Savage Axis XP Youth Rifle - Thoughts? Reviews? Suggestions?
Discussion in 'Guns & Hunting' started by steveo27, Oct 14, 2014.
  1. Oct 15, 2014 at 11:38 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    This ^
    Agreed, why the fuck wouldn't they just spend another .18 at the factory and use metal springs originally. In a pinch you and I are able to potentially tweak a metal spring to get us through a hunt. Plastic goes snap and we find ourselves looking for a paperclip, thread and a rubber band.....
  2. Oct 15, 2014 at 11:56 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Maybe the plastic spring is $.06. :notsure:
    There are concessions to be made when you're shopping a new rifle in this price range from a major manufacturer. Cheaper stocks/bedding, cheaper trigger assemblies, cheaper barrels, less fit and finish. I hope that poster comes back and chimes in, I'm genuinely curious about with all the corners cut on these types of rifles why a magazine release spring of all things is the thing he mentioned as a possible durability issue.
  3. Oct 15, 2014 at 12:01 PM
    T4RFTMFW
    BTW I'm not trying to sound like a prick, I'm really curious to discuss this as it isn't something I'd have put a second thought to.
  4. Oct 15, 2014 at 5:13 PM
    T4RFTMFW
    ERMEGERD THERRD BERRMP
  5. Oct 15, 2014 at 9:30 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Thanks for all the info and comments?
    :beer:
    After a little more though/discussion. Her budget is under 500$. She wants something in a youth model that has a scope.
    Were going to go check out a few shops that sell used rifles this weekend to see if we can find a nice used Remington or Winchester.
  6. Oct 15, 2014 at 10:21 PM
    T4RFTMFW
    I'd be jazzed if you let us know what you end up with.
  7. Oct 15, 2014 at 10:41 PM
    Idaholandho
    :woot:
    and a VW fan to boot!
  8. Oct 16, 2014 at 6:18 AM
    steveo27
    Pittsburgh
    Been messing with them for over a decade now.
    Long as I remember, I'll keep this thread up to date.
  9. Oct 18, 2014 at 10:45 AM
    Indy
    Indy Master of all I survey.
    Because :)
    Ok, longer answer. The savage edge (a year later renamed axis due to copyright infringement) was designed from the get go to be made as inexpensively as possible and to be sold as inexpensively as possible. There isn't a part on any firearm ever made that couldn't be better for another dollar, but eventually those dollars add up and there goes the budget.
    The edge/axis made quite a few breakthroughs in price by combing pieces. The rear sling stud doubles as the attachment point for the recoil pad. The actions for both long and short action are identical. The only thing that makes a short action is a different trigger guard, coupled with 1 of 2 magazines. You can change an axis into any caliber with 10 seconds and a new trigger guard (and barrel/bolt face of course). The stock is universal across all calibers. They did quite a few other things also but that's off the top of my head. In the end they turned out a pretty good rifle for a really good price point.
    The mag in reference, attaching a metal spring to a plastic mag is more failure prone than going all metal or all plastic. Going to the metal spring makes is more likely you'll be in the field wishing for a roll of duct tape. So the .18 difference is more likely $10-15 difference for a metal mag. And so far I've used mine in sub zero temps, no problems so far and I'm far from gentle on my tools.
    However, they use the same quality barrels on their entire line. So you can grab any savage/stevens barrel and swap over.
    The biggest negatives I've come across since they introduced the rifle.
    1. Trigger. It's heavy from the factory, 6-8 pounds. That's not an ideal weight for an experienced shooter. But this is a budget rifle, usually picked up early in a shooting career and a heavy trigger is IDEAL imo for a rookie shooter that can't keep his booger hooks off like he should.
    The trigger does break cleanly though, and you can drop weight to 2-4 pounds with a .10 spring. It takes about 10 minutes. And it's a pretty decent trigger at that point.
    2. Stock. It's ugly. But again imo, I've never seen a pretty synthetic stock so it's no uglier than any other to me. And I always say a rifle is as pretty as the groups it turns in. So the savage is really pretty to me.
    3. Stock again, it's flimsy and can flex. By all accounts the stock flexes if you set it across to cinder blocks and bounce in the middle. Pretty much like any other stock made. If it doesn't it breaks, and you shouldnt be bouncing on your rifle in any case. But again imo, the stock could whip 90 degrees after every shot, as long as it keeps turning in good groups.
    Personally I own 1 savage edge. I was dicking around on GB and saw an auction that didn't have a reserve and no bidders on it. I ended up with a NIB 25-06 for $209 shipped. The downside is I had 2 'better' 25-06 in the collection. I have some nice guns :)
    But a few years later I have exactly 1 25-06, and it's the edge. It outshot every other rifle and it's the one I carry hunting every year. Except for elk, I use a bigger caliber for bigger animals. The edge, assuming I do my part, turns in touching groups at 100 yards with me on a bipod, harvested several animals out past 600 yards. It's light and easy to carry in the field. It's a great hunting rifle. It's not a great benchrest rifle. And if I ever fall down a ravine and break it, it cost me $200.
