satellite antenna pre wired
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cheech5930, Sep 23, 2016.
  1. Sep 23, 2016 at 8:01 AM
    cheech5930
    cheech5930 [OP] New Member
    john
    2010 tacoma
    I have a 2010 tacoma double cab (satellite radio receiver pre wired & antenna).
    Having problem locating antenna wire pulled head liner down under rear roof see antenna wire which is plugged into rear light on roof what to do.
  2. Sep 23, 2016 at 10:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Sep 23, 2016 at 11:09 AM
    cheech5930
    john
    2010 tacoma
    I have the Toyota part 86180-0w032 reciever I pulled down rear head liner to see stock satellite antenna the wire is attached to something. DoI just have to run an antenna wire
    from the receiver to kick panel connection.
  4. Sep 23, 2016 at 12:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Got it. I was reading your original post incorrectly. Yes, there is a connection box behind the kick panel on the driver side that the shark fin antenna terminates at. You will need to remove the kick panel to determine what is needed but you will likely need to run a new cable from that point to your OEM radio. Because it is OEM, I don't think the adapter I linked in the earlier post will work.
  5. Sep 23, 2016 at 4:57 PM
    cheech5930
    john
    2010 tacoma
    ordered parts will be installing when they arrive thanks again
