Satoshi slain - inner-grill paint ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmb, Mar 18, 2012.
  1. Mar 18, 2012 at 5:27 PM
    dmb
    dmb [OP] Well-Known Member
    Boise, ID
    Hey guys I did a search but couldn't find anything specific to the inner-grill.
    I finished my Satoshi grill this weekend. Didn't have any problems it just took a loong time cutting/bondoing/sanding.
    I sanded the inner-grill surround and painted with satin-black Krylon Fusion, four coats about 20 mins apart. Now that everything has dried I can still see areas that were sanded. It doesn't look bad from afar but up close you can see it.
    Should I sand everything back down and use a filler primer? Then paint?
    I can get some pics if that'll help.
  2. Mar 18, 2012 at 5:58 PM
    knabber
    knabber Member
    Knabb
    Hampton Roads
    Tacoma TRD 4x4 Sport
    6" Fabtech Basic Kit
    I just finished my satoshi this weekend. I had the same problem you had. The filler primer took care of it. If that doesnt work, try some more sanding :D
  3. Mar 18, 2012 at 8:07 PM
    dmb
    Boise, ID
    Roger that! Thanks!
