satoshi help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fiolo, Jan 16, 2012.
  1. Jan 16, 2012 at 10:39 AM
    Fiolo
    Fiolo [OP] Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Ok so I'm in processor making a satoshi grille, and had trouble with the bondo, When you cut the inside out of the 98 grille it leaves 2 big holes on each side and I already bondoed and sanded it but you can still see where the hole was because of cracks around it, how can I fix that so that it will look smooth and no cracks
  2. Jan 16, 2012 at 11:58 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
  3. Jan 16, 2012 at 12:00 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    bondo the 3m bondo from auto parts stores is garbage.
    rage gold is the #1 in my opinion.
    but when you apply it thin layers work the best.
    you needed to cover thouse wholes with something before you try and fill it. the gap you can cover with body filler is only the size of a dime. any larger gap it will fall, crack, act up on you.
    cover the back side of the hole with duct tape if you need to and then fill it. it needs some support. the best way the body shop way to do it is cut a fiberglass strip and put it on the back sides of the holes let it sit and then fill it.
    it takes time, time is your worst enemy but the more time you take the better the end result.
  4. Jan 16, 2012 at 12:10 PM
    Fiolo
    Right I might put a thin layer of bondo on the cracks and see what happens, and yeah for the backing I used duct tape
