Satoshi/Grillcraft - How Do You Open The Hood?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Oct 14, 2012.
  1. Oct 14, 2012 at 6:51 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2010 Access Cab SR5 4x4 5 speed 2.7l
    Fog lights with OEM switch - Heated mirrors with OEM style switch - Cab sound deadening - Lighted 4x4 switch - URD short shifter - Rear backup camera - 2012 rear view mirror (compass, outdoor temperature and backup video mirror) - Heated seats - 2014 Tacoma stereo install - Bluetooth with OEM steering wheel controls, Access roll-up tonneau cover
    Hope this isn't one of those questions where the answer is embarrassingly obvious but how do you open your hood if you have one of these grills installed.
    When I pop the hood from the interior of my truck I still have to go around the front, reach around the Toyota emblem and lift the hood catch to unlock the hood.
    Wouldn't one of these grills totally block your hand from accessing the hood catch?
    Did a search but couldn't really find an answer on the forums.
  2. Oct 14, 2012 at 6:52 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I never opened the hood through the grille. I didn't know that was possible. Ha.
  3. Oct 14, 2012 at 6:53 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That's what I thought. There is a little handle you push just below the hood and just above the grille. OP is doing it the hard way I guess......
  4. Oct 14, 2012 at 6:54 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Stick your fingers between the hood and top of grill :)
  5. Oct 14, 2012 at 6:56 PM
    himmie
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    Yup, that's what I do. That's what I do with all of our Toyotas. The latch is on the same side on all of ours too.
  6. Oct 14, 2012 at 6:56 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    if u had owned a 1st gen, this would be a concern because to open the hood u must stick a finger in between the vertical space in the grill to release the hook.
    if u owned a 2nd gen, u would know that the hood release hook is above the grill. so when u pop the hood latch, u lift up the hood a little so there is space between the hood n the grill, stick a finger in, n it opens right up. (pun intended)
  7. Oct 14, 2012 at 7:04 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
  8. Oct 14, 2012 at 7:16 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    Fortunately there's two ways of doing this hood release :) I only knew of the upper one for the longest time
  9. Oct 14, 2012 at 7:18 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    lol. OP you doing the hard way. that i thought was impossible. lol. i just pull the latch on the inside, go to the front lift hood a little and stick fingers between the top of grill and hood and release that latch.
  10. Oct 14, 2012 at 7:19 PM
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    My 2000 opens with the finger between grill and hood method. Two fingers works better. :D
  11. Oct 15, 2012 at 7:26 PM
    mash25
    mash25 Roll Tide Roll
    Mark
    Bama
    '08 DC Sport 4X4..
    TGC 3'' lift,18'' Addicts,33'' Trail Grapplers
    :rofl:
  12. Oct 16, 2012 at 10:01 AM
    Molon Labe
    Molon Labe Never LBS
    Metro Atlanta Area
    2012 Spruce Mica DC 4x4 Auto V6
    see my build
    I did a Satoshi on my 2012. I cut off 2" of the under the hood latch for the grill clearance. I can still pop it between the hood and the grill once the interior latch is activated. No big issue.
