Satalite radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dads truck, Jul 28, 2018.
  1. Jul 28, 2018 at 3:16 PM
    Dads truck
    Dads truck [OP] Active Member
    Stephen
    Uniontown Pa
    White 07 Tacoma
    Did any second generation Tacoma’s come with satalite serious XM. If so, how can I install one in my 07? I don’t want anything after market.
  2. Jul 28, 2018 at 3:38 PM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/MD
    2013 DC TRD-OR 4x4 Pyrite Mica
    There were definitely radios in the 05-11 model years that came from factory with sat. I have a 2013 tho (one of the years that Toyota took away SAT for whatever reason) so my guidance ends there.
    You’d be looking for a 2005-2011 radio specifically so it will fit without changing dash parts. You’d also need the corresponding antenna.
  3. Jul 28, 2018 at 4:29 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    all the stereos are compatible, you need the receiver (small black box on roof) and there's an adaptor you have to buy from the stealership which is a few hundred dollars. It connects to your kicker panel.
  4. Jul 28, 2018 at 4:33 PM
    DrFunker
    DrFunker Prisoner of the little people circus
    o_O
    I do not cumpuute.
    PackCon likes this.
  5. Jul 28, 2018 at 4:36 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Cypress Texas
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    My 2012 has factory satellite radio
  6. Jul 28, 2018 at 6:15 PM
    Dads truck
    Stephen
    Uniontown Pa
    White 07 Tacoma
    Thanks. At least I know the option is available and possible. I appreciate the help
  7. Jul 28, 2018 at 7:35 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Yeah. You should make the modification. As I'm sure you know, you'd enjoy/use it every day.
  8. Jul 30, 2018 at 9:13 AM
    PackCon
    PackCon Well-Known Member
    Connor
    Super White 2013 TRD Sport DCLB - 2002 Ford F250 SD
    If it’s not stock... it’s aftermarket...
    So looks like you need to buy a used 2nd Gen that came with stock Sat radio.
  9. Jul 30, 2018 at 10:27 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I have an Alpine CDE-HD149BT satellite compatible single din radio in my 2013. I got it from Crutchfield and they had a Sirius satellite adapter and wiring harness for the Toyota. A few too many features for me but it works well enough and I enjoy satellite radio. They probably have newer radio models by now but this is ok. It was not that expensive if I recall it's been a few years since I bought it. I like the extra dash cubby from the single din conversion too.
    Edit: The sound is FAR better than the stock Toyota Touch screen radio. Not impressed with oem radios by and large, UNLESS it is a factory premium optional system.
