Satoshi grill mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XGR50.2, Mar 18, 2010.
  1. Mar 18, 2010 at 8:17 AM
    XGR50.2
    XGR50.2 [OP] Active Member
    David
    West Texas
    05 TRD
    I've been through a few tutorials and I don't know how people are mounting the mesh on to the grill.
    I have a rectangle of mesh, and after I cut it to size how do I go about mounting it?
  2. Mar 18, 2010 at 8:19 AM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    go to lowes and get these things that are used to screw down and zip-tie things to. except don't screw them... use epoxy glue/fiberglass reson and use a lot of zip-ties.
  3. Mar 18, 2010 at 8:22 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
  4. Mar 18, 2010 at 8:23 AM
    l_prettyman
    Logan
    06 4x4 SR5
  5. Mar 18, 2010 at 8:53 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    ^ well done! :thumbsup:
    what brand epoxy did you use? strong bond between the aluminum and plastic?
  6. Mar 18, 2010 at 9:15 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    what about fiberglass to aluminum bond where the mounts are on the sides?
    I'm still trying to figure out a good bond. Could I use fiberglass resin you think?
