savage 111 30-06 problems
Discussion in 'Guns & Hunting' started by brutalguyracing, Sep 4, 2010.
  1. Sep 4, 2010 at 8:25 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    ok i just got this savage model 111 30-06 sprg.
    for a cheap price .....
    i was shooting it and it seems that the second shot will not chamber unless you apply upward force to the mag." not alot"
    yes this rifle has a 4 shot mag.
    the 1st and 2nd and 4th shot work flawless..
    but the 3rd always requires that you apply upward pressure on clip
    any thoughts or ideas....
    i also have this same kinda problem on a old glenfield model 25 .22lr
    which is made by marlin.
    that has a 7 round clip "i have a few of them"
    so i know it is not a clip problem with this rifle
    any ideas on what parts on this rifle might need replacing as well
    any help is app.:help::help:
  2. Sep 4, 2010 at 10:55 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Replace the follower spring in the mag...?
  3. Sep 4, 2010 at 10:59 AM
    Hillbilly Zombi
    Hillbilly Zombi Well-Known Member
    Wilmington, NC
    01 2.7L Tacoma 4x4
    B5100's all around + Fabtech full length aal + diff. drop. Eagle Alloy 15" wheels with 32" BFG AT's. Custom built skid plate, Rhino lined bed, Westin bars, Husky liners.
    Yea, I'd try a new magazine out first.
  4. Sep 4, 2010 at 12:19 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    9 times in 10, if you have a feeding problem, it's the mag. Check for any burrs or dents on the magazine's feed lips and correct them. I suspect that you'll find a problem with the feed lip on the side where that second cartridge rests. It's possible that the previous owner dropped the mag.
  5. Sep 4, 2010 at 12:32 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    finding a new mag for this thing is not going well.
    its a side button model.....
  6. Sep 4, 2010 at 12:40 PM
    Dimonback
    Patrick
    I'm no expert, but agree with Badwin- the mag itself has been bent out of shape or the spring has been compressed too long (as in leaving rounds in it for years). Maybe Brownells could help you find the spring.
  7. Sep 4, 2010 at 12:44 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    do you think an old spring or whatever would cause just 1 position to misfeed?
    1,2,4 feed fine?
    its always the 3rd one ...the bolt skims over the top of said round without feeding it
  8. Sep 4, 2010 at 2:36 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    alright guys update:
    fixed the problem found the front action screw missing on the rifle..
    "i knew the barrell felt kinda loose"
    went to hardware store its an odd ball size "but they had it"
    cut it to fix perfectly
    and retried loading
    and bam works perfectly now
    thanks again for all your help
    and i also found clips from shoppers choice
    "go figure"
    now i need to fix the glenfield model 25 feed problems
    do you guys have any advise on that one????
  9. Sep 4, 2010 at 3:45 PM
    Dimonback
    Patrick
    Could be... if I had to look for a reason, I'd say rounds 1 and 2 have enough tension from the spring due to the compression state of the spring. Round three is slightly offset from the feed lips and needs a bit more push to get it straight. Round 4 is stripping straight off the follower. Kinda sorta makes sense to me, but I'm guessing.
    LOL... of course, your barrel could be loose, eh?
  10. Sep 4, 2010 at 3:49 PM
    Dimonback
    Patrick
    On the Glenfield (I had one, bought from Walgreens way the hell back when...)what's the possibility of some crud on the feed ramp? They coated some .22 bullets with wax awhile back as cheap waterproofing....
  11. Sep 4, 2010 at 4:24 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    what is seems like on the glenfiels is the clips not being held up tight enough so the bolt does not catch the bullet
    when i aply pressure on the clip they load fine
  12. Sep 4, 2010 at 5:47 PM
    Badwin45
    OKC
    Double tap
  13. Sep 4, 2010 at 5:48 PM
    Badwin45
    OKC
    Don't know about the Glenfield but leaving mags loaded will NOT weaken the spring. It's the repetitive cycling that does it. Glad you got your rifle fixed. Now where's your range report?
    ;o)
  14. Sep 4, 2010 at 5:53 PM
    Dimonback
    Patrick
    I'm no gunsmith, but I believe I'm going to disagree with you on that score. No offense, but you'll find a lot of advice to unload your mags so that the steel spring doesn't permanently deform.
  15. Sep 4, 2010 at 7:02 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    no range around here must wait till friday for some field testing
    cant be the clips i have 2 brand new from marlin and a few older ones and its all the same
    now i find the shells are not ejecting
    i love this gun it was my first but i dont know if it is worth it to repair
    ill just have to break in the ruger 10/22/ss i got siting here
    unless you guys have some good advise
  16. Sep 5, 2010 at 11:40 AM
    Dimonback
    Patrick
    Badwin, I'll have a serving of the crow pie, please. My gunsmith buddies tell me I'm wrong, or that I've been told wrong, and that silicon steel springs will not take a set.
    Guess I'll go ahead and top off my extra mags.
  17. Sep 9, 2010 at 9:51 AM
    Badwin45
    OKC
    ;) I was told the same thing for years then ran across some posts at ARFCOM and heard Tom Gresham talking about it and quit worrying.
    I like my crow with BBQ sauce...
