sat xm qusetion
Discussion in 'Audio & Video' started by panamavic, Apr 11, 2013.
  1. Apr 11, 2013 at 5:33 AM
    panamavic
    panamavic [OP] Member
    i have a 2009 tacoma with the satelite shark fin antenae on the roof. When i push the sat xm button on the radio nothing happens. Is there no module installed or am i missing something?
  2. Apr 11, 2013 at 5:50 AM
    TacomaBuilder67
    TacomaBuilder67 Well-Known Member
    San Antonio,TX
    '12 PreRunner DCSB V6 TRD Sport MGM
    Bull Bar, KC Apollo Lights, LED interior lights, TRD Center Caps,Tailgate Anti Theft Mod,TRD Shorty antenna,
    Do you have a Sirius/XM subscription?
  3. Apr 11, 2013 at 5:52 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    You probably don't actually have the tuner. That's how my 2009 was. Give you the antenna and say the truck is "xm ready" then make you spend a few hundred bucks for the actual tuner.
    But then yea you'd obviously need a subscription however without it you'd still get the preview channel of the tuner was installed.
  4. Apr 11, 2013 at 6:05 AM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
  5. Apr 11, 2013 at 6:23 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    This. In my 09 i bought a aftermarket headunit, the shark fin adaptor and a $20 siriusxm receiver. An for some reason it works without a subscription. Have had it almost a year and haven't paid a dime :D
  6. Apr 11, 2013 at 6:41 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    Sirius IS xm now. Your 09 is just sat "ready" meaning the shark fin on top is wired and ready to be used, but you don't have the sat receiver installed which is why the xm button doesn't do anything. The thread linked above is probably the best resource to figure out what you need.
    Options for sat on the 09 are: 1. do what the thread above did
    2. buy the Toyota oem tuner from a dealer, you can find the part online and directions on how it installs.
    3. buy an aftermarket head unit - but if you do that I think you still need a sat tuner as well.
    I have the set up described in the thread and love it, having steering wheel controls and no wires anywhere is really nice. Search on here for sat. threads, there are several. One I was just reading is how a guy set up a portable sat receiver and is using his sunglass storage to put the interface.
    There are advantages to getting a plug N play unit, some of them have song and/or artist alerts that will indicate when your favorite is playing on another station, and some have built in memory buffers so you can rewind and listen to something you missed, like if you stopped for gas or something. It's a trade off and I don't think you can ever have those features if you have steering wheel controls.
  7. Apr 11, 2013 at 6:50 AM
    jlleiber
    Justin
    Indiana
    2009 TRD Sport
    Coming soon!
    Yep this is perfect. Aftermarket headunits that are "sat ready" also need a tuner specific to the brand of the headunit. Another benefit I noticed with having a plug N play was that it was wayyy easier to jump between channels that aren't presets and navigate by genre, etc. However, nothing beats the clean look of having everything stock. Pros and cons..
  8. Apr 12, 2013 at 4:06 AM
    panamavic
    thats what i figured. One last question. If i buy a used stock xm ready radio from a seller on here is it difficult to install?
  9. Apr 12, 2013 at 4:19 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Its pretty easy. You said you have the sat xm button though, so i think that means your head unit is xm "ready"
  10. Apr 12, 2013 at 4:19 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    I think installation is going to depend on having a wiring harness or not. If you have a plug N play harness it should be easy, at least taking the stock head unit out is easy.
  11. Apr 12, 2013 at 4:26 AM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    I bought a stock head unit with xm from a member. The difference in the one thats just xm ready and the one that actually has the sat receiver installed is a blue plug on the rear of the unit. The one with the blue plug is the one you want.
  12. Apr 12, 2013 at 4:33 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    You still need the antenna wire though right? The one that plugs in under the drivers side kick panel
  13. Apr 12, 2013 at 4:58 AM
    jshsltr
    Josh
    St Louis
    That is quite possible. I have a 2007, so no shark fin or wire. I bought an aftermarket antenna. I then disassembled the head unit and removed the toyota antenna connector in order to connect the new antenna to the receiver.
