satoshi help :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hitaco, Aug 2, 2010.
  1. Aug 2, 2010 at 2:04 AM
    hitaco
    hitaco [OP] Active Member
    wahiawa
    07 tacoma
    Dual exhaust flowmasters 40 series, H.I.D. projection kit 6000 black out tint, black wheel mod, dome and map light L.E.D. cool white ^_^
    so everything was going smoothly until i had to attach the grill, so how did you guys attach it? i was thinking of glueing it, but would look kinda generic :p
  2. Aug 2, 2010 at 2:28 AM
    rvcahawaii808
    rvcahawaii808 Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
  3. Aug 2, 2010 at 2:39 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    x2...
    Zip ties and those little mount things that are right next to them at Home Depot, and some Gorilla glue to attach the mounts to the grille for good measure. Mine have been on for 8 months with no problem. :p
  4. Aug 2, 2010 at 3:37 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Duct tape
  5. Aug 2, 2010 at 4:37 AM
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    The OP from the satoshi how to used two part epoxy and every four inches or so around the outside of the existing grill. Then dropped into each epoxy point those pieces (that the guys above my response said was next to the zip ties @ home depot), followed by attaching zip ties, and cutting the excess zip tie off.
    Good luck, and wait 5-10 after you attach the zip tie holders before you secure your mesh on.
  6. Aug 2, 2010 at 5:00 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    epoxy bolts to the grill then bolt the satoshi screen to the grill
  7. Aug 2, 2010 at 5:33 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Did you cut the heads off the bolts?
  8. Aug 2, 2010 at 5:35 AM
    Burgman
    Stephen
    Ric VA
    yea Susan i chopped the heads off, i feel like it could take a baseball and keep going.... make sure to scratch up the plastic b4 u epoxy to make it adhere well enough
  9. Aug 2, 2010 at 6:17 AM
    ImpulseRed008
    Susan
    SC
    :thumbsup:
  10. Aug 3, 2010 at 3:47 AM
    hitaco
    wahiawa
    07 tacoma
    thanks for all the reply's 2mwr ima start fixing it right up with the epoxy method, n for good measure i'll also use zip ties :D hopefully everything goes fine :)
  11. Aug 3, 2010 at 4:46 AM
    hoeflich
    florida
    96 3.4L 4X4
    Stuff
    hitaco, you really dont need anything more then zip ties, it does not move at all on mine, and I have them spread out every 3-4 inches...but good on you nonetheless.
