Satoshi grill bondo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TonkaToyTaco, Aug 18, 2011.
  1. Aug 18, 2011 at 8:23 AM
    TonkaToyTaco
    TonkaToyTaco [OP] Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Can anyone help me with which Bondo or what I should use for my satoshi grill? I need a filler for the inside of it and I have been looking at the write ups and it really doesnt give me what type I should get.
  2. Aug 18, 2011 at 8:29 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Go to Autozone... ask for bondo
  3. Aug 18, 2011 at 8:36 AM
    tacoriffic
    tacoriffic Well-Known Member
    Greg
    Rhode Island
    Clarion CX609 HU, Satoshi Grill, More to come
    It depends. I used the Bondo brand glazing putty, sold in a tooth paste like tube. It worked great. You might need 2 tubes. If you want to bondo the whole thing or not to experienced, you might want to get the tub of bondo. Which might require hardner.
    I don't have much auto body experience, but the glazing putty was the easiest to work with, for small jobs like this. Also the grille has held up great.
  4. Aug 18, 2011 at 9:04 AM
    TonkaToyTaco
    Louie
    thank you for that advice. Im def not experienced and want the easiest thing. So ill try that than. The hardener is that sold near the putty?
  5. Aug 18, 2011 at 9:05 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I used the ole tub 'o bondo
  6. Aug 18, 2011 at 9:52 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Autozone or any auto parts store. Small tub of Bondo brand Bondo. Lol. Comes with hardener. About 8 bucks.
  7. Aug 18, 2011 at 11:04 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    I used...[​IMG]
  8. Aug 18, 2011 at 11:08 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ^^ exactly it. Lol.
  9. Aug 18, 2011 at 12:35 PM
    pinktaco808
    pinktaco808 Hot Steppa
    yeeepppppp
  10. Aug 18, 2011 at 12:45 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I used the same stuff, it worked really well
  11. Aug 18, 2011 at 12:46 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    or cut up the shape of what your filling in with the plastic part of the grill you have gutted... then epoxy it on or bondo... that way you dont have much to fill in
  12. Aug 18, 2011 at 1:03 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I did that but with fiber board. That particle board that has the white coating on one side. Forget the actual name of It. cut it a little longer then the space that needs to be filled. Epoxy It to the plastic. Then you can sand the edged down to fit and have the perfect curve needed for the Satoshi grill. Then fill with Bondo. Has held up for the passed 3 months since I did it.
  13. Aug 18, 2011 at 1:21 PM
    tacoriffic
    Greg
    Rhode Island
    Yeah, in the same neighborhood of items. Whatever product you get, make sure the room is ventilated. They all stink. And also let it dry good.
  14. Aug 18, 2011 at 2:24 PM
    pinktaco808
  15. Aug 18, 2011 at 2:58 PM
    morphius
    morphius Well-Known Member
    Santa Clara, CA
    2010 4x4 Access Cab TRD Sport
    After fitting a cut out piece from leftover grill, I used JB Weld as the filler material (since I had some lying around). Others use fiberglass mesh and Bondo.
    After I sanded down the JB Weld, I used Bondo glazing compound to fill in small voids. I sprayed a light 'witness' coat of primer and wet sanded to find any high/low spots that I smoothed out with additional glazing compound.
  16. Aug 21, 2011 at 1:33 AM
    808TUNDA
    808TUNDA Well-Known Member
    D
    Oahu, Hawaii
    same here.
