Satoshi GrillCraft *How To* w/ pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Klipp11, Feb 18, 2010.
  1. Feb 18, 2010 at 3:17 PM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    decided to install a grillcraft on my tacoma so i can mount some hellas behind the grill down the road
    after considering the fiberglass / bondo method, i decided on another route. i fabricated a piece of oem plastic from the crossmember to fit perfectly in the gap left from the cut, then used an epoxy resin to set it in. very strong...
    check it out:
    oem grill
    remove the grill by removing the two plastic flare clips using a flathead screwdriver
    and 2 bolts with a socket
    then lift the grill straight up to release the two clips holding the bottom of the grill
    tested the grillcraft by placing it on top; fits good
    next cut the 2 crossmembers out of the center of the grill (use a reciprocating saw or dremel with a cutting wheel)
    if you want to mount the gc flush, you're already done at this point. (just drill a couple holes and fasten the gc to the grill using the hardware that comes with the kit)
    personally, i wasn't thrilled by how it looked on my truck and wanted to see how it looked satoshi'd...
    cut the crossmembers in half and dissect the only two pieces of flat plastic from them like this
    to yield this
    trace a template of the piece you want to make using a sharpie and some cardboard
    then cut your template from the cardboard with scissors and trace it on the plastic. then use a cutting wheel to carve it out
    fine tune your insert until it fits nice
    when you're satisfied with the fit, epoxy it from the back (make sure you sand down the edges of the bonded surfaces so the epoxy has somewhere to go and cement the two together), let dry for 15 minutes, then sand it down so it looks like this
    then apply a coat of finishing putty
    and sand with 320 grit until smooth and the edges of the putty blend in smoothly to the plastic, then use 400 grit to finish it off
    tape it up
    and paint it (i used flat black trim spray paint). use 2-3 thin coats, letting it dry thoroughly between coats
    remove the tape, drill a couple holes to fasten the gc to the back of the grill, and you got yourself a damn nice grill!! :D:thumbsup:
    Bravisimo likes this.
  2. Feb 18, 2010 at 3:23 PM
    ekard
    ekard Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    Wow, that seems a lot simpler than the fiberglass/bondo approach. Nice thinking!
    Let us know how it holds up over time.
  3. Feb 18, 2010 at 3:25 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    Great thinking and very nice write-up +rep for you!
  4. Feb 18, 2010 at 3:27 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    Very good idea
  5. Feb 18, 2010 at 3:28 PM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    dude, this epoxy is the shit. after setting for 5 minutes, i could hold up the entire grill surround by the piece i bonded to it. also used it on my fender flares when i trimmed to fit the 305's. it's a two part resin that mixes together in the nozzle when applying and cures in under a minute
  6. Feb 18, 2010 at 3:37 PM
    TJ Asher
    TJ Asher Well-Known Member
    TJ
    Minneapolis
    '10 Virgin
    Great write up and pics. Makes a complicated mod look simple.
    +1 rep for you!
  7. Feb 18, 2010 at 3:38 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Nice looking grille! Your steps were similar to HBMurphy, I think the difference is he used ABS glue to bond the two plastics.
    Do you think there will be any problems with the plastic flexing a little causing the paint to crack and show the seam? I might have to try this method because I personally am sick of the fiberglass mess.
  8. Feb 18, 2010 at 3:39 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    great write-up and pics. Looks really good
  9. Feb 18, 2010 at 3:42 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Nice write up! I am not so nervis to do this mod now!
  10. Feb 18, 2010 at 3:44 PM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    thanks for the easy way!!!!
  11. Feb 18, 2010 at 3:45 PM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    i can't see it cracking. that's why you just mist the paint on over a couple of layers. and the epoxy is so solid that it won't allow any movement anyway
  12. Feb 18, 2010 at 3:46 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Can you post a close up pic of how you mounted the grill craft to the grill?
  13. Feb 18, 2010 at 3:51 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    awesome job! :thumbsup:
  14. Feb 18, 2010 at 3:52 PM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    yeah sure. i'll take a pic for you tomorrow and post :)
  15. Feb 18, 2010 at 3:53 PM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    thanks aaron, that means a lot coming from mr. satoshi himself!! :D
  16. Feb 18, 2010 at 3:53 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    2nd! Post up some more pics... installed too :D
  17. Feb 18, 2010 at 3:56 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Great job, looks great. :thumbsup:
  18. Feb 18, 2010 at 4:03 PM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    subscribed. looks awesome!
  19. Feb 18, 2010 at 4:04 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    +1 for you. Satoshi mods seems easier doing it that way!
  20. Feb 18, 2010 at 4:07 PM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    needs to be made a sticky