    Like I said I have some nice rifles and I'm always moving my collection around. The edge is the only budget rifle I would pick up without worry and the only 'budget' gun in my collection. Where it will stay :)
    Best advice I have is to at all costs avoid a rifle/scope package. A bad piece of glass on a really good rifle makes for a really bad combination. And a really good piece of glass on a mediocre rifle turns it into a nice little package. Factory package glass is JUNK from any manufacturer. Along the budget rifle below is a redfield scope. Budget friendly and good optics (by leupold) with a lifetime warranty. It is the entry level I would consider, roughly $150-250 if memory serves.
    This ^ was last week. Roughly 1/4 mile by laser and me shooting some bastardized off-hand crouching abomination of a shooting position. If you want I'll preach how great the barnes ttsx bullet is. I love that bullet :laugh:
  10. Oct 18, 2014 at 11:01 AM
    Indy
    And the great thing about synthetic stocks, it doesn't break your heart if screw them up. The above rifles first paint job. It's ok to throw up a little :laugh: I don't think it made it out of the house looking like that but I had to document probably the ugliest thing I'd ever done.
  11. Oct 18, 2014 at 12:17 PM
    T4RFTMFW
    Best post ever Indy. Great insight. Nice kill!
  12. Oct 18, 2014 at 12:59 PM
    TacomaRobert
    TacomaRobert Well-Known Member
    First, no such thing as a beginner's rifle that can kill a deer.
    Beginner's rifle is the Browning 22 lever action. Sweet. Good for plinking.
    Second. The 270 caliber is a prefect deer rifle. More long range energy than a 30-06. Recoil in a bolt action is mild. FUN to shoot. You could almost shoot it with one hand. FLAT trajectory. My win model 70 rifle puts three touching on the paper at 100 yards. You will have fun calibrating it before the hunt, unlike others that beat you up. But you won't have to. It's on zero out of the closet. BUT you will enjoy double checking.
    A fantastic rifle.
  13. Oct 18, 2014 at 6:57 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Been gone for a couple of days. The plastic magazine spring was the only thing I thought was a serious flaw. There might be a couple other shortcomings, but that one caught my attention because a failure there would put a major crimp in a hunting trip. Metal springs are more reliable than plastic IMO.
  14. Oct 18, 2014 at 9:17 PM
    Indy
    I just picked up another 270, still debating what im going to turn it into or if im going to use it as trade fodder. It was a good price.
    Recoil pad makes a world of difference. I built a 358 last year and took it to the range to function test. 10 shots had me cussing like a sailor. I put a limbsaver on it, total sweetheart now. I even put one on my 223 cuz why not :laugh: of course im wildcatting it this week to a .20p, besides the noise im curious if ill even know it fired.
  15. Oct 18, 2014 at 9:22 PM
    #35
    Indy
    They have been out for several years and savage isnt the only company that uses them. I havent come across it as an issue, i spend more time on hunting forums than here. But if you end up with a rifle that uses one and youre overly concerned just pick up an extra mag and carry it with you. I carry 1 extra for my 460 when im hunting and ive never had the chance to use a pistol yet. But its with me regardless.
  16. Oct 19, 2014 at 1:02 AM
    #36
    TacomaRobert
    A big 'hell yeah" on the recoil pad! I used to do a lot of skeet and trap with an over under 12ga. Would end up with a bruised shoulder even with one. Would be impossible for me to shoot more than a few minutes without.
    When hunting I don't feel the recoil due to the adrenaline and the relatively few shots and a coat. But at the range, shooting dozens of round, in the middle of the summer, light shirt, it's way more noticeable.
    What is a .20p ?
  17. Oct 19, 2014 at 8:12 AM
    #37
    Indy
    20 practical, 223 necked down to 20 caliber. It pushes a 32gr at about 4000fps. It should be fun.
    I havent bought ammo in a couple decades, im slowly running out of rifles that its even an option :)
  18. Oct 19, 2014 at 8:48 AM
    #38
    steveo27
    Pittsburgh
    Great info.
    We're going out this afternoon to do some more shopping, maybe I'll have an update this evening.
  19. Oct 19, 2014 at 9:47 PM
    #39
    steveo27
    Pittsburgh
    Welp. After stopping at 4 more stores and looking at some things, the Savage XP in a 243 Win was the winner.
    She checked out the Ruger American compact, the youth Remington 770, the Savage Axis XP, and a few other things rifles that were slightly over budget.
    The Ruger was still too long even though it was compact rifle. The Remington was too heavy.
    The Savage felt the best to her. The stock was the right length. The safety is easily accessible. It was light enough that she didnt struggle to with it.
    The trigger is a little heavier than the other guns we looked at. The plastic magazine is weird, but doesnt seem as bad as everyone makes it out to be.
    Next Sunday, were going to shoot a box of shells through the gun and see what happens.
  20. Oct 20, 2014 at 2:13 AM
    #40
    TacomaRobert
    Awesome! Let us know how it goes!
