Battery checks out fine after 1,000 mi return trip even though it's 3 years old. Best we can tell, and that is talking with my dealer and a couple of other knowledgable folks, is there was an accessory left plugged in (but was turned off) and though it was ever so slight, the drain most likely caused the battery to come down just enough to not supply the onboard electronics with proper power. Thank you all for your input.
    shakerhood likes this.
  19. Feb 12, 2019 at 3:18 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Yep
    Just went through thjs
  20. Feb 12, 2019 at 3:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    So everything is working like normal again?
